大家好,
关于L6480数据表,STEP_MODE寄存器具有SYNC_EN位和SYNC_SEL。如果SYNC_EN位设置为高电平,则SYNC输出根据SYNC_SEL参数提供时钟信号。从电气位置信息EL_POS寄存器开始获得同步信号。
我很明白这是如何工作的。有人可以解释一下吗。让我们说SYNC_EN = 1; SYNC_SEL = 000;我应该期望BUSY / SYNC输出提供什么?
先谢谢你
#l8480忙/同步输出
以上来自于谷歌翻译
以下为原文
Hi all,
Regarding to L6480 datasheet, STEP_MODE register has SYNC_EN bit and SYNC_SEL. if SYNC_EN bit is set high, then SYNC output provides a clock signal according to the SYNC_SEL parameter. the sync signal is obtained star
ting from electrical position info EL_POS register.
I am quite understand how does this work. Can someone explain it more. Lets say SYNC_EN = 1; SYNC_SEL = 000; what should I expect BUSY/SYNC output provides?
Thank you in advance
#l8480-busy/sync-output
