电子发烧友论坛|
你好!我用TAS5805,使用的是384KHz,Hybrid Mode(测试这样配置,电流最小,发热最小)。在解除MUTE的时候会有一声类似爆音的声音,应该是功放内部做了处理,没有爆音那么响。 #define AP_MUTE_DEEP_SLEEP 0 #define AP_MUTE_SLEEP 1 #define AP_MUTE_HIZ 2 #define AP_MUTE_SOFT 3 #define AP_MUTE_MODE AP_MUTE_HIZ #define AP_FSW_768K 0 #define AP_FSW_384K 1 #define AP_FSW_480K 2 #define AP_FSW_576K 3 #define AP_DAMP_MODE_BD 0 #define AP_DAMP_MODE_1SPW 1 #define AP_DAMP_MODE_HYBRID 2 #define AP_FSW AP_FSW_384K #define AP_DAMP AP_DAMP_MODE_HYBRID #define AP_DEV_CTRL ((AP_FSW<<4) || AP_DAMP) void _EXT_HW_MUTE() {//测试结果 24V //384K +Hybrid Mode // soft Mute = 36mA // Hiz = 10mA // Sleep = 6mA // Deep Sleep = 0mA // return; puts("SPK muten"); if(b_ap_mute_flag == 0) { puts("SPK Hizn"); TAS5805_Write_Reg(TAS5805_ADDR,0x00, 0x00); TAS5805_Write_Reg(TAS5805_ADDR,0x7F, 0x00); TAS5805_Write_Reg(TAS5805_ADDR,0x00, 0x00); #if (AP_MUTE_MODE == AP_MUTE_SOFT) TAS5805_Write_Reg(TAS5805_ADDR,0x03, 0x08 | 0x03); //soft mute + Play #elif (AP_MUTE_MODE == AP_MUTE_HIZ) TAS5805_Write_Reg(TAS5805_ADDR,0x03, 0x02); //Hiz #elif (AP_MUTE_MODE == AP_MUTE_SLEEP) TAS5805_Write_Reg(TAS5805_ADDR,0x03, 0x02); //Hiz TAS5805_Write_Reg(TAS5805_ADDR,0x03, 0x01); //Hiz #elif (AP_MUTE_MODE == AP_MUTE_DEEP_SLEEP) TAS5805_Write_Reg(TAS5805_ADDR,0x03, 0x02); //Hiz TAS5805_Write_Reg(TAS5805_ADDR,0x03, 0x00); //Deep Sleep #endif // TAS5805_Write_Reg(TAS5805_ADDR,0x03, 0x00); //Deep Sleep TAS5805_Write_Reg(TAS5805_ADDR,0x78, 0x80); //Clrear analog fault IIC_Idle(); } b_ap_mute_flag = 1; } void _EXT_C_HW_MUTE() { // return; puts("SPK unmuten"); if(b_ap_mute_flag == 1) { //00 00 //3ms //7F 00 //4ms //00 00 //r 03 00 //00 00 //7F 00 //00 00 //03 02 //r 03 02 //03 03 //r 02 12 puts("SPK APn"); TAS5805_Write_Reg(TAS5805_ADDR,0x00, 0x00); TAS5805_Write_Reg(TAS5805_ADDR,0x7F, 0x00); TAS5805_Write_Reg(TAS5805_ADDR,0x00, 0x00); #if (AP_MUTE_MODE == AP_MUTE_SOFT) TAS5805_Write_Reg(TAS5805_ADDR,0x03, 0x03); //Play #elif (AP_MUTE_MODE == AP_MUTE_HIZ) TAS5805_Write_Reg(TAS5805_ADDR,0x03, 0x03); //Play #elif (AP_MUTE_MODE == AP_MUTE_SLEEP) TAS5805_Write_Reg(TAS5805_ADDR,0x03, 0x02); //Hiz delay_2ms(5); TAS5805_Write_Reg(TAS5805_ADDR,0x03, 0x03); //Play #elif (AP_MUTE_MODE == AP_MUTE_DEEP_SLEEP) TAS5805_Write_Reg(TAS5805_ADDR,0x03, 0x00); //deep sleep delay_2ms(5); TAS5805_Write_Reg(TAS5805_ADDR,0x02, 0x00); //BD Mode delay_2ms(5); TAS5805_Write_Reg(TAS5805_ADDR,0x03, 0x02); //Hiz delay_2ms(5); TAS5805_Write_Reg(TAS5805_ADDR,0x02, AP_DEV_CTRL); //384K / Hybrid Mode //384K +Hybrid 模式电流最低 // TAS5805_Write_Reg(TAS5805_ADDR,0x02, 0x00); //BD Mode //Hybrid Mode delay_2ms(5); // TAS5805_Write_Reg(TAS5805_ADDR,0x03, 0x03); //Play TAS5805_Write_Reg(TAS5805_ADDR,0x03, 0x03); //Play #endif // TAS5805_Write_Reg(TAS5805_ADDR,0x03, 0x00); //deep sleep // delay_2ms(5); // TAS5805_Write_Reg(TAS5805_ADDR,0x02, 0x00); //BD Mode // delay_2ms(5); // TAS5805_Write_Reg(TAS5805_ADDR,0x03, 0x02); //Hiz // delay_2ms(5); // TAS5805_Write_Reg(TAS5805_ADDR,0x02, 0x12); //384K / Hybrid Mode //384K +Hybrid 模式电流最低 // TAS5805_Write_Reg(TAS5805_ADDR,0x02, 0x00); //BD Mode //Hybrid Mode // delay_2ms(5); TAS5805_Write_Reg(TAS5805_ADDR,0x78, 0x80); //Clrear analog fault IIC_Idle(); } b_ap_mute_flag = 0; } |
2个回答
这个可以借鉴一下数据手册看看
您好!根据您的描述,您在使用TAS5805M芯片时遇到了在解除MUTE状态时产生杂音的问题。这可能是由于硬件或软件配置不当导致的。以下是一些建议,希望能帮助您解决问题:
1. 检查硬件连接:确保所有连接都正确无误,包括电源、地线和信号线。检查是否有短路或接触不良的情况。 2. 检查电源:确保电源电压稳定,且符合TAS5805M的规格要求。不稳定的电源可能导致杂音。 3. 检查滤波器:在信号线和电源线上添加滤波器,以减少噪声干扰。 4. 调整软件配置:尝试调整软件配置,以减少杂音。例如,您可以尝试以下方法: a. 在解除MUTE状态之前,先将音量逐渐降低,然后再解除MUTE状态。这样可以减少杂音的产生。 b. 在解除MUTE状态后,等待一段时间(例如10ms)再开始播放音频。这样可以给功放足够的时间稳定下来。 c. 尝试使用不同的MUTE模式,例如AP_MUTE_SOFT,看看是否能减少杂音。 5. 检查音频文件:确保音频文件没有问题,例如格式错误或损坏。 6. 检查驱动程序:确保您使用的驱动程序是最新版本,且与您的硬件兼容。 7. 考虑硬件故障:如果以上方法都无法解决问题,可能是硬件故障。您可以尝试更换另一块TAS5805M芯片,看看问题是否仍然存在。 希望这些建议能帮助您解决问题。如果问题仍然存在,请提供更多详细信息,以便我们更好地帮助您。 |
只有小组成员才能发言,加入小组>>
598 浏览 0 评论
1651 浏览 0 评论
2090 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1541 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1383 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1793浏览 29评论
2820浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1748浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1666浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1680浏览 13评论
/9
GMT+8, 2025-12-13 19:18 , Processed in 0.764920 second(s), Total 78, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
406
