电子发烧友论坛|
#include "pwm_output.h"
void tiM3_PWM_Init(void) { TIM3_GPIO_Config(); TIM3_Mode_Config(); } static void TIM3_GPIO_Config() { GPIO_InitTypeDef GPIO_InitStructure; RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOB,ENABLE); RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3,ENABLE); GPIO_InitStructure.GPIO_Mode =GPIO_Mode_AF_PP; GPIO_InitStructure.GPIO_Pin =GPIO_Pin_6|GPIO_Pin_7; GPIO_InitStructure.GPIO_Speed =GPIO_Speed_50MHz; GPIO_Init(GPIOA, GPIO_InitStructure); GPIO_InitStructure.GPIO_Pin =GPIO_Pin_0|GPIO_Pin_1; GPIO_Init(GPIOB, GPIO_InitStructure); } static void TIM3_Mode_Config() { TIM_TimeBaseInitTypeDef TIM_TimeBaseInitStructure; TIM_OCInitTypeDef TIM_OCInitStructure; u16 CCR1_Val=750; u16 CCR2_Val=500; u16 CCR3_Val=250; u16 CCR4_Val=100; TIM_DeInit(TIM3); TIM_TimeBaseInitStructure.TIM_ClockDivision =TIM_CKD_DIV1; TIM_TimeBaseInitStructure.TIM_CounterMode =TIM_CounterMode_Up; TIM_TimeBaseInitStructure.TIM_Period =999; TIM_TimeBaseInitStructure.TIM_Prescaler =0; TIM_TimeBaseInit(TIM3, TIM_TimeBaseInitStructure); TIM_OCInitStructure.TIM_OCMode =TIM_OCMode_PWM1; TIM_OCInitStructure.TIM_OCPolarity =TIM_OCPolarity_High; TIM_OCInitStructure.TIM_OutputState =TIM_OutputState_Enable; TIM_OCInitStructure.TIM_Pulse =CCR1_Val; TIM_OC1Init(TIM3, TIM_OCInitStructure); TIM_OC1PreloadConfig(TIM3,TIM_OCPreload_Enable); TIM_OCInitStructure.TIM_OutputState =TIM_OutputState_Enable; TIM_OCInitStructure.TIM_Pulse =CCR2_Val; TIM_OC2Init(TIM3, TIM_OCInitStructure); TIM_OC2PreloadConfig(TIM3,TIM_OCPreload_Enable); TIM_OCInitStructure.TIM_OutputState =TIM_OutputState_Enable; TIM_OCInitStructure.TIM_Pulse =CCR3_Val; TIM_OC3Init(TIM3, TIM_OCInitStructure); TIM_OC3PreloadConfig(TIM3,TIM_OCPreload_Enable); TIM_OCInitStructure.TIM_OutputState =TIM_OutputState_Enable; TIM_OCInitStructure.TIM_Pulse =CCR4_Val; TIM_OC4Init(TIM3, TIM_OCInitStructure); TIM_OC4PreloadConfig(TIM3,TIM_OCPreload_Enable); TIM_Cmd(TIM3,ENABLE); } |
1个回答
根据您提供的代码片段,我将逐步分析可能导致STM32定时器3的PWM无输出的原因。
1. 首先,您已经包含了一个头文件 "pwm_output.h",这个文件应该包含与PWM输出相关的宏定义、函数声明等。请确保这个文件中的内容是正确的。 2. 在 `TIM3_PWM_Init()` 函数中,您调用了 `TIM3_GPIO_Config()` 和 `TIM3_Mode_Config()` 两个函数。请确保这两个函数的实现是正确的。 3. 在 `TIM3_GPIO_Config()` 函数中,您已经正确地开启了GPIOA和GPIOB的时钟以及TIM3的时钟。 4. 接下来,您配置了GPIO的模式为 `GPIO_Mode_AF_PP`(复用推挽输出),并设置了GPIO_Pin_6和GPIO_Pin_7。这里看起来是正确的。 5. 代码片段在 `GPIO_InitTypeDef GPIO_InitStructure;` 后被截断了。请确保您已经正确地初始化了 `GPIO_InitStructure` 结构体,并且在最后调用了 `GPIO_Init(GPIOA, &GPIO_InitStructure);`(假设您使用的是GPIOA端口)。 6. 请检查 `TIM3_Mode_Config()` 函数的实现,确保您已经正确地配置了TIM3的工作模式、时钟源、分频、占空比等参数。 7. 如果以上步骤都正确无误,但仍然没有输出,请检查硬件连接,确保GPIO_Pin_6和GPIO_Pin_7与PWM负载正确连接。 8. 使用示波器或逻辑分析仪检查GPIO_Pin_6和GPIO_Pin_7的波形,以确保PWM信号确实被生成。 9. 如果问题仍然存在,请检查STM32的固件库(如HAL库或Standard Peripheral Library)是否正确安装和配置。 10. 最后,检查您的开发环境(如Keil MDK、STM32CubeIDE等)是否正确配置,确保编译和链接过程没有问题。 通过以上步骤,您应该能够找到导致STM32定时器3的PWM无输出的原因,并进行相应的修复。 |
只有小组成员才能发言,加入小组>>
调试STM32H750的FMC总线读写PSRAM遇到的问题求解?
4168 浏览 1 评论
X-NUCLEO-IHM08M1板文档中输出电流为15Arms,15Arms是怎么得出来的呢?
3246 浏览 1 评论
2776 浏览 2 评论
STM32F030F4 HSI时钟温度测试过不去是怎么回事?
2206 浏览 2 评论
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
15067 浏览 2 评论
STM32仿真器是选择ST-LINK还是选择J-LINK?各有什么优势啊?
3134浏览 4评论
stm32f4下spi+dma读取数据不对是什么原因导致的?
1923浏览 3评论
STM32F0_TIM2输出pwm2后OLED变暗或者系统重启是怎么回事?
2092浏览 3评论
2003浏览 3评论
stm32cubemx生成mdk-arm v4项目文件无法打开是什么原因导致的?
2200浏览 3评论
/9
GMT+8, 2025-12-8 09:33 , Processed in 0.818641 second(s), Total 77, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1728
