电子发烧友论坛|
我希望将 AN78175 的安全软件程序库集成到我正在开发的 PSoC5LP 项目中,该项目需要对 RAM/闪存/CPU 进行更密集的自测试。 我的问题是在尝试组装 SelfTest_CPU_s.s 时出现的。 装配源文件。 出于某种原因,它似乎无法识别表示注释的分号字符?
以下是该文件的完整内容: ;-------------------------------------------------------------------------------; FILENAME: SelfTest_CPU.s; Version 1.0;; DESCRIPtiON:; Assembly routines for RealView compiler.;;-------------------------------------------------------------------------------; Copyright 2010-2012, Cypress Semiconductor Corporation. All rights reserved.; You may use this file only in accordance with the license, terms, conditions, ; disclaimers, and limitations in the end user license agreement accompanying ; the software package with which this file was provided.;------------------------------------------------------------------------------- AREA |.text|,CODE THUMB;-------------------------------------------------------------------------------; Function Name: CPU_PSoC_5_Asm;-------------------------------------------------------------------------------; Summary:; Tests all ARM M3 CPU registers except PC.;; Parameters:; None;; Return:; void.;;-------------------------------------------------------------------------------; void CPU_PSoC_5_Asm(void)CPU_PSoC_5_Asm FUNCTION EXPORT CPU_PSoC_5_Asm PUSH {R1-R12, LR} MOV R0, #0xAAAAAAAA CMP R0, #0xAAAAAAAA BNE.W test_asm_fail MOV R0, #0x55555555 CMP R0, #0x55555555 BNE.W test_asm_fail MOV R1, #0xAAAAAAAA CMP R1, #0xAAAAAAAA BNE.W test_asm_fail MOV R1, #0x55555555 CMP R1, #0x55555555 BNE.W test_asm_fail MOV R2, #0xAAAAAAAA CMP R2, #0xAAAAAAAA BNE.W test_asm_fail MOV R2, #0x55555555 CMP R2, #0x55555555 BNE.W test_asm_fail MOV R3, #0xAAAAAAAA CMP R3, #0xAAAAAAAA BNE test_asm_fail MOV R3, #0x55555555 CMP R3, #0x55555555 BNE test_asm_fail MOV R4, #0xAAAAAAAA CMP R4, #0xAAAAAAAA BNE test_asm_fail MOV R4, #0x55555555 CMP R4, #0x55555555 BNE test_asm_fail MOV R5, #0xAAAAAAAA CMP R5, #0xAAAAAAAA BNE test_asm_fail MOV R5, #0x55555555 CMP R5, #0x55555555 BNE test_asm_fail MOV R6, #0xAAAAAAAA CMP R6, #0xAAAAAAAA BNE test_asm_fail MOV R6, #0x55555555 CMP R6, #0x55555555 BNE test_asm_fail MOV R7, #0xAAAAAAAA CMP R7, #0xAAAAAAAA BNE test_asm_fail MOV R7, #0x55555555 CMP R7, #0x55555555 BNE test_asm_fail MOV R8, #0xAAAAAAAA CMP R8, #0xAAAAAAAA BNE test_asm_fail MOV R8, #0x55555555 CMP R8, #0x55555555 BNE test_asm_fail MOV R9, #0xAAAAAAAA CMP R9, #0xAAAAAAAA BNE test_asm_fail MOV R9, #0x55555555 CMP R9, #0x55555555 BNE test_asm_fail MOV R10, #0xAAAAAAAA CMP R10, #0xAAAAAAAA BNE test_asm_fail MOV R10, #0x55555555 CMP R10, #0x55555555 BNE test_asm_fail MOV R11, #0xAAAAAAAA CMP R11, #0xAAAAAAAA BNE test_asm_fail MOV R11, #0x55555555 CMP R11, #0x55555555 BNE test_asm_fail MOV R12, #0xAAAAAAAA CMP R12, #0xAAAAAAAA BNE test_asm_fail MOV R12, #0x55555555 CMP R12, #0x55555555 BNE test_asm_fail MOV LR, #0xAAAAAAAA CMP LR, #0xAAAAAAAA BNE test_asm_fail MOV LR, #0x55555555 CMP LR, #0x55555555 BNE test_asm_fail ; Test SP register ; Note: SP ignores writes to the lower two bits, ; so they are intentionally set to 0 ; Save SP to R0 MOV R0, SP ; Load SP with 0xAAAAAAA8 LDR R1, =0xAAAAAAA8 MOV SP, R1 CMP SP, R1 ; Restore SP and return failure IT NE MOVNE SP, R0 BNE test_asm_fail ; Load SP with #0x55555554 LDR R1, =0x55555554 MOV SP, R1 CMP SP, R1 IT NE MOVNE SP, R0 BNE test_asm_fail MOV SP, R0 ; Return success MOV R0, #0 POP {R1-R12, LR} BX LR ; Return failure test_asm_fail MOV R0, #0x00000001 POP {R1-R12, LR} BX LR ENDFUNC END;[] END OF FILE 我知道这个代码已经很旧了(好像是 2012 年的)。 是否存在某些不兼容性? 我注意到它在顶部注释块中提到了"RealView Compiler" 。 这可能是某个不再使用的传统编译器/汇编器吗? 无论如何,ARM GNU GCC 是否不将分号视为注释? 我是否应该删除这个源文件,然后使用写在 SelfTest_CPU_asm.c 中的 CPU_PSoC_Asm() 函数? 文件? 我相信,它所做的事情本质上是一样的: __attribute__((naked)) uint8 CPU_PSoC_Asm(void) /* declaration of function if PSoC 5 GCC compiler */ { /* Disable global interrupts */ CyGlobalIntDisable; __ASM volatile ( " PUSH {R1-R12, LR} nt" CPU_REGISTER_TEST("R0") #if (ERROR_IN_CPU_REGISTERS) CPU_REGISTER_TEST_ERROR("R1") #else CPU_REGISTER_TEST("R1") #endif CPU_REGISTER_TEST("R2") CPU_REGISTER_TEST("R3") CPU_REGISTER_TEST("R4") CPU_REGISTER_TEST("R5") CPU_REGISTER_TEST("R6") CPU_REGISTER_TEST("R7") CPU_REGISTER_TEST("R8") CPU_REGISTER_TEST("R9") CPU_REGISTER_TEST("R10") CPU_REGISTER_TEST("R11") CPU_REGISTER_TEST("R12") CPU_REGISTER_TEST("LR") /* Test SP register */ /* Note: SP ignores writes to the lower two bits, so they are intentionally set to 0 */ /* Save SP to R0 */ " MOV R0, SP nt" /* Load SP with 0xAAAAAAA8 */ " LDR R1, =0xAAAAAAA8 nt" " MOV SP, R1 nt" " CMP SP, R1 nt" /* Restore SP and return failure */ " IT NE nt" " MOVNE SP, R0 nt" " BNE __test_asm_fail nt" /* Load SP with 0x55555554 */ " LDR R1, =0x55555554 nt" " MOV SP, R1 nt" " CMP SP, R1 nt" " IT NE nt" " MOVNE SP, R0 nt" " BNE __test_asm_fail nt" " MOV SP, R0 nt" /* Return success */ " MOV R0, #0 nt" " POP {R1-R12, LR} nt" " BX LR nt" /* Return failure */ "__test_asm_fail: nt" " MOV R0, 0x00000001 nt" " POP {R1-R12, LR} nt" " BX LR nt"); /* Enable global interrupts */ CyGlobalIntEnable; /* end of assembler code for PSoC 5 */ } 我注意到 CyGlobalIntDisable/CyGlobalIntEnable 也会出错:",不支持裸函数中的非 ASM 语句" 。 是否可以分别用" CPSID i nt" 和" CPSIE i nt" 来代替? 我使用的是 PSoC Creator 4.3,编译器是 ARM GCC 5.4-2016-q2-update。 |
1个回答
要将ASM集成到PSoC 5LP项目中并解决SelfTest_CPU_s.s文件中的注释问题,请按照以下步骤操作:
1. 首先,确保您已经安装了PSoC Creator IDE,这是开发PSoC 5LP项目所需的集成开发环境。 2. 创建一个新的PSoC 5LP项目或打开一个现有的项目。 3. 在PSoC Creator IDE中,导航到“Project”菜单,然后选择“New”->“File”来创建一个新的ASM文件。将SelfTest_CPU_s.s文件的内容复制到新创建的ASM文件中。 4. 解决注释问题:在ASM文件中,分号(;)通常用于单行注释。但是,从您提供的文件内容来看,分号前面有一个空格,这可能导致汇编器无法识别注释。请确保在每个注释行的开头,分号前面没有空格。例如,将以下内容: `;-------------------------------------------------------------------------------------------;` 更改为: `;-------------------------------------------------------------------------------` 5. 保存修改后的ASM文件。 6. 在PSoC Creator IDE中,将新创建的ASM文件添加到项目中。右键单击项目名称,选择“Add Existing Item”,然后浏览并选择修改后的ASM文件。 7. 在PSoC Creator IDE中,打开项目的“Build”设置。在“Build”选项卡中,确保选中了“Include Assembler Files in Build”选项。这将确保在构建项目时包含ASM文件。 8. 现在,您可以开始将AN78175的安全软件程序库集成到您的PSoC 5LP项目中。根据AN78175文档和示例代码,将所需的库文件和函数集成到您的项目中。 9. 在集成过程中,您可能需要对SelfTest_CPU_s.s文件进行一些修改,以适应您的特定需求。确保在进行这些修改时,遵循正确的ASM语法和注释规则。 10. 构建并测试您的PSoC 5LP项目,确保所有集成的组件正常工作。 通过遵循这些步骤,您应该能够成功地将ASM集成到PSoC 5LP项目中,并解决SelfTest_CPU_s.s文件中的注释问题。 |
只有小组成员才能发言,加入小组>>
请教个XMC1404调试串口接收时为什么一直无法接收数据的问题
1218 浏览 0 评论
BLDC桥驱动的两端都会并联很大的电容和一个小一点的电容,这个电容是必须的吗?
7294 浏览 3 评论
TLE9879_BLDC电机启动需要用手拨一下才能转动,怎么解决?
8045 浏览 2 评论
4634 浏览 9 评论
请问TLE5012B_E1000 启动后为什么位置不能正确获取
4292 浏览 9 评论
7294浏览 3评论
1021浏览 2评论
897浏览 2评论
1005浏览 2评论
8045浏览 2评论
/9
GMT+8, 2025-12-2 02:57 , Processed in 0.830622 second(s), Total 75, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1651
