根据英特尔支持代理在最近关于该主题的讨论中提供的信息,Up Board上的两个D415应该可以工作。
Aaeon®UP板设置采用2xIntel®RealSense™深度相机D415
对于多相机设置,Up Board不是您唯一的选择。
它应该适用于任何带有Intel或ARM处理器芯片的计算设备,该芯片可以连接2个或更多摄像头(无论是直接连接到设备上的USB 3.x端口还是连接到USB 3.x集线器)。
关于你的Wi-Fi问题......通过wi-fi发送摄像机数据是不切实际的,因为它需要某种布线,因为通过电缆发送了大量的摄像机数据带宽。
替代解决方案可能是使用USB电缆扩展,例如Newnex提供的工业级解决方案,可以承载高达100米的RealSense数据。
用于英特尔实感D400系列相机的USB扩展 - YouTube
以上来自于谷歌翻译
以下为原文
Two D415s on an Up Board should work, according to information provided by an Intel support agent in a recent discussion on this topic.
Aaeon® UP Board setup with 2x Intel® RealSense™ Depth Camera D415
Up Board isn't your only option though for multi-camera setups. It should work with any computing device with an Intel or ARM processor chip that can have 2 or more cameras attached to it (whether directly to USB 3.x ports on the device or to a USB 3.x hub).
Regarding your wi-fi question ... it would not be practical to send camera data over wi-fi, as it requires some kind of cabling due to the large amount of camera data bandwidth that is sent through the cable. And alternative solution may be to use USB cable extension, such as the industrial-grade solutions provided by Newnex that can carry RealSense data up to 100 m.
USB Extension for Intel RealSense D400 Series Camera - YouTube
以上来自于谷歌翻译
以下为原文
举报
