电子发烧友论坛|
最近几天 研究了下AC6编译器 ,想使用AC6 编译TouchGFX, 用ArmV5 编译 工程没问题,
可是换成AC6 编译器就会出现很多错误 ,经过各种折腾 最后错误剩了1条了, 有啥解决办法吗? 下面是最后的部分报错 linking... Test_baseBlank_0824Test_baseBlank_0824.axf: Warning: L6869W: abstractpartition.o requested the Rogue Wave Standard C++ Library which has been removed from the product. This might cause link errors because libc++ is used instead. Test_baseBlank_0824Test_baseBlank_0824.axf: Warning: L6869W: lcd24bpp.o requested the Rogue Wave Standard C++ Library which has been removed from the product. This might cause link errors because libc++ is used instead. Test_baseBlank_0824Test_baseBlank_0824.axf: Warning: L6869W: application.o requested the Rogue Wave Standard C++ Library which has been removed from the product. This might cause link errors because libc++ is used instead. Test_baseBlank_0824Test_baseBlank_0824.axf: Warning: L6869W: bitmap.o requested the Rogue Wave Standard C++ Library which has been removed from the product. This might cause link errors because libc++ is used instead. Test_baseBlank_0824Test_baseBlank_0824.axf: Warning: L6869W: button.o requested the Rogue Wave Standard C++ Library which has been removed from the product. This might cause link errors because libc++ is used instead. Test_baseBlank_0824Test_baseBlank_0824.axf: Warning: L6869W: buttonwithlabel.o requested the Rogue Wave Standard C++ Library which has been removed from the product. This might cause link errors because libc++ is used instead. Test_baseBlank_0824Test_baseBlank_0824.axf: Warning: L6869W: constfont.o requested the Rogue Wave Standard C++ Library which has been removed from the product. This might cause link errors because libc++ is used instead. Test_baseBlank_0824Test_baseBlank_0824.axf: Warning: L6869W: container.o requested the Rogue Wave Standard C++ Library which has been removed from the product. This might cause link errors because libc++ is used instead. Test_baseBlank_0824Test_baseBlank_0824.axf: Warning: L6869W: dma.o requested the Rogue Wave Standard C++ Library which has been removed from the product. This might cause link errors because libc++ is used instead. Test_baseBlank_0824Test_baseBlank_0824.axf: Warning: L6869W: drawable.o requested the Rogue Wave Standard C++ Library which has been removed from the product. This might cause link errors because libc++ is used instead. Test_baseBlank_0824Test_baseBlank_0824.axf: Warning: L6869W: font.o requested the Rogue Wave Standard C++ Library which has been removed from the product. This might cause link errors because libc++ is used instead. Test_baseBlank_0824Test_baseBlank_0824.axf: Warning: L6869W: fontmanager.o requested the Rogue Wave Standard C++ Library which has been removed from the product. This might cause link errors because libc++ is used instead. Test_baseBlank_0824Test_baseBlank_0824.axf: Warning: L6869W: hal.o requested the Rogue Wave Standard C++ Library which has been removed from the product. This might cause link errors because libc++ is used instead. Test_baseBlank_0824Test_baseBlank_0824.axf: Warning: L6869W: image.o requested the Rogue Wave Standard C++ Library which has been removed from the product. This might cause link errors because libc++ is used instead. Test_baseBlank_0824Test_baseBlank_0824.axf: Warning: L6869W: lcd.o requested the Rogue Wave Standard C++ Library which has been removed from the product. This might cause link errors because libc++ is used instead. Test_baseBlank_0824Test_baseBlank_0824.axf: Warning: L6869W: screen.o requested the Rogue Wave Standard C++ Library which has been removed from the product. This might cause link errors because libc++ is used instead. Test_baseBlank_0824Test_baseBlank_0824.axf: Warning: L6869W: textprovider.o requested the Rogue Wave Standard C++ Library which has been removed from the product. This might cause link errors because libc++ is used instead. Test_baseBlank_0824Test_baseBlank_0824.axf: Warning: L6869W: typedtext.o requested the Rogue Wave Standard C++ Library which has been removed from the product. This might cause link errors because libc++ is used instead. Test_baseBlank_0824Test_baseBlank_0824.axf: Warning: L6869W: unicode.o requested the Rogue Wave Standard C++ Library which has been removed from the product. This might cause link errors because libc++ is used instead. Test_baseBlank_0824Test_baseBlank_0824.axf: Warning: L6869W: utils.o requested the Rogue Wave Standard C++ Library which has been removed from the product. This might cause link errors because libc++ is used instead. Test_baseBlank_0824Test_baseBlank_0824.axf: Warning: L6869W: abstractbutton.o requested the Rogue Wave Standard C++ Library which has been removed from the product. This might cause link errors because libc++ is used instead. Test_baseBlank_0824Test_baseBlank_0824.axf: Warning: L6869W: displaytransformation.o requested the Rogue Wave Standard C++ Library which has been removed from the product. This might cause link errors because libc++ is used instead. Test_baseBlank_0824Test_baseBlank_0824.axf: Warning: L6869W: gestures.o requested the Rogue Wave Standard C++ Library which has been removed from the product. This might cause link errors because libc++ is used instead. Test_baseBlank_0824Test_baseBlank_0824.axf: Warning: L6869W: STM32_crc_lock.o requested the Rogue Wave Standard C++ Library which has been removed from the product. This might cause link errors because libc++ is used instead. Test_baseBlank_0824Test_baseBlank_0824.axf: Warning: L6869W: texturemaptypes.o requested the Rogue Wave Standard C++ Library which has been removed from the product. This might cause link errors because libc++ is used instead. Test_baseBlank_0824Test_baseBlank_0824.axf: Warning: L6869W: touchcalibration.o requested the Rogue Wave Standard C++ Library which has been removed from the product. This might cause link errors because libc++ is used instead. Test_baseBlank_0824Test_baseBlank_0824.axf: Error: L6218E: Undefined symbol __aeabi_vec_ctor_nocookie_nodtor (referred from application.o). Not enough information to list image symbols. Not enough information to list load addresses in the image map. Finished: 2 information, 26 warning and 1 error messages. "Test_baseBlank_0824Test_baseBlank_0824.axf" - 1 Error(s), 102 Warning(s). |
2个回答
touchgfx_core.lib 需要切换为Keil6.x目录下的AC6版本
的开始部分 @ I$$rodata undefined: referenced from screen setup Test_baseBlank_0824Test_baseBlank_0824.axf: Error: L6218E: Undefined symbol @@Screen_Test_baseBlank_0824__I$$rodata (referred from Responsible.o). 在搜索引擎中找了很多资料都没有找到有效的解决方法,希望大家能帮忙解答一下,谢谢!
只有小组成员才能发言,加入小组>>
调试STM32H750的FMC总线读写PSRAM遇到的问题求解?
4130 浏览 1 评论
X-NUCLEO-IHM08M1板文档中输出电流为15Arms,15Arms是怎么得出来的呢?
3221 浏览 1 评论
2747 浏览 2 评论
STM32F030F4 HSI时钟温度测试过不去是怎么回事?
2175 浏览 2 评论
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
14939 浏览 2 评论
STM32仿真器是选择ST-LINK还是选择J-LINK?各有什么优势啊?
3084浏览 4评论
stm32f4下spi+dma读取数据不对是什么原因导致的?
1894浏览 3评论
STM32F0_TIM2输出pwm2后OLED变暗或者系统重启是怎么回事?
2064浏览 3评论
1976浏览 3评论
stm32cubemx生成mdk-arm v4项目文件无法打开是什么原因导致的?
2165浏览 3评论
/9
GMT+8, 2025-12-2 01:55 , Processed in 0.485109 second(s), Total 43, Slave 36 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1405
