扫一扫,分享给好友
我想用STM32通过DMA,获得外设SPI的数据。 SPI1->DR寄存器里面有值,但是DMA读到的数一直是0,这是什么情况啊?附上代码,如果哪里有错误请各位帮忙指正。另外,我只用STm32通过SPI获得的数据是正确的。
void DMA_Configuration_SPI1_RX(void) //DMA初始化 { DMA_InitTypeDef DMA_InitStructure; RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE); DMA_DeInit(DMA1_Channel4); DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)SPIx_DR; DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)&SPI_Buffer_Rx; DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC; DMA_InitStructure.DMA_BufferSize = 1; DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable; DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Disable; DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord; DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord; DMA_InitStructure.DMA_Mode = DMA_Mode_Normal; DMA_InitStructure.DMA_Priority = DMA_Priority_VeryHigh; DMA_InitStructure.DMA_M2M = DMA_M2M_Disable; DMA_Init(DMA1_Channel4, &DMA_InitStructure); } //SPI口初始化 void SPIx_Init(void) { SPI_InitTypeDef SPI_InitStructure; GPIO_InitTypeDef GPIO_InitStructure; /* Configure SPI1 pins: SCK, MISO and MOSI */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5 | GPIO_Pin_6 | GPIO_Pin_7; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //复用推挽输出 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOA, &GPIO_InitStructure); /* Configure I/O for Flash Chip select */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5; //SPI CS GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //复用推挽输出 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOC, &GPIO_InitStructure); /* Deselect the FLASH: Chip Select high */ GPIO_SetBits(GPIOC,GPIO_Pin_5); GPIO_SetBits(GPIOC,GPIO_Pin_4); SPI_Cmd(SPI1, DISABLE); //不使能SPI外设 自己加上 /* SPI1 configuration */ SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex; //SPI设置为双线双向全双工 SPI_InitStructure.SPI_Mode = SPI_Mode_Master; //设置SPI工作模式:设置为主SPI SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b; //设置SPI的数据大小:SPI发送接收8位帧结构 SPI_InitStructure.SPI_CPOL = SPI_CPOL_High; //选择了串行时钟的稳态:时钟悬空高 SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge; //数据捕获于第二个时钟沿 SPI_InitStructure.SPI_NSS = SPI_NSS_Soft; SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_64; //定义波特率预分频的值:波特率预分频值为256 SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB; //指定数据传输从MSB位还是LSB位开始:数据传输从MSB位开始 SPI_InitStructure.SPI_CRCPolynomial = 7; //CRC值计算的多项式 SPI_Init(SPI1, &SPI_InitStructure); //根据SPI_InitStruct中指定的参数初始化外设SPIx寄存器 SPI_Cmd(SPI1, ENABLE); //使能SPI外设 SPIx_ReadWriteByte(0xff);//启动传输 } //SPIx 读写一个字节 //TxData:要写入的字节 //返回值:读取到的字节 u8 SPIx_ReadWriteByte(u8 TxData) { GPIO_ResetBits(GPIOC,GPIO_Pin_5); //CS片选为 低电平有效的逻辑输入 while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_TXE) == RESET); //检查指定的SPI标志位设置与否:发送缓存空标志位 /* Send byte through the SPI1 peripheral */ SPI_I2S_SendData(SPI1, TxData); //通过外设SPIx发送一个数据 /* Wait to receive a byte */ while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_RXNE) == RESET); //检查指定的SPI标志位设置与否:接受缓存非空标志 /* Return the byte read from the SPI bus */ GPIO_SetBits(GPIOC,GPIO_Pin_5); return SPI_I2S_ReceiveData(SPI1); //返回通过SPIx最近接收的数据 } /********读取AD7705第一通道数据************/ u16 ReadTM7705(u8 n) { unsigned long Ret = 0; TM7705_Init1(); SPIx_ReadWriteByte(0x38);//设置读当前通道数据 while(GPIO_ReadInputDataBit(GPIOC, GPIO_Pin_4)== 1) { ; } MYDMA_Enable(DMA1_Channel4); Ret = DMA_read(); } return Ret; } void MYDMA_Enable(DMA_Channel_TypeDef*DMAy_Channelx) { SPI_I2S_DMACmd(SPI1, SPI_I2S_DMAReq_Rx, ENABLE); DMA_Cmd(DMA1_Channel4, DISABLE ); //关闭USART1 TX DMA1 所指示的通道 DMA_Cmd(DMA1_Channel4, ENABLE); //使能USART1 TX DMA1 所指示的通道 } u16 DMA_read(void) { u16 data; data = SPI_Buffer_Rx; return data; } |
8个回答
楼主知道原因了吗?我也遇到类似问题了,数据一直是0.
我也想知道为什么,楼主解决了吗?
我这也是,楼主怎么解决的?
楼主辛苦了,十分感谢!
你设置的SPI为主模式,在SPI接收数据时要有时钟才能接收到数据,才能将数据放在缓冲寄存器里,也就是说你在接收是也要发送数据,随便发送诸如0xff什么就行了
最终,怎么解决的???
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
STM32F405驱动DS1302时钟模块,输出时间错乱该怎么排查?
2797 浏览 2 评论
stm32f405rgt6驱动DS1302ZN出现时间错乱问题
2403 浏览 1 评论
stm32用fsmc读取ad7606采集数据,数据不变,只有开发版复位才更新数据
2276 浏览 0 评论
2388 浏览 1 评论
1637 浏览 1 评论
/9
GMT+8, 2025-12-1 22:03 , Processed in 0.679037 second(s), Total 57, Slave 49 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2021
