扫一扫,分享给好友
#include
#define uint unsigned int #define uchar unsigned char uchar bdata m_key,key;//定义键沿有效寄存器和电平有效寄存器(bdata是可位寻址片内RAM) ***it wx1=P3^0;//位选 ***it wx2=P3^1; ***it wx3=P3^2; ***it wx4=P3^3; ***it k1=m_key^0; ***it k2=m_key^1; ***it k3=m_key^2; ***it k4=m_key^3;//按键键沿标志 ***it buz=P3^7; bit shan;//闪烁标志位 ***it s=P1^7;//秒控制位 bit nao; //闹钟标志 uchar code sm_tab[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0x88,0x83}; uchar code sszymmh[]={ 6,2,3, 5,2,1, 3,2,2, 5,2,2, 1,3,2, 6,2,1, 5,2,1, 6,2,4, 3,2,2, 5,2,1, 6,2,1, 5,2,2, 3,2,2, 1,2,1, 6,1,1, 5,2,1, 3,2,1, 2,2,4, 2,2,3, 3,2,1, 5,2,2, 5,2,1, 6,2,1, 3,2,2, 2,2,2, 1,2,4, 5,2,3, 3,2,1, 2,2,1, 1,2,1, 6,1,1, 1,2,1, 5,1,6, 0,0,0 };//世上只有妈妈好 // 音节频率 高八位 uchar code FREQH[]={ 0xF2,0xF3,0xF5,0xF5,0xF6,0xF7,0xF8, 0xF9,0xF9,0xFA,0xFA,0xFB,0xFB,0xFC,0xFC, //1,2,3,4,5,6,7,8,i 0xFC,0xFD,0xFD,0xFD,0xFD,0xFE, 0xFE,0xFE,0xFE,0xFE,0xFE,0xFE,0xFF, } ; // 音节频率 低八位 uchar code FREQL[]={ 0x42,0xC1,0x17,0xB6,0xD0,0xD1,0xB6, 0x21,0xE1,0x8C,0xD8,0x68,0xE9,0x5B,0x8F, //1,2,3,4,5,6,7,8,i 0xEE,0x44, 0x6B,0xB4,0xF4,0x2D, 0x47,0x77,0xA2,0xB6,0xDA,0xFA,0x16, }; uchar k,i,sm_sz,mkcnt,tz,scnt,shancnt,s_cnt,timer0h,timer0l,time,ncnt,sz0,sz1,sz2,sz3,sz4; uchar xs,fz;//小时和分钟变量 uchar nxs,nfz;//闹钟小时和分钟变量 void init();//闪烁 void pdnz(void); //判断闹钟 void sjtz(void); //调整时钟 void nzsj(void); //闹钟设置 void nzx(void); //闹钟歌曲 void disp(); //数显 void MKYscan(void); //按键扫描 void main() { init(); while(1) { while(!TF0); //判断5ms是否到了? TF0=0; TH0=0XEC;//初始化赋值5mS TL0=0X78; MKYscan(); disp(); scnt++; if(scnt>=100) { s=~s;//秒控制位取反 ,500ms一次 scnt=0; s_cnt++; //秒计数 } if(s_cnt>=120) //120*500=60000为60秒,分钟加一 { s_cnt=0; fz++; if(fz>=60) { fz=0; xs++; if(xs>=24) xs=0; } } sz0=fz%10; sz1=fz/10; sz2=xs%10; sz3=xs/10; if(k1) { tz++; if(tz>=3) tz=0; } switch(tz) //散转 { case 0:pdnz();break;//闹钟判断 case 1:sjtz();break;//时间调整 case 2:nzsj();break; //闹钟时间设定 case 3:nzx(); break; //闹钟响 default:break; } } } void MKYscan(void)//矩阵键盘扫描 { uchar r1,r2,zs; zs=P3; P3=0xff; P3=0xdf;//扫键 r1=P3; P3=0xff; r1=r1^0xff; r1>>=1; if(r1)//有键? { mkcnt++; if(mkcnt>=4)//20ms { mkcnt=0; m_key=r1; } else m_key=key; } else { m_key=0; mkcnt=0; } r2=m_key; m_key=m_key&(key^m_key);//沿提取 key=r2; P3=zs|0x0f; } void init() { TMOD=0x11;//中断定时/计数 TH0=0XEC; //定时5ms TL0=0X78; EA=1; TR0=1; TF0=0; i=0; s=0; mkcnt=0; key=0; shancnt=0;//数码管闪烁计数 tz=0; shan=0; s_cnt=0; nao=0; } void sjtz(void) { shancnt++; if(shancnt>=100) {shan=~shan;shancnt=0;} //500取反 //s=1; if(k2) { xs++; if(xs>=24) xs=0; } if(k3) { fz++; if(fz>=60) fz=0; } } void disp()//扫描数码管 { if(!shan) { wx1=1;//位选关 wx2=1; wx3=1; wx4=1; sm_sz++; //数码散转 if(sm_sz>=4) { sm_sz=0; } switch(sm_sz) { case 0:wx4=0; //选数码管一 P1=0xff;//取反,低电平 P1=sm_tab[sz0]; //分钟低 break; case 1:wx3=0; P1=0XFF; P1=sm_tab[sz1]; //分钟高 break; case 2: wx2=0; P1=0xff; P1=sm_tab[sz2]; //小时低 break; case 3: wx1=0; P1=0XFF; P1=sm_tab[sz3]; //小时高 break; } } else {wx1=1;wx2=1;wx3=1;wx4=1;} } void nzsj(void) //闹钟时间 { s=0;//秒控制标志位 shan=0;//闪烁标志位 if(k2) { nao=1; nxs++; if(nxs>=24) nxs=0; } sz3=nxs/10; sz2=nxs%10; if(k3) { nao=1; nfz++; if(nfz>=60) nfz=0; } sz0=nfz%10; sz1=nfz/10; } void nzx(void) { ET1=1; if(k4) {nao=0;tz=0;}//按键按下闹钟标志位为零停止中断 if(!ncnt) { TR1=0; k=sszymmh[i]+7*sszymmh[i+1]-1;//去音符振荡频率所需数据 TH1=FREQH[k]; TL1=FREQL[k]; time=sszymmh[i+2]; i=i+3; ncnt=time*30; TR1=1; } ncnt--; if(i>=100) {i=0;nao=0;tz=0;} } void TIM1_ISR() interrupt 3 { TR1=0; buz=~buz;//取反 TH1=FREQH[k]; TL1=FREQL[k]; TR1=1; } void pdnz(void) //判断闹钟模块 { buz=1; ET1=0; if(xs==nxs&&fz==nfz&&nao==1) //闹钟时间到 { tz=3; if(k4) {nxs=0;nfz=0;} } }
3个回答
程序不对把,灯是由P1.7控制的
程序的s定义的就是1.7口,那个对应的就是LED
灯一秒亮一秒灭 可以考虑写在中断里
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
串口发送中断中对发送I/O口定义为GPIO输出,出现发送数据不完整,缺少2个字节,求解答
1589 浏览 3 评论
777 浏览 0 评论
【xG24 Matter开发套件试用体验】10-Bluetooth示例1
908 浏览 0 评论
996 浏览 0 评论
【xG24 Matter开发套件试用体验】power specification电源规格参数配置
810 浏览 0 评论
【youyeetoo X1 windows 开发板体验】少儿AI智能STEAM积木平台
10864 浏览 31 评论
GMT+8, 2024-8-27 01:25 , Processed in 0.659728 second(s), Total 76, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
