2个回答
利用TIM1模块的1、2通道产生一共4路PWM的代码例子,类似代码也可以参考ST的固件库中相应example
C语言: TIM1模块产生PWM,带死区 RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB | RCC_APB2Periph_GPIOC | RCC_APB2Periph_GPIOD, ENABLE); //启动AFIO RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE); //启动TIM1 RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1, ENABLE); //Step2. GPIO做相应设置,为AF输出 //PA.8/9口设置为TIM1的OC1输出口 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8 | GPIO_Pin_9; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOA, &GPIO_InitStructure); //PB.13/14口设置为TIM1_CH1N和TIM1_CH2N输出口 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13 | GPIO_Pin_14; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOB, &GPIO_InitStructure); //Step3. TIM模块初始化 void TIM_Configuration(void) { TIM_TimeBaseInitTypeDef TIM_BaseInitStructure; TIM_OCInitTypeDef TIM_OCInitStructure; TIM_BDTRInitTypeDef TIM_BDTRInitStructure; //TIM1基本计数器设置(设置PWM频率) //频率=TIM1_CLK/(ARR+1) TIM_BaseInitStructure.TIM_Period = 1000-1; TIM_BaseInitStructure.TIM_Prescaler = 72-1; TIM_BaseInitStructure.TIM_ClockDivision = 0; TIM_BaseInitStructure.TIM_CounterMode = TIM_CounterMode_Up; TIM_BaseInitStructure.TIM_RepetitionCounter = 0; TIM_TimeBaseInit(TIM1, &TIM_BaseInitStructure); //启用ARR的影子寄存器(直到产生更新事件才更改设置) TIM_ARRPreloadConfig(TIM1, ENABLE); //TIM1_OC1模块设置(设置1通道占空比) TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1; TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable; TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High; TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_High; TIM_OCInitStructure.TIM_Pulse = 120; TIM_OC1Init(TIM1, &TIM_OCInitStructure); //启用CCR1寄存器的影子寄存器(直到产生更新事件才更改设置) TIM_OC1PreloadConfig(TIM1, TIM_OCPreload_Enable); //TIM2_OC2模块设置(设置2通道占空比) TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable; TIM_OCInitStructure.TIM_Pulse = 680; TIM_OC2Init(TIM1, &TIM_OCInitStructure); //启用CCR2寄存器的影子寄存器(直到产生更新事件才更改设置) TIM_OC2PreloadConfig(TIM1, TIM_OCPreload_Enable); //死区设置 TIM_BDTRInitStructure.TIM_OSSRState = TIM_OSSRState_Enable; TIM_BDTRInitStructure.TIM_OSSIState = TIM_OSSIState_Enable; TIM_BDTRInitStructure.TIM_LOCKLevel = TIM_LOCKLevel_OFF; TIM_BDTRInitStructure.TIM_DeadTime = 0x90; //这里调整死区大小0-0xff TIM_BDTRInitStructure.TIM_Break = TIM_Break_Disable; TIM_BDTRInitStructure.TIM_BreakPolarity = TIM_BreakPolarity_High; TIM_BDTRInitStructure.TIM_AutomaticOutput = TIM_AutomaticOutput_Enable; TIM_BDTRConfig(TIM1, &TIM_BDTRInitStructure); //TIM1开启 TIM_Cmd(TIM1, ENABLE); //TIM1_OC通道输出PWM(一定要加) TIM_CtrlPWMOutputs(TIM1, ENABLE); }
最佳答案
你需要注意三个参数的设定,最高的,最低的,中间的
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
STM32F405驱动DS1302时钟模块,输出时间错乱该怎么排查?
2776 浏览 2 评论
stm32f405rgt6驱动DS1302ZN出现时间错乱问题
2379 浏览 1 评论
stm32用fsmc读取ad7606采集数据,数据不变,只有开发版复位才更新数据
2255 浏览 0 评论
2367 浏览 1 评论
1625 浏览 1 评论
/9
GMT+8, 2025-12-1 18:51 , Processed in 0.645367 second(s), Total 75, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2312
