电子发烧友论坛|
我在使用mqtt在接受处理后发布消息时,mqtt接受消息不定时的出现接受发布有延时的情况、mqtt断开重连,有时会出现wifi:bcn_timout,ap_probe_send_start,WiFi也会有断开的情况,这是wifi断开时的log
Code: Select all I (710643) wifi:bcn_timout,ap_probe_send_start W (715733) TRANSPORT_BASE: Poll timeout or error, errno=Connection already in progress, fd=54, timeout_ms=10000 E (715733) MQTT_CLIENT: Writing didn't complete in specified timeout: errno=119 I (715733) USER_MQTT: MQTT_EVENT_ERROR I (715743) USER_MQTT: Last errno string (Success) E (715743) MQTT_CLIENT: Error to resend data I (715753) USER_MQTT: MQTT_EVENT_DISCONNECTED E (715753) MQTT_CLIENT: Client has started W (725783) TRANSPORT_BASE: Poll timeout or error, errno=Connection already in progress, fd=-1, timeout_ms=10000 E (725783) MQTT_CLIENT: Writing didn't complete in specified timeout: errno=119 I (725783) USER_MQTT: MQTT_EVENT_ERROR I (725793) USER_MQTT: Last errno string (Success) E (725793) MQTT_CLIENT: Error sending ping E (725803) MQTT_CLIENT: Can't send ping, disconnected I (725803) USER_MQTT: MQTT_EVENT_DISCONNECTED E (725813) MQTT_CLIENT: Client has started I (727373) wifi:bcn_timout,ap_probe_send_start I (735823) USER_MQTT: Other event id:7 I (736893) wifi:bcn_timout,ap_probe_send_start I (739393) wifi:ap_probe_send over, resett wifi status to disassoc I (739393) wifi:state: run -> init (c800) I (739393) wifi:pm stop, total sleep time: 16178413 us / 735831852 us W (739393) wifi: I (739403) wifi:new:<1,0>, old:<1,0>, ap:<255,255>, sta:<1,0>, prof:1 E (739413) TRANSPORT_BASE: poll_read select error 113, errno = Software caused connection abort, fd = 54 I (739413) wifi station: retry to connect to the AP E (739413) MQTT_CLIENT: mqtt_message_receive: transport_read() error: errno=119 I (739433) USER_MQTT: MQTT_EVENT_ERROR E (739433) USER_MQTT: Last error captured as transport's socket errno: 0x71 I (739443) USER_MQTT: Last errno string (Software caused connection abort) E (739453) MQTT_CLIENT: esp_mqtt_connect: mqtt_message_receive() returned -1 E (739453) MQTT_CLIENT: MQTT connect failed free heap size: 187676 bytes I (739463) USER_MQTT: MQTT_EVENT_DISCONNECTED E (739473) MQTT_CLIENT: Client has started I (740073) wifi:new:<6,0>, old:<1,0>, ap:<255,255>, sta:<6,0>, prof:1 I (740073) wifi:state: init -> auth (b0) I (740093) wifi:state: auth -> assoc (0) I (740133) wifi:state: assoc -> run (10) I (740283) wifi:connected with ICkey-GC-Tmp, aid = 1, channel 6, BW20, bssid = f0:5c:19:84:d2:82 I (740283) wifi:security: WPA2-PSK, phy: bgn, rssi: -79 I (740383) wifi:pm start, type: 1 I (740383) wifi:AP's beacon interval = 102400 us, DTIM period = 1 W (740453) wifi: W (740703) wifi: I (741693) esp_netif_handlers: sta ip: 10.8.85.154, mask: 255.255.255.0, gw: 10.8.85.254 I (741693) wifi station: got ip:10.8.85.154 I (749483) USER_MQTT: Other event id:7 I (749633) USER_MQTT: MQTT_EVENT_CONNECTED I (749633) USER_MQTT: sent subscribe successful, msg_id=65052 I (749673) USER_MQTT: MQTT_EVENT_SUBSCRIBED, msg_id=12091 I (749683) USER_MQTT: sent publish successful, msg_id=3348 I (749703) USER_MQTT: MQTT_EVENT_SUBSCRIBED, msg_id=65052 I (749703) USER_MQTT: sent publish successful, msg_id=522 I (749733) USER_MQTT: MQTT_EVENT_PUBLISHED, msg_id=3348 I (749753) USER_MQTT: MQTT_EVENT_PUBLISHED, msg_id=522 请问这是什么问题导致的呢 |
只有小组成员才能发言,加入小组>>
945 浏览 0 评论
1672 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1330 浏览 1 评论
1233 浏览 1 评论
5021 浏览 2 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1253浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
927浏览 3评论
2338浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2527浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1052浏览 2评论
/9
GMT+8, 2025-12-2 10:00 , Processed in 0.690282 second(s), Total 71, Slave 54 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
4322
