@ vatsal.naik,
很高兴知道您的设计与vivado 2017.4一起使用。
您是否在Vivado 2016.2中使用支持的操作系统?
检查以下AR:
https://www.xilinx.com/support/answers/54242.html
如果您使用过支持的操作系统,那么这可能是在以后的版本中修复的错误。
问题解决之后,请将有用的帖子标记为“接受为解决方案”,以关闭此主题
--Syed
-------------------------------------------请注意 - 请标记答案
如果提供的信息有用,请“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢Kudos .------------------------
在原帖中查看解决方案
以上来自于谷歌翻译
以下为原文
@vatsal.naik,
Glad to know that your design is working with vivado 2017.4.
Did you use supported OS with Vivado 2016.2? Check the following AR:
If you have used supported OS then this could be a bug which got fixed in the later releases.
As the issue is resolved, please close this thread by marking the helpful post as "Accept as Solution"
--Syed
Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful.
Give Kudos to a post which you think is helpful and reply oriented.
---------------------------------------------------------------------------------------------View solution in original post
@ vatsal.naik,
检查以下AR:
--Syed
在原帖中查看解决方案
以上来自于谷歌翻译
以下为原文
@vatsal.naik,
--Syed
举报
