目前我用esp32 idf v3.4的examples/periperals/sp_master/lcd例程,芯片引脚连接正确,代码中也修改为相应的引脚。我使用的是以st7789为控制芯片的液晶屏。在menuconfig->examples_configuration/LCD module type 选择 st7789V 编译烧录后,打印如下信息
ets Jun 8 2016 00:22:57rst:0x1 (POWERON_RESET),boot:0x12 (SPI_FAST_FLASH_BOOT)configsip: 0, SPIWP:0xeeclk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00mode:DIO, clock div:2load:0x3fff0030,len:4load:0x3fff0034,len:6916load:0x40078000,len:14336load:0x40080400,len:3672entry 0x40080678[0;32mI (28) boot: ESP-IDF v4.3-dev-2940-g6e776946d 2nd stage bootloader[0m[0;32mI (28) boot: compile time 11:01:01[0m[0;32mI (29) boot: chip revision: 1[0m[0;32mI (33) boot_comm: chip revision: 1, min. bootloader chip revision: 0[0m[0;32mI (40) boot.esp32: SPI Speed : 40MHz[0m[0;32mI (45) boot.esp32: SPI Mode : DIO[0m[0;32mI (49) boot.esp32: SPI Flash Size : 4MB[0m[0;32mI (54) boot: Enabling RNG early entropy source...[0m[0;32mI (59) boot: Partition Table:[0m[0;32mI (63) boot: ## Label Usage Type ST Offset Length[0m[0;32mI (70) boot: 0 nvs WiFi data 01 02 00009000 00006000[0m[0;32mI (77) boot: 1 phy_init RF data 01 01 0000f000 00001000[0m[0;32mI (85) boot: 2 factory factory app 00 00 00010000 00100000[0m[0;32mI (92) boot: End of partition table[0m[0;32mI (96) boot_comm: chip revision: 1, min. application chip revision: 0[0m[0;32mI (104) esp_image: segment 0: paddr=00010020 vaddr=3f400020 size=18c58h (101464) map[0m[0;32mI (148) esp_image: segment 1: paddr=00028c80 vaddr=3ffb0000 size=02a88h ( 10888) load[0m[0;32mI (152) esp_image: segment 2: paddr=0002b710 vaddr=40080000 size=00404h ( 1028) load[0m[0;32mI (154) esp_image: segment 3: paddr=0002bb1c vaddr=40080404 size=044fch ( 17660) load[0m[0;32mI (169) esp_image: segment 4: paddr=00030020 vaddr=400d0020 size=185a0h ( 99744) map[0m[0;32mI (206) esp_image: segment 5: paddr=000485c8 vaddr=40084900 size=07b84h ( 31620) load[0m[0;32mI (226) boot: Loaded app from partition at offset 0x10000[0m[0;32mI (226) boot: Disabling RNG early entropy source...[0m[0;32mI (237) cpu_start: Pro cpu up.[0m[0;32mI (237) cpu_start: Starting app cpu, entry point is 0x40081010[0m[0;32mI (0) cpu_start: App cpu up.[0m[0;32mI (252) cpu_start: Pro cpu start user code[0m[0;32mI (252) cpu_start: cpu freq: 160000000[0m[0;32mI (252) cpu_start: Application information:[0m[0;32mI (256) cpu_start: Project name: spi_master[0m[0;32mI (261) cpu_start: App version: v4.3-dev-2940-g6e776946d[0m[0;32mI (268) cpu_start: Compile time: Apr 22 2021 11:02:26[0m[0;32mI (274) cpu_start: ELF file SHA256: 07e622b42a06ba98...[0m[0;32mI (280) cpu_start: ESP-IDF: v4.3-dev-2940-g6e776946d[0m[0;32mI (287) heap_init: Initializing. RAM available for dynamic allocation:[0m[0;32mI (294) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM[0m[0;32mI (300) heap_init: At 3FFB3830 len 0002C7D0 (177 KiB): DRAM[0m[0;32mI (306) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM[0m[0;32mI (312) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM[0m[0;32mI (319) heap_init: At 4008C484 len 00013B7C (78 KiB): IRAM[0m[0;32mI (326) spi_flash: detected chip: generic[0m[0;32mI (330) spi_flash: flash io: dio[0m[0;32mI (335) cpu_start: Starting scheduler on PRO CPU.[0m[0;32mI (0) cpu_start: Starting scheduler on APP CPU.[0mLCD ID: 00000000ILI9341 detected.kconfig: force CONFIG_LCD_TYPE_ST7789V.LCD ST7789V initialization. 可以看到esp32读取到的芯片id是000000,说明应该是spi通信出问题了。我用STM32的开发板驱动同一块显示屏,显示屏可以正常显示,说明不是显示屏出问题,可能是idf例程的问题。各位有没有说明调试的方法? |
1个回答
在使用ESP32 SPI Master驱动IPS液晶屏时,如果遇到驱动失败的问题,可能有以下几个原因:
1. 硬件连接问题:请确保液晶屏的引脚连接正确,包括数据线、时钟线、片选线等。同时,检查电源线是否连接正确。 2. 引脚配置问题:在代码中,确保已经正确设置了SPI引脚和液晶屏的控制引脚。如果引脚配置错误,可能导致通信失败。 3. SPI通信速率问题:不同的液晶屏可能需要不同的SPI通信速率。请检查代码中设置的SPI速率是否与液晶屏的要求相匹配。 4. 初始化代码问题:请确保液晶屏的初始化代码是正确的。错误的初始化代码可能导致液晶屏无法正常工作。 5. 液晶屏型号问题:请确保您选择的液晶屏型号与代码中设置的型号相匹配。如果型号不匹配,可能导致驱动失败。 针对您的问题,可以尝试以下解决方法: 1. 检查硬件连接,确保所有引脚连接正确。 2. 检查代码中的引脚配置,确保与实际连接的引脚一致。 3. 调整SPI通信速率,尝试使用不同的速率设置。 4. 检查液晶屏的初始化代码,确保与液晶屏的数据手册中的推荐设置一致。 5. 确认液晶屏型号是否与代码中设置的型号一致。 6. 如果问题仍然存在,可以尝试查看ESP32的错误日志,以获取更多关于问题的信息。 7. 考虑升级ESP32的固件版本,以获取更好的兼容性和性能。 8. 如果可能,尝试使用其他示例代码或库来驱动液晶屏,以排除代码问题。 通过以上方法,您应该能够找到问题的原因并解决驱动失败的问题。 |
只有小组成员才能发言,加入小组>>
475浏览 6评论
399浏览 5评论
有没有办法在不使用混杂模式的情况下实现Wifi驱动程序接收缓冲区访问中断呢?
380浏览 5评论
385浏览 4评论
361浏览 4评论
GMT+8, 2024-10-1 21:14 , Processed in 0.612998 second(s), Total 47, Slave 41 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
