电子发烧友论坛|
在使用STM32G474CBT6的HRtiM_Mater、HRTIM_TIMER_B和HRTIM_TIMER_D输出同步互补的四路输出时,关闭4路输出和三个定时器的计数后,再次开启时第一个周期的频率异常。
初始化HRTIM第一次开启时,变频控制第一个周期没有问题。 MX_HRTIM1_Init();//设置频率和变频控制第一个周期一致HAL_HRTIM_WaveformOutputStart(&hhrtim1, HRTIM_OUTPUT_TB2 + HRTIM_OUTPUT_TB1 + HRTIM_OUTPUT_TD1 + HRTIM_OUTPUT_TD2);HAL_HRTIM_WaveformCounterStart(&hhrtim1, HRTIM_TIMERID_MASTER + HRTIM_TIMERID_TIMER_B + HRTIM_TIMERID_TIMER_D);for(){//变频控制 增加 _period值__HAL_HRTIM_SETCOMPARE(&hhrtim1, HRTIM_TIMERINDEX_TIMER_B, HRTIM_COMPAREUNIT_1, _period>>1);__HAL_HRTIM_SETCOMPARE(&hhrtim1, HRTIM_TIMERINDEX_TIMER_D, HRTIM_COMPAREUNIT_1, _period>>1);__HAL_HRTIM_SETPERIOD(&hhrtim1, HRTIM_TIMERINDEX_MASTER, _period);__HAL_HRTIM_SETPERIOD(&hhrtim1, HRTIM_TIMERINDEX_TIMER_B, _period);__HAL_HRTIM_SETPERIOD(&hhrtim1, HRTIM_TIMERINDEX_TIMER_D, _period);if(ok)//变频完成后跳出{return}}当关闭输出后再次开启时出现异常 HAL_HRTIM_WaveformOutputStop(&hhrtim1, HRTIM_OUTPUT_TB2 + HRTIM_OUTPUT_TB1 + HRTIM_OUTPUT_TD1 + HRTIM_OUTPUT_TD2);//关闭输出HAL_HRTIM_WaveformCounterStop(&hhrtim1, HRTIM_TIMERID_MASTER + HRTIM_TIMERID_TIMER_B + HRTIM_TIMERID_TIMER_D);//关闭计数 __HAL_HRTIM_SETCOMPARE(&hhrtim1, HRTIM_TIMERINDEX_TIMER_B, HRTIM_COMPAREUNIT_1, first_period>>1);__HAL_HRTIM_SETCOMPARE(&hhrtim1, HRTIM_TIMERINDEX_TIMER_D, HRTIM_COMPAREUNIT_1, first_period>>1);__HAL_HRTIM_SETPERIOD(&hhrtim1, HRTIM_TIMERINDEX_MASTER, first_period);__HAL_HRTIM_SETPERIOD(&hhrtim1, HRTIM_TIMERINDEX_TIMER_B, first_period);__HAL_HRTIM_SETPERIOD(&hhrtim1, HRTIM_TIMERINDEX_TIMER_D, first_period);//初始化频率__HAL_HRTIM_SETCOUNTER(&hhrtim1, HRTIM_TIMERINDEX_MASTER, 0);__HAL_HRTIM_SETCOUNTER(&hhrtim1, HRTIM_TIMERINDEX_TIMER_B, 0);__HAL_HRTIM_SETCOUNTER(&hhrtim1, HRTIM_TIMERINDEX_TIMER_D, 0);//清0计数hhrtim1.Instance->sCommonRegs.CR2 |= HRTIM_CR2_MSWU;hhrtim1.Instance->sCommonRegs.CR2 |= HRTIM_CR2_TBSWU;hhrtim1.Instance->sCommonRegs.CR2 |= HRTIM_CR2_TDSWU;//猜测可能是预装载引起后增加额代码,触发更新事件//////////////完成关闭HAL_HRTIM_WaveformOutputStart(&hhrtim1, HRTIM_OUTPUT_TB2 + HRTIM_OUTPUT_TB1 + HRTIM_OUTPUT_TD1 + HRTIM_OUTPUT_TD2);HAL_HRTIM_WaveformCounterStart(&hhrtim1, HRTIM_TIMERID_MASTER + HRTIM_TIMERID_TIMER_B + HRTIM_TIMERID_TIMER_D);for(){//变频控制 增加 _period值__HAL_HRTIM_SETCOMPARE(&hhrtim1, HRTIM_TIMERINDEX_TIMER_B, HRTIM_COMPAREUNIT_1, _period>>1);__HAL_HRTIM_SETCOMPARE(&hhrtim1, HRTIM_TIMERINDEX_TIMER_D, HRTIM_COMPAREUNIT_1, _period>>1);__HAL_HRTIM_SETPERIOD(&hhrtim1, HRTIM_TIMERINDEX_MASTER, _period);__HAL_HRTIM_SETPERIOD(&hhrtim1, HRTIM_TIMERINDEX_TIMER_B, _period);__HAL_HRTIM_SETPERIOD(&hhrtim1, HRTIM_TIMERINDEX_TIMER_D, _period);if(ok)//变频完成后跳出{return}}////////////////再次开启频率是从高频往下降,再次开启时第一个周期的频率低了很多(周期变长)。 请问有什么办法解决嘛? |
1个回答
在STM32G474C474的HRTIM模块中,重新启动定时器时第一个周期频率异常的问题通常是由于计数器未复位导致的。以下是逐步解决方案:
总结:主要问题在于重新启动时定时器计数器未复位,导致第一个周期时长异常。通过软件复位计数器并确保配置更新,即可解决该问题。 |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1453 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1502 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3649 浏览 1 评论
3842 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2461 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
727浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
661浏览 5评论
710浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
941浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
745浏览 5评论
/9
GMT+8, 2025-12-1 22:46 , Processed in 0.475104 second(s), Total 43, Slave 36 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
7799
