电子发烧友论坛|
我在使用mqtt在接受处理后发布消息时,mqtt接受消息不定时的出现接受发布有延时的情况、mqtt断开重连,有时会出现wifi:bcn_timout,ap_probe_send_start,WiFi也会有断开的情况,这是wifi断开时的logCode: Select all
I (710643) wifi:bcn_timout,ap_probe_send_startW (715733) TRANSPORT_BASE: Poll timeout or error, errno=Connection already in progress, fd=54, timeout_ms=10000E (715733) MQTT_CLIENT: Writing didn't complete in specified timeout: errno=119I (715733) USER_MQTT: MQTT_EVENT_ERRORI (715743) USER_MQTT: Last errno string (Success)E (715743) MQTT_CLIENT: Error to resend dataI (715753) USER_MQTT: MQTT_EVENT_DISCONNECTEDE (715753) MQTT_CLIENT: Client has startedW (725783) TRANSPORT_BASE: Poll timeout or error, errno=Connection already in progress, fd=-1, timeout_ms=10000E (725783) MQTT_CLIENT: Writing didn't complete in specified timeout: errno=119I (725783) USER_MQTT: MQTT_EVENT_ERRORI (725793) USER_MQTT: Last errno string (Success)E (725793) MQTT_CLIENT: Error sending pingE (725803) MQTT_CLIENT: Can't send ping, disconnectedI (725803) USER_MQTT: MQTT_EVENT_DISCONNECTEDE (725813) MQTT_CLIENT: Client has startedI (727373) wifi:bcn_timout,ap_probe_send_startI (735823) USER_MQTT: Other event id:7I (736893) wifi:bcn_timout,ap_probe_send_startI (739393) wifi:ap_probe_send over, resett wifi status to disassocI (739393) wifi:state: run -> init (c800)I (739393) wifi:pm stop, total sleep time: 16178413 us / 735831852 usW (739393) wifi:idxI (739403) wifi:new:<1,0>, old:<1,0>, ap:<255,255>, sta:<1,0>, prof:1E (739413) TRANSPORT_BASE: poll_read select error 113, errno = Software caused connection abort, fd = 54I (739413) wifi station: retry to connect to the APE (739413) MQTT_CLIENT: mqtt_message_receive: transport_read() error: errno=119I (739433) USER_MQTT: MQTT_EVENT_ERRORE (739433) USER_MQTT: Last error captured as transport's socket errno: 0x71I (739443) USER_MQTT: Last errno string (Software caused connection abort)E (739453) MQTT_CLIENT: esp_mqtt_connect: mqtt_message_receive() returned -1E (739453) MQTT_CLIENT: MQTT connect failedfree heap size: 187676 bytesI (739463) USER_MQTT: MQTT_EVENT_DISCONNECTEDE (739473) MQTT_CLIENT: Client has startedI (740073) wifi:new:<6,0>, old:<1,0>, ap:<255,255>, sta:<6,0>, prof:1I (740073) wifi:state: init -> auth (b0)I (740093) wifi:state: auth -> assoc (0)I (740133) wifi:state: assoc -> run (10)I (740283) wifi:connected with ICkey-GC-Tmp, aid = 1, channel 6, BW20, bssid = f0:5c:19:84:d2:82I (740283) wifi:security: WPA2-PSK, phy: bgn, rssi: -79I (740383) wifi:pm start, type: 1I (740383) wifi:AP's beacon interval = 102400 us, DTIM period = 1W (740453) wifi:idx:0 (ifx:0, f0:5c:19:84:d2:82), tid:0, ssn:2, winSize:64W (740703) wifi:idx:1 (ifx:0, f0:5c:19:84:d2:82), tid:7, ssn:0, winSize:64I (741693) esp_netif_handlers: sta ip: 10.8.85.154, mask: 255.255.255.0, gw: 10.8.85.254I (741693) wifi station: got ip:10.8.85.154I (749483) USER_MQTT: Other event id:7I (749633) USER_MQTT: MQTT_EVENT_CONNECTEDI (749633) USER_MQTT: sent subscribe successful, msg_id=65052I (749673) USER_MQTT: MQTT_EVENT_SUBSCRIBED, msg_id=12091I (749683) USER_MQTT: sent publish successful, msg_id=3348I (749703) USER_MQTT: MQTT_EVENT_SUBSCRIBED, msg_id=65052I (749703) USER_MQTT: sent publish successful, msg_id=522I (749733) USER_MQTT: MQTT_EVENT_PUBLISHED, msg_id=3348I (749753) USER_MQTT: MQTT_EVENT_PUBLISHED, msg_id=522 请问这是什么问题导致的呢 |
1个回答
根据您提供的信息,您的ESP32-WROOM-32E设备在使用MQTT协议时出现了异常断开和延时问题。以下是可能导致这些问题的一些原因:
1. 网络不稳定:如果您的WiFi网络不稳定,可能会导致设备与MQTT服务器之间的连接断开。这可能是由于信号弱、干扰或其他网络问题。 2. MQTT服务器问题:如果MQTT服务器本身存在问题,例如负载过高或配置不当,也可能导致连接不稳定。 3. 代码问题:在您的代码中,可能存在一些逻辑错误或资源管理问题,导致MQTT连接不稳定。例如,发送消息时可能没有正确处理超时或重试机制。 4. 设备硬件问题:ESP32-WROOM-32E设备本身可能存在硬件问题,例如电源不稳定或内存泄漏,导致设备在运行过程中出现问题。 5. 软件版本问题:您使用的ESP32-WROOM-32E固件或MQTT库可能存在已知的bug或兼容性问题,导致连接不稳定。 为了解决这些问题,您可以尝试以下方法: 1. 检查您的WiFi网络,确保信号强度和稳定性。 2. 检查MQTT服务器的配置和性能,确保其正常运行。 3. 审查您的代码,确保正确处理了MQTT连接、消息发送和超时等问题。 4. 更新您的ESP32-WROOM-32E固件和MQTT库,以确保使用的是最新版本。 5. 如果可能,尝试使用其他MQTT库或协议,以排除特定库的问题。 |
只有小组成员才能发言,加入小组>>
448 浏览 0 评论
971 浏览 0 评论
1695 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1349 浏览 1 评论
1246 浏览 1 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1272浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
936浏览 3评论
2370浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2556浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1064浏览 2评论
/9
GMT+8, 2025-12-9 02:26 , Processed in 0.661775 second(s), Total 77, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
427
