目前自己做的板子是,STM32f103c8t6。
现在的问题是想用外部HSE来产生72Mhz时钟,但是HSE的RDY比特一直都是0。 下面是程序代码,请问大家?问题出在哪里? 板子上用的是8Mhz的无源晶振。两个电容都是接的22P, 电容之间没有接电阻 void SystemInit (void) { /* Reset the RCC clock configuration to the default reset state(for debug purpose) */ /* Set HSION bit */ RCC->CR |= (uint32_t)0x00000001; /* Reset SW, HPRE, PPRE1, PPRE2, ADCPRE and MCO bits */ #ifndef STM32F10X_CL RCC->CFGR = (uint32_t)0xF8FF0000; #else RCC->CFGR = (uint32_t)0xF0FF0000; #endif /* STM32F10X_CL */ /* Reset HSEON, CSSON and PLLON bits */ RCC->CR = (uint32_t)0xFEF6FFFF; /* Reset HSEBYP bit */ RCC->CR = (uint32_t)0xFFFBFFFF; /* Reset PLLSRC, PLLXTPRE, PLLMUL and USBPRE/OTGFSPRE bits */ RCC->CFGR = (uint32_t)0xFF80FFFF; #ifdef STM32F10X_CL /* Reset PLL2ON and PLL3ON bits */ RCC->CR = (uint32_t)0xEBFFFFFF; /* Disable all interrupts and clear pending bits */ RCC->CIR = 0x00FF0000; /* Reset CFGR2 register */ RCC->CFGR2 = 0x00000000; #elif defined (STM32F10X_LD_VL) || defined (STM32F10X_MD_VL) || (defined STM32F10X_HD_VL) /* Disable all interrupts and clear pending bits */ RCC->CIR = 0x009F0000; /* Reset CFGR2 register */ RCC->CFGR2 = 0x00000000; #else /* Disable all interrupts and clear pending bits */ RCC->CIR = 0x009F0000; #endif /* STM32F10X_CL */ #if defined (STM32F10X_HD) || (defined STM32F10X_XL) || (defined STM32F10X_HD_VL) #ifdef DATA_IN_ExtSRAM SystemInit_ExtMemCtl(); #endif /* DATA_IN_ExtSRAM */ #endif /* Configure the System clock frequency, HCLK, PCLK2 and PCLK1 prescalers */ /* Configure the Flash Latency cycles and enable prefetch buffer */ SetSysClock(); #ifdef VECT_TAB_SRAM SCB->VTOR = SRAM_BASE | VECT_TAB_OFFSET; /* Vector Table Relocation in Internal SRAM. */ #else SCB->VTOR = FLASH_BASE | VECT_TAB_OFFSET; /* Vector Table Relocation in Internal FLASH. */ #endif } ------------------------------------------------------------ static void SetSysClock(void) { #ifdef SYSCLK_FREQ_HSE SetSysClockToHSE(); #elif defined SYSCLK_FREQ_24MHz SetSysClockTo24(); #elif defined SYSCLK_FREQ_36MHz SetSysClockTo36(); #elif defined SYSCLK_FREQ_48MHz SetSysClockTo48(); #elif defined SYSCLK_FREQ_56MHz SetSysClockTo56(); #elif defined SYSCLK_FREQ_72MHz SetSysClockTo72();//执行到这里 #endif } ----------------------------------------------------------- static void SetSysClockTo72(void) { __IO uint32_t StartUpCounter = 0, HSEStatus = 0; /* SYSCLK, HCLK, PCLK2 and PCLK1 configuration ---------------------------*/ /* Enable HSE */ RCC->CR |= ((uint32_t)RCC_CR_HSEON); /* Wait till HSE is ready and if Time out is reached exit */ do { HSEStatus = RCC->CR RCC_CR_HSERDY; StartUpCounter++; } while((HSEStatus == 0) (StartUpCounter != HSE_STARTUP_TIMEOUT)); if ((RCC->CR RCC_CR_HSERDY) != RESET) { HSEStatus = (uint32_t)0x01; } else { HSEStatus = (uint32_t)0x00; } if (HSEStatus == (uint32_t)0x01) { /* Enable Prefetch Buffer */ FLASH->ACR |= FLASH_ACR_PRFTBE; /* Flash 2 wait state */ FLASH->ACR = (uint32_t)((uint32_t)~FLASH_ACR_LATENCY); FLASH->ACR |= (uint32_t)FLASH_ACR_LATENCY_2; /* HCLK = SYSCLK */ RCC->CFGR |= (uint32_t)RCC_CFGR_HPRE_DIV1; /* PCLK2 = HCLK */ RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE2_DIV1; /* PCLK1 = HCLK */ RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE1_DIV2; #ifdef STM32F10X_CL /* Configure PLLs ------------------------------------------------------*/ /* PLL2 configuration: PLL2CLK = (HSE / 5) * 8 = 40 MHz */ /* PREDIV1 configuration: PREDIV1CLK = PLL2 / 5 = 8 MHz */ RCC->CFGR2 = (uint32_t)~(RCC_CFGR2_PREDIV2 | RCC_CFGR2_PLL2MUL | RCC_CFGR2_PREDIV1 | RCC_CFGR2_PREDIV1SRC); RCC->CFGR2 |= (uint32_t)(RCC_CFGR2_PREDIV2_DIV5 | RCC_CFGR2_PLL2MUL8 | RCC_CFGR2_PREDIV1SRC_PLL2 | RCC_CFGR2_PREDIV1_DIV5); /* Enable PLL2 */ RCC->CR |= RCC_CR_PLL2ON; /* Wait till PLL2 is ready */ while((RCC->CR RCC_CR_PLL2RDY) == 0) { } /* PLL configuration: PLLCLK = PREDIV1 * 9 = 72 MHz */ RCC->CFGR = (uint32_t)~(RCC_CFGR_PLLXTPRE | RCC_CFGR_PLLSRC | RCC_CFGR_PLLMULL); RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLXTPRE_PREDIV1 | RCC_CFGR_PLLSRC_PREDIV1 | RCC_CFGR_PLLMULL9); #else /* PLL configuration: PLLCLK = HSE * 9 = 72 MHz */ RCC->CFGR = (uint32_t)((uint32_t)~(RCC_CFGR_PLLSRC | RCC_CFGR_PLLXTPRE | RCC_CFGR_PLLMULL)); RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_HSE | RCC_CFGR_PLLMULL9); #endif /* STM32F10X_CL */ /* Enable PLL */ RCC->CR |= RCC_CR_PLLON; /* Wait till PLL is ready */ while((RCC->CR RCC_CR_PLLRDY) == 0) { } /* Select PLL as system clock source */ RCC->CFGR = (uint32_t)((uint32_t)~(RCC_CFGR_SW)); RCC->CFGR |= (uint32_t)RCC_CFGR_SW_PLL; /* Wait till PLL is used as system clock source */ while ((RCC->CFGR (uint32_t)RCC_CFGR_SWS) != (uint32_t)0x08) { } } else { /* If HSE fails to start-up, the application will have wrong clock configuration. User can add here some code to deal with this error */ } } |
1个回答
从您提供的代码来看,使用HSE(外部时钟)来产生72MHz时钟的问题可能出在以下几个地方:
1. 晶振的频率设置:您提到使用的是8MHz的无源晶振。请确保在初始化RCC之前,将HSEBYP位(bit 17)清零,以使外部时钟源正常工作,即 RCC->CR &= ~(1<<17)。 2. 等待外部时钟稳定:在启动外部时钟后,根据芯片的规格,需要一定的时间等待外部时钟稳定。为了避免进一步的问题,可以在启动外部时钟后增加适当的延迟,比如几百个毫秒等。 3. 使用外部时钟作为系统时钟:请确保在RCC中正确配置SYSCFGR寄存器,将外部时钟源(HSE)作为系统时钟。相关的代码可能如下: RCC->CR |= RCC_CR_HSEON; // 开启外部时钟 while(!(RCC->CR & RCC_CR_HSERDY)); // 等待外部时钟就绪 // 配置系统时钟源(HSE) RCC->CFGR |= RCC_CFGR_SW_0; // 外部时钟作为系统时钟 while((RCC->CFGR & RCC_CFGR_SWS) != RCC_CFGR_SWS_0); // 等待系统时钟切换完成 // 设置APB1和APB2时钟分频系数等 请在代码中进行适当更改,并确保按照规格手册的要求正确配置并初始化外部时钟。 4. 检查引脚连接:请确保将晶振连接到正确的引脚(OSC_IN和OSC_OUT)。 如果上述步骤都没能解决问题,那么可能有其他硬件问题,比如连接错误,电源不稳定等。建议再次检查电路连接,引脚状态,以及输入电压等。 另外,建议参考STM32官方提供的例程和用户手册,以获取更多关于使用外部时钟的细节信息。 |
只有小组成员才能发言,加入小组>>
调试STM32H750的FMC总线读写PSRAM遇到的问题求解?
4168 浏览 1 评论
X-NUCLEO-IHM08M1板文档中输出电流为15Arms,15Arms是怎么得出来的呢?
3246 浏览 1 评论
2776 浏览 2 评论
STM32F030F4 HSI时钟温度测试过不去是怎么回事?
2206 浏览 2 评论
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
15067 浏览 2 评论
STM32仿真器是选择ST-LINK还是选择J-LINK?各有什么优势啊?
3132浏览 4评论
stm32f4下spi+dma读取数据不对是什么原因导致的?
1921浏览 3评论
STM32F0_TIM2输出pwm2后OLED变暗或者系统重启是怎么回事?
2090浏览 3评论
2001浏览 3评论
stm32cubemx生成mdk-arm v4项目文件无法打开是什么原因导致的?
2198浏览 3评论
/9
GMT+8, 2025-12-8 08:48 , Processed in 1.220825 second(s), Total 76, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
517
