1、 MCU 正在运行,我使用 miniprog3 和 Auto Flash Utility 擦除闪存,但无法连接目标。
2、日志如下: PS C:Program Files (x86)infineonAuto Flash Utility 1.3bin>.openocd.exe -s ./scripts -f interface/kitprog3.cfg -c"transport select swd" -f target/traveo2_8m_b0.cfg -c"targets; shutdown" Open On-Chip Debugger 0.11.0+dev-1.3.0.1958 (2022-02-14-10:58) Licensed under GNU GPL v2 错误报告请阅读 http://openocd.org/doc/doxygen/bugs.html 适配器速度:2000 kHz 适配卡 srst 延迟:25 适配卡 srst 脉宽:25 ** 启用自动获取功能,使用"设置 ENABLE_ACQUIRE 0" 禁用 cortex_m reset_config sysresetreq TargetName Type Endian TapName State -- ------------------ ---------- ------ ------------------ ------------ 0* traveo2_8m。cpu.cm0 cortex_m little traveo2_8m.cpu unknown 1 traveo2_8m.cpu.cm70 cortex_m little traveo2_8m.cpu unknown 2 traveo2_8m.cpu.cm71 cortex_m little traveo2_8m.cpu.cm71 cortex_m little traveo2_8m.cpu unknown 调用关机命令 PS C:Program Files (x86)infineonAuto Flash Utility 1.3bin>.openocd.exe -s ./scripts -f interface/kitprog3.cfg -c"transport select swd" -f target/traveo2_8m_b0.cfg -c"init; reset init; flash erase_sector 0 0 last; shutdown" Open On-Chip Debugger 0.11.0+dev-1.3.0.1958 (2022-02-14-10:58) Licensed under GNU GPL v2 错误报告请阅读 http://openocd.org/doc/doxygen/bugs.html adapter speed: 2000 kHz adapter srst delay: 25 adapter srst pulse_width: 25 ** Auto-acquire enabled, use"set ENABLE_ACQUIRE 0" to disable cortex_m reset_config sysresetreq Info : Using CMSIS-DAPv2 interface with VID:PID=0x04b4:0xf151, serial=1B1D0B1D03201400 Info : CMSIS-DAP:支持 SWD 信息:CMSIS-DAP:支持 JTAG Info : CMSIS-DAP:支持原子命令 信息:CMSIS-DAP:FW 版本 = 2.0.0 信息:CMSIS-DAP:Interface Initialised (SWD) Info : SWCLK/TCK = 1 SWDIO/TMS = 1 TDI = 0 TDO = 0 nTRST = 0 nRESET = 1 Info : CMSIS-DAP:接口就绪 Info : KitProg3: FW version: 2.40.1241 Info : KitProg3: Pipelined transfers enabled Info : KitProg3: Asynchronous USB transfers enabled Info : VTarget = 3.284 V Info : kitprog3: acquiring the device (mode: reset)... Error: kitprog3: failed to acquire the device Info : clock speed 2000 kHz Error:Error: Error connecting DP: cannot read IDR Error:Error: Error connecting DP: cannot read IDR Error:Error: Error connecting DP: cannot read IDR Error:DAP "traveo2_8m.cpu 初始化失败(检查连接、电源、传输、DAP 是否启用等) Info : traveo2_8m.dap: 关闭调试域电源...... 错误:连接 DP 出错:无法读取 IDR Error:连接 DP 出错:无法读取 IDR 警告 :调试域关机失败 3、您能帮我们提出一些建议吗? 非常感谢 |
1个回答
以下是一些建议和可能的原因:
1. 确保您的设备已正确连接到计算机,并且驱动程序已安装。检查设备管理器以确认设备是否被识别。 2. 检查您的miniprog3和Auto Flash Utility软件版本是否与您的目标设备兼容。如果不兼容,请尝试更新软件。 3. 确保您的目标设备(CYT4BF8)处于正确的电源状态。某些设备在运行时可能无法连接,您可能需要将其置于复位或停止状态。 4. 检查您的连接线和接口是否完好无损,以确保信号传输正常。 5. 根据您提供的日志,Open On-Chip Debugger (OpenOCD) 正在运行。请确保您的脚本文件(如interface/kitprog3.cfg和target/traveo2_8m_b0.cfg)是正确的,并且与您的设备兼容。 6. 如果问题仍然存在,您可以尝试在OpenOCD命令行中添加一些调试选项,例如: - `-d2`:增加调试级别,以便在日志中显示更多详细信息。 - `-c "adapter_khz 1000"`:设置适配器时钟频率,以确保与您的设备兼容。 |
只有小组成员才能发言,加入小组>>
请教个XMC1404调试串口接收时为什么一直无法接收数据的问题
1242 浏览 0 评论
BLDC桥驱动的两端都会并联很大的电容和一个小一点的电容,这个电容是必须的吗?
7318 浏览 3 评论
TLE9879_BLDC电机启动需要用手拨一下才能转动,怎么解决?
8069 浏览 2 评论
4649 浏览 9 评论
请问TLE5012B_E1000 启动后为什么位置不能正确获取
4306 浏览 9 评论
7319浏览 3评论
1038浏览 2评论
912浏览 2评论
1025浏览 2评论
8071浏览 2评论
/9
GMT+8, 2025-12-14 09:33 , Processed in 0.726370 second(s), Total 77, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1548
