电子发烧友论坛|
目前我用esp32 idf v3.4的examples/periperals/sp_master/lcd例程,芯片引脚连接正确,代码中也修改为相应的引脚。我使用的是以st7789为控制芯片的液晶屏。在menuconfig->examples_configuration/LCD module type 选择 st7789V 编译烧录后,打印如下信息:
Code: Select all ets Jun 8 2016 00:22:57 rst:0x1 (POWERON_RESET),boot:0x12 (SPI_FAST_FLASH_BOOT) configsip: 0, SPIWP:0xee clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 mode:DIO, clock div:2 load:0x3fff0030,len:4 load:0x3fff0034,len:6916 load:0x40078000,len:14336 load:0x40080400,len:3672 entry 0x40080678 [0;32mI (28) boot: ESP-IDF v4.3-dev-2940-g6e776946d 2nd stage bootloader[0m [0;32mI (28) boot: compile time 11:01:01[0m [0;32mI (29) boot: chip revision: 1[0m [0;32mI (33) boot_comm: chip revision: 1, min. bootloader chip revision: 0[0m [0;32mI (40) boot.esp32: SPI Speed : 40MHz[0m [0;32mI (45) boot.esp32: SPI Mode : DIO[0m [0;32mI (49) boot.esp32: SPI Flash Size : 4MB[0m [0;32mI (54) boot: Enabling RNG early entropy source...[0m [0;32mI (59) boot: Partition Table:[0m [0;32mI (63) boot: ## Label Usage Type ST Offset Length[0m [0;32mI (70) boot: 0 nvs WiFi data 01 02 00009000 00006000[0m [0;32mI (77) boot: 1 phy_init RF data 01 01 0000f000 00001000[0m [0;32mI (85) boot: 2 factory factory app 00 00 00010000 00100000[0m [0;32mI (92) boot: End of partition table[0m [0;32mI (96) boot_comm: chip revision: 1, min. application chip revision: 0[0m [0;32mI (104) esp_image: segment 0: paddr=00010020 vaddr=3f400020 size=18c58h (101464) map[0m [0;32mI (148) esp_image: segment 1: paddr=00028c80 vaddr=3ffb0000 size=02a88h ( 10888) load[0m [0;32mI (152) esp_image: segment 2: paddr=0002b710 vaddr=40080000 size=00404h ( 1028) load[0m [0;32mI (154) esp_image: segment 3: paddr=0002bb1c vaddr=40080404 size=044fch ( 17660) load[0m [0;32mI (169) esp_image: segment 4: paddr=00030020 vaddr=400d0020 size=185a0h ( 99744) map[0m [0;32mI (206) esp_image: segment 5: paddr=000485c8 vaddr=40084900 size=07b84h ( 31620) load[0m [0;32mI (226) boot: Loaded app from partition at offset 0x10000[0m [0;32mI (226) boot: Disabling RNG early entropy source...[0m [0;32mI (237) cpu_start: Pro cpu up.[0m [0;32mI (237) cpu_start: Starting app cpu, entry point is 0x40081010[0m [0;32mI (0) cpu_start: App cpu up.[0m [0;32mI (252) cpu_start: Pro cpu start user code[0m [0;32mI (252) cpu_start: cpu freq: 160000000[0m [0;32mI (252) cpu_start: Application information:[0m [0;32mI (256) cpu_start: Project name: spi_master[0m [0;32mI (261) cpu_start: App version: v4.3-dev-2940-g6e776946d[0m [0;32mI (268) cpu_start: Compile time: Apr 22 2021 11:02:26[0m [0;32mI (274) cpu_start: ELF file SHA256: 07e622b42a06ba98...[0m [0;32mI (280) cpu_start: ESP-IDF: v4.3-dev-2940-g6e776946d[0m [0;32mI (287) heap_init: Initializing. RAM available for dynamic allocation:[0m [0;32mI (294) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM[0m [0;32mI (300) heap_init: At 3FFB3830 len 0002C7D0 (177 KiB): DRAM[0m [0;32mI (306) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM[0m [0;32mI (312) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM[0m [0;32mI (319) heap_init: At 4008C484 len 00013B7C (78 KiB): IRAM[0m [0;32mI (326) spi_flash: detected chip: generic[0m [0;32mI (330) spi_flash: flash io: dio[0m [0;32mI (335) cpu_start: Starting scheduler on PRO CPU.[0m [0;32mI (0) cpu_start: Starting scheduler on APP CPU.[0m LCD ID: 00000000 ILI9341 detected. kconfig: force CONFIG_LCD_TYPE_ST7789V. LCD ST7789V initialization. 可以看到esp32读取到的芯片id是000000,说明应该是spi通信出问题了。我用STM32的开发板驱动同一块显示屏,显示屏可以正常显示,说明不是显示屏出问题,可能是idf例程的问题。各位有没有说明调试的方法? |
只有小组成员才能发言,加入小组>>
467 浏览 0 评论
984 浏览 0 评论
1706 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1361 浏览 1 评论
1251 浏览 1 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1286浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
943浏览 3评论
2377浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2565浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1071浏览 2评论
/9
GMT+8, 2025-12-12 00:08 , Processed in 0.764322 second(s), Total 69, Slave 52 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
794
