@ araongao2015
是的,除非您的pblock设置了EXCLUDE_PLACEMENT属性。
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_2/ug912-vivado-properties.pdf#page=200
pblock默认禁用此属性。
--Syed
-------------------------------------------请注意 - 请标记答案
如果提供的信息有用,请“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢Kudos .------------------------
在原帖中查看解决方案
以上来自于谷歌翻译
以下为原文
@araongao2015
Yes, unless your pblock has EXCLUDE_PLACEMENT property set on it.
This property is disabled by default for pblock.
--Syed
Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful.
Give Kudos to a post which you think is helpful and reply oriented.
---------------------------------------------------------------------------------------------View solution in original post
@ araongao2015
pblock默认禁用此属性。
--Syed
在原帖中查看解决方案
以上来自于谷歌翻译
以下为原文
@araongao2015
--Syed
举报
