tiM2的输出比较模式的一个简单实验,要求比较成功后产生中断,在中断服务程序里翻转PF6。
其中系统时钟72MHz 实验中计数器工作正常,CCR1值正常。 但是实验中中断并未产生,用软件模拟产生中断后,一切正常。 所以问题应该出在比较的时候。就是说:当计数器CNT的计数值与CCR1的值相等时,没有中断产生 但是我没有发现问题。请各位帮忙看看,源码如下: main.c #include "STM32f10x.h" TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure; TIM_OCInitTypeDef TIM_OCInitStructure; __IO uint16_t CCR1_Val = 40961; uint16_t PrescalerValue = 0; void RCC_Configuration(void); void GPIO_Configuration(void); void NVIC_Configuration(void); int main(void) { RCC_Configuration(); NVIC_Configuration(); GPIO_Configuration(); PrescalerValue = (uint16_t) (SystemCoreClock / 12000000) - 1; TIM_TimeBaseStructure.TIM_Period = 65535; //最大计数值65536 TIM_TimeBaseStructure.TIM_Prescaler = 0; //不分频 TIM_TimeBaseStructure.TIM_ClockDivision = 0; //不滤波 TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; //向上计数模式 TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure); TIM_PrescalerConfig(TIM2, PrescalerValue, TIM_PSCReloadMode_Immediate);//计数器时钟为6MHz TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_Timing; //冻结,比较成功后OC1状态不变 TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; //OC1输出使能 TIM_OCInitStructure.TIM_Pulse = CCR1_Val; //给CCR1赋值 TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High; //高电平有效 TIM_OC1Init(TIM2, &TIM_OCInitStructure); TIM_OC1PreloadConfig(TIM2, TIM_OCPreload_Disable); //不使用预装载寄存器 TIM_ITConfig(TIM2, TIM_IT_CC1 , ENABLE);//使能CC1中断 TIM_Cmd(TIM2, ENABLE); //开启定时器 while (1); } void RCC_Configuration(void) { RCC_PCLK1Config(RCC_HCLK_Div4); RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE); RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOF, ENABLE); } void GPIO_Configuration(void) { GPIO_InitTypeDef GPIO_InitStructure; GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOF, &GPIO_InitStructure); } void NVIC_Configuration(void) { NVIC_InitTypeDef NVIC_InitStructure; NVIC_PriorityGroupConfig(NVIC_PriorityGroup_3);//优先级分组3:7个抢占优先级,2个响应优先级 NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQn; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0; NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //TIM2全局中断使能 NVIC_Init(&NVIC_InitStructure); } stm32f10x_it.c void TIM2_IRQHandler(void) { if (TIM_GetITStatus(TIM2, TIM_IT_CC1) != RESET) { TIM_ClearITPendingBit(TIM2, TIM_IT_CC1); GPIO_WriteBit(GPIOF, GPIO_Pin_6, (BitAction)(1 - GPIO_ReadOutputDataBit(GPIOF, GPIO_Pin_6)));//ÒëÕß×¢ capture = TIM_GetCapture1(TIM2); TIM_SetCompare1(TIM2, capture + CCR1_Val); } |
5个回答
弄了几天,自己解决了。
禁止了TIM_OC1PreloadConfig(),就要在中断重新设置捕获寄存器值,这样才能不断有捕获中断产生。
今天看到这个帖子,刚开始学习STM32,写的程序和你基本一模一样,也出现了同样的问题,不过没看明白你的解决方法,TIM_SetCompare1(TIM2, capture + CCR1_Val);这句不是重新设置了比较寄存器的新值吗,我现在的程序一样进不去中断,能不能说详细点,或者传个到我邮箱365283796@qq.com,谢了 |
已解决了,不是程序的原因,是软件仿真的原因,可能是软件不能仿真定时中断,将程序改到另外一块板子,同样的程序,运行正常 |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
762 浏览 0 评论
739 浏览 0 评论
飞凌嵌入式ElfBoard-文件I/O的了解探究之复制文件描述符
668 浏览 0 评论
飞凌嵌入式ElfBoard-文件I/O的了解探究之返回错误处理与相关函数
1448 浏览 0 评论
飞凌嵌入式ElfBoard-文件I/O的了解探究之文件描述符和FILE指针转换
1058 浏览 0 评论
/9
GMT+8, 2025-12-1 19:28 , Processed in 0.693417 second(s), Total 80, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
570
