我正在尝试使用 CYW54591 启动 Azurewave。以下是我的系统设置的简介:
Nvidia Jetson Orin Nano 内核 5.15.148 Ubuntu 22 固件:BCM4355/13 wl0:2024 年 10 月 29 日 19:34:53 版本 13.35.369 (65bac01 CY) FWID 01-a64ef454 我目前处于系统能够检测到 WifiCard 并设法执行 wifi 接入点扫描的状态。然而,当连接到 wifi 接入点时,FW 崩溃并且 wifi 卡正在重新初始化。 以下是日志: 初始化 [ 848.219113] brcmfmac: brcmf_feat_firmware_capabilities enabling feature: MBSS[ 848.219117] brcmfmac: brcmf_feat_firmware_capabilities enabling feature: MCHAN[ 848.219120] brcmfmac: brcmf_feat_firmware_capabilities enabling feature: P2P[ 848.219139] brcmfmac: brcmf_feat_firmware_capabilities enabling feature: DOT11H[ 848.219145] brcmfmac: brcmf_feat_firmware_capabilities enabling feature: SAE[ 848.219458] brcmfmac: brcmf_feat_iovar_data_set GSCAN feature check failed: -23[ 848.219766] brcmfmac: brcmf_feat_iovar_int_get PNO feature check failed: -23[ 848.220000] brcmfmac: brcmf_feat_iovar_int_get enabling feature: WOWL[ 848.220433] brcmfmac: brcmf_feat_iovar_int_get enabling feature: RSDB[ 848.220752] brcmfmac: brcmf_feat_iovar_int_get TDLS feature check failed: -23[ 848.220984] brcmfmac: brcmf_feat_iovar_int_get enabling feature: MFP[ 848.221632] brcmfmac: brcmf_feat_iovar_int_get FWSUP feature check failed: -23[ 848.221637] brcmfmac: brcmf_alloc_vif allocating virtual interface (size=4680)[ 848.221654] brcmfmac: brcmf_fweh_register event handler registered for LINK[ 848.221657] brcmfmac: brcmf_fweh_register event handler registered for DEAUTH_IND[ 848.221659] brcmfmac: brcmf_fweh_register event handler registered for DEAUTH[ 848.221661] brcmfmac: brcmf_fweh_register event handler registered for DISASSOC_IND[ 848.221663] brcmfmac: brcmf_fweh_register event handler registered for ASSOC_IND[ 848.221665] brcmfmac: brcmf_fweh_register event handler registered for REASSOC_IND[ 848.221667] brcmfmac: brcmf_fweh_register event handler registered for ROAM[ 848.221669] brcmfmac: brcmf_fweh_register event handler registered for MIC_ERROR[ 848.221671] brcmfmac: brcmf_fweh_register event handler registered for SET_SSID[ 848.221673] brcmfmac: brcmf_fweh_register event handler registered for PFN_NET_FOUND[ 848.221676] brcmfmac: brcmf_fweh_register event handler registered for IF[ 848.221678] brcmfmac: brcmf_fweh_register event handler registered for P2P_PROBEREQ_MSG[ 848.221680] brcmfmac: brcmf_fweh_register event handler registered for P2P_DISC_LISTEN_COMPLETE[ 848.221683] brcmfmac: brcmf_fweh_register event handler registered for ACTION_FRAME_RX[ 848.221685] brcmfmac: brcmf_fweh_register event handler registered for ACTION_FRAME_COMPLETE[ 848.221687] brcmfmac: brcmf_fweh_register event handler registered for ACTION_FRAME_OFF_CHAN_COMPLETE[ 848.221689] brcmfmac: brcmf_fweh_register event handler registered for PSK_SUP[ 848.221691] brcmfmac: brcmf_fweh_register event handler registered for RSSI[ 848.221693] brcmfmac: brcmf_fweh_register event handler registered for ESCAN_RESULT[ 848.222046] brcmfmac: brcmf_cfg80211_attach Registering custom regulatory[ 848.224624] brcmfmac: brcmf_setup_wiphybands nmode=1, vhtmode=1, bw_cap=(1, 7)[ 848.225051] brcmfmac: brcmf_setup_wiphybands nchain=1[ 848.240726] brcmfmac: brcmf_btcoex_attach enter[ 848.240737] brcmfmac: brcmf_pno_attach enter[ 848.240936] brcmfmac: brcmf_net_attach Enter, bsscfgidx=0 mac=10:68:38:c4:0e:35[ 848.241916] brcmfmac: brcmf_cfg80211_get_tx_power Enter[ 848.241920] brcmfmac: check_vif_up device is not ready : status (0)[ 848.243023] brcmfmac: brcmf_net_attach wlan0: Broadcom Dongle Host Driver[ 848.243451] brcmfmac: brcmf_cfg80211_get_tx_power Enter[ 848.243457] brcmfmac: check_vif_up device is not ready : status (0)[ 848.244931] brcmfmac 0001:01:00.0 wlP1p1s0: renamed from wlan0[ 848.299871] brcmfmac: brcmf_netdev_open Enter, bsscfgidx=0[ 848.329297] brcmfmac: brcmf_add_if Enter, bsscfgidx=0, ifidx=0[ 848.329309] brcmfmac: brcmf_add_if netdev:wlP1p1s0 ignore IF event[ 848.330436] brcmfmac: brcmf_config_dongle power save set to enabled[ 848.330709] brcmfmac: brcmf_dongle_roam Internal Roaming = On[ 848.331377] brcmfmac: brcmf_cfg80211_change_iface Enter, bsscfgidx=0, type=2[ 848.331712] brcmfmac: brcmf_cfg80211_change_iface IF Type = Infra[ 848.331718] brcmfmac: brcmf_cfg80211_change_iface Exit[ 848.332201] brcmfmac: brcmf_configure_arp_nd_offload successfully configured (1) ARP offload to 0x9[ 848.332481] brcmfmac: brcmf_configure_arp_nd_offload failed to configure (1) ND offload err = -52[ 848.333111] brcmfmac: brcmf_cfg80211_set_power_mgmt Enter[ 848.333115] brcmfmac: brcmf_cfg80211_set_power_mgmt power save enabled[ 848.333126] brcmfmac: _brcmf_set_multicast_list Enter, bsscfgidx=0[ 848.333546] brcmfmac: brcmf_cfg80211_set_power_mgmt Exit[ 848.334856] brcmfmac: brcmf_cfg80211_get_tx_power Enter[ 848.335189] brcmfmac: brcmf_cfg80211_get_tx_power Exit (0x7f 31)[ 848.337538] brcmfmac: brcmf_configure_arp_nd_offload successfully configured (1) ARP offload to 0x9[ 848.337845] brcmfmac: brcmf_configure_arp_nd_offload failed to configure (1) ND offload err = -52[ 848.341198] brcmfmac: brcmf_cfg80211_get_tx_power Enter[ 848.341497] brcmfmac: brcmf_cfg80211_get_tx_power Exit (0x7f 31)[ 848.341760] brcmfmac: brcmf_cfg80211_get_tx_power Enter[ 848.342053] brcmfmac: brcmf_cfg80211_get_tx_power Exit (0x7f 31)[ 848.342471] brcmfmac: brcmf_cfg80211_get_tx_power Enter[ 848.342767] brcmfmac: brcmf_cfg80211_get_tx_power Exit (0x7f 31)[ 848.342992] brcmfmac: brcmf_cfg80211_get_tx_power Enter[ 848.343274] brcmfmac: brcmf_cfg80211_get_tx_power Exit (0x7f 31)[ 848.343961] brcmfmac: brcmf_cfg80211_get_tx_power Enter[ 848.344241] brcmfmac: brcmf_cfg80211_get_tx_power Exit (0x7f 31)[ 848.366364] brcmfmac: brcmf_cfg80211_flush_pmksa Enter[ 848.366760] brcmfmac: brcmf_cfg80211_flush_pmksa Exit[ 848.399479] brcmfmac: brcmf_cfg80211_add_iface enter: p2p-dev-wlP1p1s type 10[ 848.399490] brcmfmac: brcmf_p2p_add_vif adding vif "p2p-dev-wlP1p1s" (type=10)[ 848.399495] brcmfmac: brcmf_alloc_vif allocating virtual interface (size=4680)[ 848.431211] brcmfmac: brcmf_add_if Enter, bsscfgidx=0, ifidx=0[ 848.431217] brcmfmac: brcmf_add_if netdev:wlP1p1s0 ignore IF event[ 848.432309] brcmfmac: brcmf_add_if Enter, bsscfgidx=2, ifidx=0[ 848.432313] brcmfmac: brcmf_add_if allocate non-netdev interface[ 848.432316] brcmfmac: brcmf_add_if ==== pid:2d, if:wl0 (12:68:38:c4:0e:35) created ===[ 848.432321] brcmfmac: brcmf_notify_vif_event Enter: action 1 flags 1 ifidx 0 bsscfgidx 2[ 848.432593] brcmfmac: brcmf_cfg80211_get_tx_power Enter[ 848.432596] brcmfmac: check_vif_up device is not ready : status (0)[ 848.432602] brcmfmac: brcmf_cfg80211_get_tx_power Enter[ 848.432603] brcmfmac: check_vif_up device is not ready : status (0)[ 848.437236] brcmfmac: brcmf_cfg80211_get_tx_power Enter[ 848.437242] brcmfmac: check_vif_up device is not ready : status (0)[ 848.437388] brcmfmac: brcmf_cfg80211_get_tx_power Enter[ 848.437390] brcmfmac: check_vif_up device is not ready : status (0)[ 848.437404] brcmfmac: brcmf_cfg80211_get_tx_power Enter[ 848.437405] brcmfmac: check_vif_up device is not ready : status (0)[ 848.437432] brcmfmac: brcmf_cfg80211_get_tx_power Enter[ 848.437433] brcmfmac: check_vif_up device is not ready : status (0)[ 848.437691] brcmfmac: brcmf_cfg80211_get_tx_power Enter[ 848.437693] brcmfmac: check_vif_up device is not ready : status (0)[ 848.437901] brcmfmac: brcmf_cfg80211_get_tx_power Enter[ 848.437903] brcmfmac: check_vif_up device is not ready : status (0)[ 848.437920] brcmfmac: brcmf_p2p_enable_discovery enter[ 848.438227] brcmfmac: brcmf_p2p_set_discover_state enter[ 848.459984] brcmfmac: brcmf_cfg80211_scan Enter[ 848.459995] brcmfmac: brcmf_vif_set_mgmt_ie bsscfgidx 0, pktflag : 0x10连接到接入点时记录 [ 972.072094] brcmfmac: brcmf_cfg80211_scan Enter[ 972.072131] brcmfmac: brcmf_vif_set_mgmt_ie bsscfgidx 0, pktflag : 0x10[ 972.101592] brcmfmac: brcmf_add_if Enter, bsscfgidx=0, ifidx=0[ 972.101624] brcmfmac: brcmf_add_if netdev:wlP1p1s0 ignore IF event[ 986.711096] brcmfmac: _brcmf_set_multicast_list Enter, bsscfgidx=0[ 986.713394] brcmfmac: brcmf_configure_arp_nd_offload successfully configured (1) ARP offload to 0x9[ 986.713762] brcmfmac: brcmf_configure_arp_nd_offload failed to configure (1) ND offload err = -52[ 986.715956] brcmfmac: _brcmf_set_multicast_list Enter, bsscfgidx=0[ 986.718117] brcmfmac: brcmf_configure_arp_nd_offload successfully configured (1) ARP offload to 0x9[ 986.718477] brcmfmac: brcmf_configure_arp_nd_offload failed to configure (1) ND offload err = -52[ 986.740837] brcmfmac: brcmf_cfg80211_scan Enter[ 986.740884] brcmfmac: brcmf_vif_set_mgmt_ie bsscfgidx 0, pktflag : 0x10[ 986.740901] brcmfmac: brcmf_parse_vndr_ies ** OUI 00 50 f2, type 0x04[ 986.740913] brcmfmac: brcmf_parse_vndr_ies ** OUI 50 6f 9a, type 0x09[ 986.740917] brcmfmac: brcmf_parse_vndr_ies ** OUI 50 6f 9a, type 0x16[ 986.740921] brcmfmac: brcmf_vif_set_mgmt_ie ADDED ID : 221, Len: 105, OUI:00 50 f2[ 986.740934] brcmfmac: brcmf_vif_set_mgmt_ie ADDED ID : 221, Len: 17, OUI:50 6f 9a[ 986.740937] brcmfmac: brcmf_vif_set_mgmt_ie ADDED ID : 221, Len: 7, OUI:50 6f 9a[ 986.770149] brcmfmac: brcmf_add_if Enter, bsscfgidx=0, ifidx=0[ 986.770166] brcmfmac: brcmf_add_if netdev:wlP1p1s0 ignore IF event[ 987.262824] brcmfmac: brcmf_cfg80211_connect Enter[ 987.263450] brcmfmac: brcmf_vif_set_mgmt_ie bsscfgidx 0, pktflag : 0x20[ 987.263469] brcmfmac: brcmf_cfg80211_connect Applied Vndr IEs for Assoc request[ 987.263476] brcmfmac: brcmf_cfg80211_connect ie (0000000059406f2f), ie_len (50)[ 987.270219] brcmfmac: brcmf_cfg80211_connect Exit[ 990.781122] brcmfmac: brcmf_notify_vif_event Enter: action 3 flags 0 ifidx 0 bsscfgidx 0[ 990.867386] brcmfmac: brcmf_pcie_handle_mb_data D2H_MB_DATA: 0x1000000b[ 990.867402] brcmfmac: brcmf_pcie_handle_mb_data D2H_MB_DATA: DEEP SLEEP REQ[ 990.867409] brcmfmac: brcmf_pcie_handle_mb_data D2H_MB_DATA: sent DEEP SLEEP ACK[ 990.867413] brcmfmac: brcmf_pcie_handle_mb_data D2H_MB_DATA: D3 ACK[ 990.867415] brcmfmac: brcmf_pcie_handle_mb_data D2H_MB_DATA: FW HALT[ 990.867429] ieee80211 phy2: brcmf_fw_crashed: Firmware has halted or crashed[ 991.468622] brcmfmac 0001:01:00.0: brcmf_pcie_bus_console_read: CONSOLE: 74, r11 1efccb, r12 b4[ 991.468661] brcmfmac 0001:01:00.0: brcmf_pcie_bus_console_read: CONSOLE: 002286.590[ 991.468780] brcmfmac 0001:01:00.0: brcmf_pcie_bus_console_read: CONSOLE: sp+0 0023fc38 0021ef3c 00218bb8 0023fc38[ 991.468926] brcmfmac 0001:01:00.0: brcmf_pcie_bus_console_read: CONSOLE: 002286.590 sp+10 00000000 00082f71 00000000 0023fc04[ 991.468933] brcmfmac 0001:01:00.0: brcmf_pcie_bus_console_read: CONSOLE:[ 991.469004] brcmfmac 0001:01:00.0: brcmf_pcie_bus_console_read: CONSOLE: 002286.590 sp+14 00082f71[ 991.469075] brcmfmac 0001:01:00.0: brcmf_pcie_bus_console_read: CONSOLE: 002286.590 sp+34 00001c3b[ 991.469146] brcmfmac 0001:01:00.0: brcmf_pcie_bus_console_read: CONSOLE: 002286.590 sp+54 0006ab95[ 991.469217] brcmfmac 0001:01:00.0: brcmf_pcie_bus_console_read: CONSOLE: 002286.590 sp+7c 001b119d[ 991.469288] brcmfmac 0001:01:00.0: brcmf_pcie_bus_console_read: CONSOLE: 002286.590 sp+d4 00001511[ 991.469359] brcmfmac 0001:01:00.0: brcmf_pcie_bus_console_read: CONSOLE: 002286.590 sp+f8 00001511[ 991.469432] brcmfmac 0001:01:00.0: brcmf_pcie_bus_console_read: CONSOLE: 002286.590 sp+11c 00184ff1[ 991.469506] brcmfmac 0001:01:00.0: brcmf_pcie_bus_console_read: CONSOLE: 002286.590 sp+12c 00184ff1[ 991.469580] brcmfmac 0001:01:00.0: brcmf_pcie_bus_console_read: CONSOLE: 002286.590 sp+15c 0016ddad[ 991.469654] brcmfmac 0001:01:00.0: brcmf_pcie_bus_console_read: CONSOLE: 002286.590 sp+160 0016ddcd[ 991.469727] brcmfmac 0001:01:00.0: brcmf_pcie_bus_console_read: CONSOLE: 002286.590 sp+174 0016504f[ 991.469801] brcmfmac 0001:01:00.0: brcmf_pcie_bus_console_read: CONSOLE: 002286.590 sp+184 0018702b[ 991.469875] brcmfmac 0001:01:00.0: brcmf_pcie_bus_console_read: CONSOLE: 002286.590 sp+1bc 001b1373[ 991.469948] brcmfmac 0001:01:00.0: brcmf_pcie_bus_console_read: CONSOLE: 002286.590 sp+214 001b1e17[ 991.470022] brcmfmac 0001:01:00.0: brcmf_pcie_bus_console_read: CONSOLE: 002286.590 sp+26c 00178903[ 991.470096] brcmfmac 0001:01:00.0: brcmf_pcie_bus_console_read: CONSOLE: 002286.590 sp+2b4 001b376d[ 991.470301] brcmfmac 0001:01:00.0: brcmf_pcie_bus_console_read: CONSOLE: 002286.590 RO region is overwritten. printf not allowed. called from 00184cf5[ 991.470506] brcmfmac 0001:01:00.0: brcmf_pcie_bus_console_read: CONSOLE: 002286.590 RO region is overwritten. printf not allowed. called from 00184d09[ 991.470508] brcmfmac: brcmf_detach Enter[ 991.483023] brcmfmac: brcmf_bus_change_state 1 -> 0[ 991.483030] brcmfmac: brcmf_remove_interface Enter, bsscfgidx=2, ifidx=0[ 991.483033] brcmfmac: brcmf_del_if Enter, bsscfgidx=2, ifidx=0[ 991.483036] brcmfmac: brcmf_p2p_ifp_removed P2P: device interface removed[ 991.483049] brcmfmac: brcmf_cfg80211_get_tx_power Enter[ 991.483061] ieee80211 phy2: brcmf_fil_cmd_data: bus is down. we have nothing to do.[ 991.483065] ieee80211 phy2: brcmf_cfg80211_get_tx_power: error (-5)[ 991.483067] brcmfmac: brcmf_cfg80211_get_tx_power Exit (0x0 -65536)[ 991.483121] brcmfmac: brcmf_remove_interface Enter, bsscfgidx=0, ifidx=0[ 991.483124] brcmfmac: brcmf_del_if Enter, bsscfgidx=0, ifidx=0[ 991.483125] brcmfmac: brcmf_netdev_stop Enter, bsscfgidx=0[ 991.483128] brcmfmac: brcmf_link_down Enter[ 991.483130] brcmfmac: brcmf_btcoex_set_mode DHCP session ends[ 991.483133] brcmfmac: brcmf_link_down Exit[ 991.999046] brcmfmac: brcmf_net_setcarrier Enter, bsscfgidx=0 carrier=0[ 991.999074] brcmfmac: brcmf_txflowblock_if enter: bsscfgidx=0 stop=0x0 reason=4 state=1[ 991.999203] brcmfmac: brcmf_cfg80211_disconnect Enter. Reason code = 3[ 991.999210] brcmfmac: check_vif_up device is not ready : status (0)[ 991.999301] brcmfmac: brcmf_netdev_stop Enter, bsscfgidx=0[ 991.999305] brcmfmac: check_vif_up device is not ready : status (0)[ 991.999307] brcmfmac: brcmf_net_setcarrier Enter, bsscfgidx=0 carrier=0[ 991.999309] brcmfmac: brcmf_txflowblock_if enter: bsscfgidx=0 stop=0x4 reason=4 state=1[ 992.000347] brcmfmac: brcmf_cfg80211_get_tx_power Enter[ 992.000353] brcmfmac: check_vif_up device is not ready : status (0)[ 992.023252] brcmfmac: brcmf_proto_detach Enter[ 992.023298] brcmfmac: brcmf_proto_msgbuf_detach Enter[ 992.025450] brcmfmac: brcmf_pno_detach enter[ 992.025466] brcmfmac: brcmf_btcoex_detach enter[ 992.025476] brcmfmac: brcmf_btcoex_boost_wifi attempted to restore not saved BTCOEX params[ 992.235099] brcmfmac: brcmf_fw_alloc_request: using cypress/cyfmac54591-pcie for chip BCM4355/13[ 992.235162] brcmfmac: brcmf_fw_get_firmwares enter: dev=0001:01:00.0[ 992.235354] brcmfmac 0001:01:00.0: Direct firmware load for cypress/cyfmac54591-pcie.nvidia,p3768-0000+p3767-0003.bin failed with error -2[ 992.235372] brcmfmac 0001:01:00.0: Falling back to sysfs fallback for: cypress/cyfmac54591-pcie.nvidia,p3768-0000+p3767-0003.bin[ 992.240077] brcmfmac: brcmf_fw_complete_request firmware cypress/cyfmac54591-pcie.bin found[ 992.240275] brcmfmac 0001:01:00.0: Direct firmware load for cypress/cyfmac54591-pcie.nvidia,p3768-0000+p3767-0003.txt failed with error -2[ 992.240282] brcmfmac 0001:01:00.0: Falling back to sysfs fallback for: cypress/cyfmac54591-pcie.nvidia,p3768-0000+p3767-0003.txt[ 992.245781] brcmfmac 0001:01:00.0: Direct firmware load for cypress/cyfmac54591-pcie.txt failed with error -2[ 992.245797] brcmfmac 0001:01:00.0: Falling back to sysfs fallback for: cypress/cyfmac54591-pcie.txt[ 992.249644] brcmfmac: brcmf_fw_complete_request firmware cypress/cyfmac54591-pcie.txt not found[ 992.249655] brcmfmac: brcmf_fw_request_nvram_done enter: dev=0001:01:00.0[ 992.250432] brcmfmac: brcmf_fw_request_nvram_done nvram 0000000000000000 len 0[ 992.251222] brcmfmac: brcmf_chip_get_raminfo RAM: base=0x160000 size=917504 (0xe0000) sr=0 (0x0)[ 992.313285] brcmfmac: brcmf_chip_set_active Enter[ 992.432284] brcmfmac: brcmf_attach Enter[ 992.432293] brcmfmac: brcmf_proto_attach Enter[ 992.433756] brcmfmac: brcmf_fweh_register event handler registered for PSM_WATCHDOG[ 992.433767] brcmfmac: brcmf_bus_started[ 992.433773] brcmfmac: brcmf_add_if Enter, bsscfgidx=0, ifidx=0[ 992.433781] brcmfmac: brcmf_add_if allocate netdev interface[ 992.433821] brcmfmac: brcmf_add_if ==== pid:d4f, if:wlan%d (00:00:00:00:00:00) created ===[ 992.433830] brcmfmac: brcmf_bus_change_state 0 -> 1[ 992.435543] brcmfmac: brcmf_c_process_clm_blob Enter[ 992.435558] brcmfmac: brcmf_fw_alloc_request: using cypress/cyfmac54591-pcie for chip BCM4355/13[ 992.444487] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4355/13 wl0: Oct 29 2024 19:34:53 version 13.35.369 (65bac01 CY) FWID 01-a64ef454[ 992.444781] brcmfmac: brcmf_c_preinit_dcmds CLM version = API: 12.2 Data: Cypress.CYW54591 Compiler: 1.39.1 ClmImport: 1.36.3 Customization: v1 200611 Creation: 2024-10-29 19:26:06[ 992.446772] brcmfmac: brcmf_feat_firmware_capabilities [ ap sta wme 802.11d 802.11h cac mbss dualband ampdu ampdu_tx ampdu_rx amsdurx amsdutx radio_pwrsave p2p proptxstatus mchan wds vht-prop-rates single-user-beamformer multi-user-beamformee single-user-beamformee dfrts lpas txpwrcache stbc-tx stbc-rx-1ss mp2p rsdb mfp wnm bsstrans txcap scanmac cptlv-4 pktfltr2 ve fbt fbtoverds fbt_adpt event_log txcap ifver sae_ext ap_pmksa ][ 992.446778] brcmfmac: brcmf_feat_firmware_capabilities enabling feature: MBSS[ 992.446782] brcmfmac: brcmf_feat_firmware_capabilities enabling feature: MCHAN[ 992.446784] brcmfmac: brcmf_feat_firmware_capabilities enabling feature: P2P[ 992.446799] brcmfmac: brcmf_feat_firmware_capabilities enabling feature: DOT11H[ 992.446804] brcmfmac: brcmf_feat_firmware_capabilities enabling feature: SAE[ 992.447341] brcmfmac: brcmf_feat_iovar_data_set GSCAN feature check failed: -23[ 992.447927] brcmfmac: brcmf_feat_iovar_int_get PNO feature check failed: -23[ 992.448144] brcmfmac: brcmf_feat_iovar_int_get enabling feature: WOWL[ 992.448574] brcmfmac: brcmf_feat_iovar_int_get enabling feature: RSDB[ 992.448883] brcmfmac: brcmf_feat_iovar_int_get TDLS feature check failed: -23[ 992.449118] brcmfmac: brcmf_feat_iovar_int_get enabling feature: MFP[ 992.449775] brcmfmac: brcmf_feat_iovar_int_get FWSUP feature check failed: -23[ 992.449779] brcmfmac: brcmf_alloc_vif allocating virtual interface (size=4680)[ 992.449795] brcmfmac: brcmf_fweh_register event handler registered for LINK[ 992.449798] brcmfmac: brcmf_fweh_register event handler registered for DEAUTH_IND[ 992.449799] brcmfmac: brcmf_fweh_register event handler registered for DEAUTH[ 992.449801] brcmfmac: brcmf_fweh_register event handler registered for DISASSOC_IND[ 992.449803] brcmfmac: brcmf_fweh_register event handler registered for ASSOC_IND[ 992.449804] brcmfmac: brcmf_fweh_register event handler registered for REASSOC_IND[ 992.449806] brcmfmac: brcmf_fweh_register event handler registered for ROAM[ 992.449807] brcmfmac: brcmf_fweh_register event handler registered for MIC_ERROR[ 992.449809] brcmfmac: brcmf_fweh_register event handler registered for SET_SSID[ 992.449811] brcmfmac: brcmf_fweh_register event handler registered for PFN_NET_FOUND[ 992.449813] brcmfmac: brcmf_fweh_register event handler registered for IF[ 992.449815] brcmfmac: brcmf_fweh_register event handler registered for P2P_PROBEREQ_MSG[ 992.449817] brcmfmac: brcmf_fweh_register event handler registered for P2P_DISC_LISTEN_COMPLETE[ 992.449819] brcmfmac: brcmf_fweh_register event handler registered for ACTION_FRAME_RX[ 992.449820] brcmfmac: brcmf_fweh_register event handler registered for ACTION_FRAME_COMPLETE[ 992.449822] brcmfmac: brcmf_fweh_register event handler registered for ACTION_FRAME_OFF_CHAN_COMPLETE[ 992.449824] brcmfmac: brcmf_fweh_register event handler registered for PSK_SUP[ 992.449825] brcmfmac: brcmf_fweh_register event handler registered for RSSI[ 992.449827] brcmfmac: brcmf_fweh_register event handler registered for ESCAN_RESULT[ 992.450185] brcmfmac: brcmf_cfg80211_attach Registering custom regulatory[ 992.452583] brcmfmac: brcmf_setup_wiphybands nmode=1, vhtmode=1, bw_cap=(1, 7)[ 992.453054] brcmfmac: brcmf_setup_wiphybands nchain=1[ 992.465275] brcmfmac: brcmf_btcoex_attach enter[ 992.465289] brcmfmac: brcmf_pno_attach enter[ 992.465540] brcmfmac: brcmf_net_attach Enter, bsscfgidx=0 mac=10:68:38:c4:0e:35[ 992.466917] brcmfmac: brcmf_cfg80211_get_tx_power Enter[ 992.466926] brcmfmac: check_vif_up device is not ready : status (0)[ 992.467810] brcmfmac: brcmf_net_attach wlan0: Broadcom Dongle Host Driver[ 992.468854] brcmfmac: brcmf_cfg80211_get_tx_power Enter[ 992.468858] brcmfmac: check_vif_up device is not ready : status (0)[ 992.470930] brcmfmac 0001:01:00.0 wlP1p1s0: renamed from wlan0[ 992.534340] brcmfmac: brcmf_netdev_open Enter, bsscfgidx=0[ 992.564325] brcmfmac: brcmf_add_if Enter, bsscfgidx=0, ifidx=0[ 992.564348] brcmfmac: brcmf_add_if netdev:wlP1p1s0 ignore IF event[ 992.565506] brcmfmac: brcmf_config_dongle power save set to enabled[ 992.565806] brcmfmac: brcmf_dongle_roam Internal Roaming = On[ 992.566571] brcmfmac: brcmf_cfg80211_change_iface Enter, bsscfgidx=0, type=2[ 992.566918] brcmfmac: brcmf_cfg80211_change_iface IF Type = Infra[ 992.566930] brcmfmac: brcmf_cfg80211_change_iface Exit[ 992.567468] brcmfmac: brcmf_configure_arp_nd_offload successfully configured (1) ARP offload to 0x9[ 992.567790] brcmfmac: brcmf_configure_arp_nd_offload failed to configure (1) ND offload err = -52[ 992.568731] brcmfmac: brcmf_cfg80211_set_power_mgmt Enter[ 992.568737] brcmfmac: brcmf_cfg80211_set_power_mgmt power save enabled[ 992.568757] brcmfmac: _brcmf_set_multicast_list Enter, bsscfgidx=0[ 992.569252] brcmfmac: brcmf_cfg80211_set_power_mgmt Exit[ 992.570680] brcmfmac: brcmf_cfg80211_get_tx_power Enter[ 992.571842] brcmfmac: brcmf_cfg80211_get_tx_power Exit (0x7f 31)[ 992.573309] brcmfmac: brcmf_configure_arp_nd_offload successfully configured (1) ARP offload to 0x9[ 992.573647] brcmfmac: brcmf_configure_arp_nd_offload failed to configure (1) ND offload err = -52[ 992.576107] brcmfmac: brcmf_cfg80211_get_tx_power Enter[ 992.576449] brcmfmac: brcmf_cfg80211_get_tx_power Exit (0x7f 31)[ 992.576798] brcmfmac: brcmf_cfg80211_get_tx_power Enter[ 992.577112] brcmfmac: brcmf_cfg80211_get_tx_power Exit (0x7f 31)[ 992.577690] brcmfmac: brcmf_cfg80211_get_tx_power Enter[ 992.577993] brcmfmac: brcmf_cfg80211_get_tx_power Exit (0x7f 31)[ 992.578237] brcmfmac: brcmf_cfg80211_get_tx_power Enter[ 992.578532] brcmfmac: brcmf_cfg80211_get_tx_power Exit (0x7f 31)[ 992.579647] brcmfmac: brcmf_cfg80211_get_tx_power Enter[ 992.579935] brcmfmac: brcmf_cfg80211_get_tx_power Exit (0x7f 31)[ 992.623887] brcmfmac: brcmf_cfg80211_flush_pmksa Enter[ 992.624150] brcmfmac: brcmf_cfg80211_flush_pmksa Exit[ 992.641982] brcmfmac: brcmf_cfg80211_add_iface enter: p2p-dev-wlP1p1s type 10[ 992.642007] brcmfmac: brcmf_p2p_add_vif adding vif "p2p-dev-wlP1p1s" (type=10)[ 992.642016] brcmfmac: brcmf_alloc_vif allocating virtual interface (size=4680)[ 992.674089] brcmfmac: brcmf_add_if Enter, bsscfgidx=0, ifidx=0[ 992.674100] brcmfmac: brcmf_add_if netdev:wlP1p1s0 ignore IF event[ 992.675552] brcmfmac: brcmf_add_if Enter, bsscfgidx=2, ifidx=0[ 992.675557] brcmfmac: brcmf_add_if allocate non-netdev interface[ 992.675560] brcmfmac: brcmf_add_if ==== pid:2d, if:wl0 (12:68:38:c4:0e:35) created ===[ 992.675565] brcmfmac: brcmf_notify_vif_event Enter: action 1 flags 1 ifidx 0 bsscfgidx 2[ 992.675849] brcmfmac: brcmf_cfg80211_get_tx_power Enter[ 992.675853] brcmfmac: check_vif_up device is not ready : status (0)[ 992.675862] brcmfmac: brcmf_cfg80211_get_tx_power Enter[ 992.675863] brcmfmac: check_vif_up device is not ready : status (0)[ 992.682870] brcmfmac: brcmf_cfg80211_get_tx_power Enter[ 992.682880] brcmfmac: check_vif_up device is not ready : status (0)[ 992.683146] brcmfmac: brcmf_cfg80211_get_tx_power Enter[ 992.683152] brcmfmac: check_vif_up device is not ready : status (0)[ 992.683182] brcmfmac: brcmf_cfg80211_get_tx_power Enter[ 992.683184] brcmfmac: check_vif_up device is not ready : status (0)[ 992.683231] brcmfmac: brcmf_cfg80211_get_tx_power Enter[ 992.683233] brcmfmac: check_vif_up device is not ready : status (0)[ 992.683710] brcmfmac: brcmf_cfg80211_get_tx_power Enter[ 992.683712] brcmfmac: check_vif_up device is not ready : status (0)[ 992.684041] brcmfmac: brcmf_cfg80211_get_tx_power Enter[ 992.684043] brcmfmac: check_vif_up device is not ready : status (0)[ 992.684076] brcmfmac: brcmf_p2p_enable_discovery enter[ 992.684419] brcmfmac: brcmf_p2p_set_discover_state enter[ 992.699272] brcmfmac: brcmf_cfg80211_scan Enter[ 992.699284] brcmfmac: brcmf_vif_set_mgmt_ie bsscfgidx 0, pktflag : 0x10[ 996.070467] brcmfmac: brcmf_cfg80211_scan Enter[ 996.070513] brcmfmac: brcmf_vif_set_mgmt_ie bsscfgidx 0, pktflag : 0x10[ 996.100125] brcmfmac: brcmf_add_if Enter, bsscfgidx=0, ifidx=0[ 996.100154] brcmfmac: brcmf_add_if netdev:wlP1p1s0 ignore IF event[ 1001.071112] brcmfmac: brcmf_cfg80211_scan Enter[ 1001.071155] brcmfmac: brcmf_vif_set_mgmt_ie bsscfgidx 0, pktflag : 0x10[ 1001.100310] brcmfmac: brcmf_add_if Enter, bsscfgidx=0, ifidx=0[ 1001.100348] brcmfmac: brcmf_add_if netdev:wlP1p1s0 ignore IF event需要一些帮助来解决这个问题。 |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
1482 浏览 0 评论
Wi-Fi 8:开启极高可靠性 (UHR) 连接的新纪元——2
1594 浏览 0 评论
5599 浏览 0 评论
你在使用WI-FI6模块PTR7002时遇到过哪些通信问题?欢迎分享解决方案!
10555 浏览 0 评论
12976 浏览 1 评论
浏览过的版块 |
/9
GMT+8, 2025-12-1 18:35 , Processed in 1.906054 second(s), Total 39, Slave 32 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
602
