电子发烧友论坛|
已经实验过,不开启调度器,I2C1能正常读取数据,一开启就返回错误HAL_ERROR!在线等帮忙,很急。I2C1配置如下:
void MX_I2C1_Init(void) { hi2c1.Instance = I2C1; hi2c1.Init.timing = 0x00501E6C; hi2c1.Init.OwnAddress1 = 0; hi2c1.Init.AddressingMode = I2C_ADDRESSINGMODE_7BIT; hi2c1.Init.DualAddressMode = I2C_DUALADDRESS_DISABLE; hi2c1.Init.OwnAddress2 = 0; hi2c1.Init.OwnAddress2Masks = I2C_OA2_NOMASK; hi2c1.Init.GeneralCallMode = I2C_GENERALCALL_DISABLE; hi2c1.Init.NoStretchMode = I2C_NOSTRETCH_DISABLE; if (HAL_I2C_Init( hi2c1) != HAL_OK) { Error_Handler(); } /** Configure Analogue filter */ if (HAL_I2CEx_ConfigAnalogFilter( hi2c1, I2C_ANALOGFILTER_ENABLE) != HAL_OK) { Error_Handler(); } /** Configure Digital filter */ if (HAL_I2CEx_ConfigDigitalFilter( hi2c1, 0) != HAL_OK) { Error_Handler(); } } void HAL_I2C_MspInit(I2C_HandleTypeDef* i2cHandle) { GPIO_InitTypeDef GPIO_InitStruct = {0}; if(i2cHandle->Instance==I2C1) { /* USER CODE BEGIN I2C1_MspInit 0 */ /* USER CODE END I2C1_MspInit 0 */ __HAL_RCC_GPIOB_CLK_ENABLE(); /* I2C1 clock enable */ __HAL_RCC_I2C1_CLK_ENABLE(); /**I2C1 GPIO Configuration PB8 ------> I2C1_SCL PB9 ------> I2C1_SDA */ GPIO_InitStruct.Pin = GPIO_PIN_8|GPIO_PIN_9; GPIO_InitStruct.Mode = GPIO_MODE_AF_OD; GPIO_InitStruct.Pull = GPIO_PULLUP; GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH; GPIO_InitStruct.Alternate = GPIO_AF4_I2C1; HAL_GPIO_Init(GPIOB, GPIO_InitStruct); /* USER CODE BEGIN I2C1_MspInit 1 */ /* USER CODE END I2C1_MspInit 1 */ } } void HAL_I2C_MspDeInit(I2C_HandleTypeDef* i2cHandle) { if(i2cHandle->Instance==I2C1) { /* USER CODE BEGIN I2C1_MspDeInit 0 */ /* USER CODE END I2C1_MspDeInit 0 */ /* Peripheral clock disable */ __HAL_RCC_I2C1_CLK_DISABLE(); /**I2C1 GPIO Configuration PB8 ------> I2C1_SCL PB9 ------> I2C1_SDA */ HAL_GPIO_DeInit(GPIOB, GPIO_PIN_8|GPIO_PIN_9); /* USER CODE BEGIN I2C1_MspDeInit 1 */ /* USER CODE END I2C1_MspDeInit 1 */ } } |
2个回答
楼主可以看一次是不是systicks中断没有对hal用到的计数器进行增加操作。
在FreeRTOS启动后,I2C1无法正常读取的原因可能是调度器的任务优先级或任务间的竞争条件导致I2C1资源无法正常访问。
为了解决这个问题,可以尝试下列方法: 1. 在FreeRTOS任务中禁用/启用调度器:在访问I2C1之前禁用调度器,完成I2C1操作后再启用调度器。这样可以确保I2C1在操作期间不被其他任务打断。 2. 调整任务优先级:如果I2C1操作被其他优先级较高的任务打断,可以调整任务的优先级,确保I2C1任务具有更高的优先级。 3. 使用信号量或互斥量:使用FreeRTOS的信号量或互斥量机制,确保只有一个任务能够访问I2C1资源,其他任务需要等待资源可用时再访问。 下面是一个示例代码,演示如何在读取I2C1之前禁用/启用调度器: ``` #include "FreeRTOS.h" #include "task.h" #include "semphr.h" SemaphoreHandle_t i2cSemaphore; void I2C1_Read_Task(void *pvParameters) { while (1) { // 等待I2C1资源可用 if (xSemaphoreTake(i2cSemaphore, portMAX_DELAY) == pdTRUE) { // 禁用调度器 vTaskSuspendAll(); // 执行I2C1读操作 // 启用调度器 xTaskResumeAll(); // 释放I2C1资源 xSemaphoreGive(i2cSemaphore); } vTaskDelay(pdMS_TO_TICKS(100)); } } void HAL_I2C1_ErrorCallback(I2C_HandleTypeDef *hi2c) { // 处理I2C1错误 } int main(void) { // 初始化信号量 i2cSemaphore = xSemaphoreCreateMutex(); // 创建I2C1读取任务 xTaskCreate(I2C1_Read_Task, "I2C1_Read_Task", configMINIMAL_STACK_SIZE, NULL, tskIDLE_PRIORITY + 1, NULL); // 启动FreeRTOS调度器 vTaskStartScheduler(); while (1) { // 不能到达这里 } return 0; } ``` 在上述示例中,`I2C1_Read_Task`是一个任务,它通过获取`i2cSemaphore`来请求I2C1资源的访问。在访问I2C1之前,调度器被禁用,以确保I2C1的操作不会被其他任务打断。完成I2C1操作后,调度器被重新启用,并释放I2C1资源,以便其他任务可以访问。 请注意,示例代码中的`HAL_I2C1_ErrorCallback`函数用于处理I2C1的错误。 |
只有小组成员才能发言,加入小组>>
调试STM32H750的FMC总线读写PSRAM遇到的问题求解?
4140 浏览 1 评论
X-NUCLEO-IHM08M1板文档中输出电流为15Arms,15Arms是怎么得出来的呢?
3228 浏览 1 评论
2753 浏览 2 评论
STM32F030F4 HSI时钟温度测试过不去是怎么回事?
2181 浏览 2 评论
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
14984 浏览 2 评论
STM32仿真器是选择ST-LINK还是选择J-LINK?各有什么优势啊?
3092浏览 4评论
stm32f4下spi+dma读取数据不对是什么原因导致的?
1898浏览 3评论
STM32F0_TIM2输出pwm2后OLED变暗或者系统重启是怎么回事?
2070浏览 3评论
1981浏览 3评论
stm32cubemx生成mdk-arm v4项目文件无法打开是什么原因导致的?
2171浏览 3评论
/9
GMT+8, 2025-12-3 05:34 , Processed in 0.713579 second(s), Total 75, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
8482
