电子发烧友论坛|
在STM8的标准库中做了选择,STM8S003,
/* #define STM8S208 */ /*!< STM8S High density devices with CAN */ /* #define STM8S207 */ /*!< STM8S High density devices without CAN */ /* #define STM8S007 */ /*!< STM8S Value Line High density devices */ /* #define STM8AF52Ax */ /*!< STM8A High density devices with CAN */ /* #define STM8AF62Ax */ /*!< STM8A High density devices without CAN */ /* #define STM8S105 */ /*!< STM8S Medium density devices */ /* #define STM8S005 */ /*!< STM8S Value Line Medium density devices */ /* #define STM8AF626x */ /*!< STM8A Medium density devices */ /* #define STM8AF622x */ /*!< STM8A Low density devices */ /* #define STM8S103 */ /*!< STM8S Low density devices */ #define STM8S003 /*!< STM8S Value Line Low density devices */ /* #define STM8S903 */ /*!< STM8S Low density devices */ 编译出现两个错误, Error[Pe513]: a value of type "uint8_t *" cannot be assigned to an entity of type "uint32_t *" D:work声眼项目软件声眼程序3LibrariesSTM8S_StdPeriph_Driversrcstm8s_flash.c 624 Error[Pe1578]: case label value has already appeared in this switch at line 180 D:work声眼项目软件声眼程序3LibrariesSTM8S_StdPeriph_Driversrcstm8s_itc.c 184 Error[Pe1578]: case label value has already appeared in this switch at line 307 D:work声眼项目软件声眼程序3LibrariesSTM8S_StdPeriph_Driversrcstm8s_itc.c 312 请问谁遇到过这类问题,怎么解决的,谢谢 |
1个回答
Error[Pe513]是指针类型不一致,一个是"uint8_t *",另一个是"uint32_t *";
Error[Pe1578]是case值冲突,同一个switch中出现了两个相同的case值,看一下 180和184行,是否相同。 |
只有小组成员才能发言,加入小组>>
调试STM32H750的FMC总线读写PSRAM遇到的问题求解?
4138 浏览 1 评论
X-NUCLEO-IHM08M1板文档中输出电流为15Arms,15Arms是怎么得出来的呢?
3228 浏览 1 评论
2752 浏览 2 评论
STM32F030F4 HSI时钟温度测试过不去是怎么回事?
2181 浏览 2 评论
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
14980 浏览 2 评论
STM32仿真器是选择ST-LINK还是选择J-LINK?各有什么优势啊?
3086浏览 4评论
stm32f4下spi+dma读取数据不对是什么原因导致的?
1896浏览 3评论
STM32F0_TIM2输出pwm2后OLED变暗或者系统重启是怎么回事?
2066浏览 3评论
1979浏览 3评论
stm32cubemx生成mdk-arm v4项目文件无法打开是什么原因导致的?
2168浏览 3评论
/9
GMT+8, 2025-12-2 07:20 , Processed in 0.672609 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3367
