电子发烧友论坛
1个回答
有可能是DeviceHandle没有成功打开。端口占用或者超出范围。
int HID_API_EXPORT HID_API_CALL hid_write(hid_device *dev, const unsigned char *data, size_t length) { DWORD bytes_written; BOOL res; OVERLAPPED ol; unsigned char *buf; memset(&ol, 0, sizeof(ol)); /* Make sure the right number of bytes are passed to WriteFile. Windows expects the number of bytes which are in the _longest_ report (plus one for the report number) bytes even if the data is a report which is shorter than that. Windows gives us this value in caps.OutputReportByteLength. If a user passes in fewer bytes than this, create a temporary buffer which is the proper size. */ if (length >= dev->output_report_length) { /* The user passed the right number of bytes. Use the buffer as-is. */ buf = (unsigned char *) data; } else { /* Create a temporary buffer and copy the user's data into it, padding the rest with zeros. */ buf = (unsigned char *) malloc(dev->output_report_length); memcpy(buf, data, length); memset(buf + length, 0, dev->output_report_length - length); length = dev->output_report_length; } res = WriteFile(dev->device_handle, buf, length, NULL, &ol); if (!res) { if (GetLastError() != ERROR_IO_PENDING) { /* WriteFile() failed. Return error. */ register_error(dev, "WriteFile"); bytes_written = -1; goto end_of_function; } } /* Wait here until the write is done. This makes hid_write() synchronous. */ res = GetOverlappedResult(dev->device_handle, &ol, &bytes_written, TRUE/*wait*/); if (!res) { /* The Write operation failed. */ register_error(dev, "WriteFile"); bytes_written = -1; goto end_of_function; } end_of_function: if (buf != data) free(buf); return bytes_written; } |
只有小组成员才能发言,加入小组>>
601 浏览 0 评论
1654 浏览 0 评论
2096 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1542 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1386 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1794浏览 29评论
2821浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1748浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1667浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1681浏览 13评论
/9
GMT+8, 2025-12-15 02:51 , Processed in 0.936041 second(s), Total 78, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
226
