电子发烧友论坛|
void main(void)
{ /* Infinite loop */ CLK_LSICmd(ENABLE);//使能LSI CLK_SYSCLKSourceConfig(CLK_SYSCLKSource_LSI);//RTC时钟源LSI,1分频=38K while (CLK_GetFlagStatus(CLK_FLAG_LSIRDY) == RESET);//等待LSI就绪 CLK_PeripheralClockConfig(CLK_Peripheral_I2C1, ENABLE); I2C_DeInit(I2C1); I2C_Init(I2C1, 4000, 0x51,I2C_Mode_I2C, I2C_DutyCycle_2,I2C_Ack_Enable, I2C_AcknowledgedAddress_7bit); /* Enable Error Interrupt*/ I2C_ITConfig(I2C1, (I2C_IT_TypeDef)(I2C_IT_ERR | I2C_IT_EVT | I2C_IT_BUF), ENABLE); USART_DeInit(USART1); CLK_PeripheralClockConfig (CLK_Peripheral_USART1,ENABLE);//开启USART时钟 USART_Init(USART1,9600,USART_WordLength_8b,USART_StopBits_1,USART_Parity_No,(USART_Mode_TypeDef)USART_Mode_Tx|USART_Mode_Rx);//设置USART参数9600,8N1,接收/发送 USART_Cmd (USART1,ENABLE); enableInterrupts();//使能中断 while (1) { } } INTERRUPT_HANDLER(I2C1_SPI2_IRQHandler,29) { /* In order to detect unexpected events during development, it is recommended to set a breakpoint on the following instruction. */ u8 temp = 0; if (I2C1->SR1 0x02)//地址已经匹配(读SR1,SR3清除该位) { I2C_GetITStatus(I2C1,I2C_IT_ADDR); temp = I2C1->SR3 0x07; USART1_SendStr("匹配地址n"); } else if ((I2C1->SR1 0x84) (I2C1->SR3 0x04))//数据字节传送完 { I2C_GetITStatus(I2C1,I2C_IT_BTF); temp = 0xA0; //假设这里发送0xA5 I2C1->DR = temp; I2C_GenerateSTOP(I2C1,ENABLE); USART1_SendStr("数据发完 等待发送n"); } else if ((I2C1->SR1 0x40) (0 == (I2C1->SR3 0x04)))//接收时数据寄存器 { temp = I2C1->DR; //读取数据寄存器 USART_SendData8(USART1,temp); USART1_SendStr("数据发完 等待读取n"); } else if (I2C1->SR1 0x10)//检测到停止位 { I2C1->CR2 = I2C1->CR2;//清除停止位 I2C_GenerateSTOP(I2C1,ENABLE); USART1_SendStr("检测到停止位n"); } //错误处理 if (I2C1->SR2 0x01)//总线错误 { I2C1->SR2 = ~0x01;//清零 USART1_SendStr("总线错误n"); } else if(I2C1->SR2 0x02)//仲裁失败 { I2C1->SR2 = ~0x02;//清零 USART1_SendStr("仲裁失败n"); } else if(I2C1->SR2 0x04)//应答失败 { I2C1->SR2 = ~0x04;//清零 USART1_SendStr("应答失败n"); } else if(I2C1->SR2 0x08)//上溢、下溢 { I2C1->SR2 = ~0x08;//清零 USART1_SendStr("上溢下溢n"); } USART1_SendStr("中断结束n"); return; } |
1个回答
从你提供的代码来看,你正在尝试使用STM8L051微控制器作为I2C从机,但是主机一直收到的是0xff。这个问题可能有以下几个原因:
1. I2C总线冲突:请确保I2C总线上没有其他设备与你的STM8L051从机发生冲突。检查其他设备的地址和引脚连接。 2. I2C初始化参数错误:检查I2C初始化函数中的参数是否正确。例如,你正在使用4000作为I2C时钟频率,但是STM8L051的最大I2C时钟频率为1MHz。请确保你的时钟频率在允许的范围内。 3. I2C通信模式错误:你正在使用I2C_Mode_I2C作为通信模式,这是正确的。但是,请确保主机也使用相同的通信模式。 4. I2C从机地址错误:你正在使用0x51作为从机地址,确保这个地址没有与其他设备冲突,并且主机正在使用正确的地址进行通信。 5. 从机响应错误:请检查你的从机是否正确地响应了主机的读取请求。在I2C通信中,从机需要向主机发送数据。确保你的从机代码中包含了发送数据的部分。 6. 硬件连接问题:检查I2C1的SDA和SCL引脚是否正确连接到主机的相应引脚上,并且没有短路或断路。 7. 主机问题:确保主机的I2C配置和通信正确。主机需要正确地发送读取请求,并且正确地解析从机发送的数据。 为了解决这个问题,你可以尝试以下步骤: 1. 检查I2C总线是否有冲突,并确保所有设备的地址不冲突。 2. 检查I2C初始化参数,确保时钟频率和从机地址正确。 3. 确保从机代码中包含了发送数据的部分,并正确响应主机的读取请求。 4. 检查硬件连接,确保I2C1的SDA和SCL引脚正确连接。 5. 检查主机的I2C配置和通信,确保正确发送读取请求并解析从机数据。 希望这些建议能帮助你解决问题。如果问题仍然存在,请提供更多的代码和信息,以便进一步分析。 |
只有小组成员才能发言,加入小组>>
调试STM32H750的FMC总线读写PSRAM遇到的问题求解?
4178 浏览 1 评论
X-NUCLEO-IHM08M1板文档中输出电流为15Arms,15Arms是怎么得出来的呢?
3251 浏览 1 评论
2781 浏览 2 评论
STM32F030F4 HSI时钟温度测试过不去是怎么回事?
2210 浏览 2 评论
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
15077 浏览 2 评论
STM32仿真器是选择ST-LINK还是选择J-LINK?各有什么优势啊?
3136浏览 4评论
stm32f4下spi+dma读取数据不对是什么原因导致的?
1927浏览 3评论
STM32F0_TIM2输出pwm2后OLED变暗或者系统重启是怎么回事?
2094浏览 3评论
2006浏览 3评论
stm32cubemx生成mdk-arm v4项目文件无法打开是什么原因导致的?
2201浏览 3评论
/9
GMT+8, 2025-12-9 09:49 , Processed in 0.553863 second(s), Total 42, Slave 35 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
456
