电子发烧友论坛|
我使用STM32F103VET6单片机做主控,现在想要做两路PWM信号输出,两路的PWM需要有一定的相位差,并要求输出的占空比可调,所以我想到了定时器的比较输出功能,我现在是使用到了定时器2的两路输出,第二路使用PWM输出的方式,第一路的相位差想到了用DMA方式,我在程序烧录进硬件电路后示波器观察波形,DMA输出的一个信号没有输出,而且第二路输出也没有相位差,从第三个信号开始按照我的设计思路正常执行了,我想求助下我DMA配置是哪里出现了问题
uint32_t Data_Pwm[]={2000,19998,0}; uint32_t Data_Pwm1[] = {300,5}; void MX_tiM2_Init(void) { /* USER CODE BEGIN TIM2_Init 0 */ /* USER CODE END TIM2_Init 0 */ TIM_ClockConfigTypeDef sClockSourceConfig = {0}; TIM_MasterConfigTypeDef sMasterConfig = {0}; TIM_OC_InitTypeDef sConfigOC = {0}; TIM_IC_InitTypeDef sConfigIC = {0}; /* USER CODE BEGIN TIM2_Init 1 */ /* USER CODE END TIM2_Init 1 */ htim2.Instance = TIM2; htim2.Init.Prescaler = 35; htim2.Init.CounterMode = TIM_COUNTERMODE_UP; htim2.Init.Period = 20000; htim2.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1; htim2.Init.AutoReloadPreload = TIM_AUTORELOAD_PRELOAD_DISABLE; if (HAL_TIM_Base_Init( htim2) != HAL_OK) { Error_Handler(__FILE__, __LINE__); } sClockSourceConfig.ClockSource = TIM_CLOCKSOURCE_INTERNAL; if (HAL_TIM_ConfigClockSource( htim2, sClockSourceConfig) != HAL_OK) { Error_Handler(__FILE__, __LINE__); } if (HAL_TIM_OC_Init( htim2) != HAL_OK) { Error_Handler(__FILE__, __LINE__); } if (HAL_TIM_PWM_Init( htim2) != HAL_OK) { Error_Handler(__FILE__, __LINE__); } if (HAL_TIM_IC_Init( htim2) != HAL_OK) { Error_Handler(__FILE__, __LINE__); } sMasterConfig.MasterOutputTrigger = TIM_TRGO_RESET; sMasterConfig.MasterSlaveMode = TIM_MASTERSLAVEMODE_DISABLE; if (HAL_TIMEx_MasterConfigSynchronization( htim2, sMasterConfig) != HAL_OK) { Error_Handler(__FILE__, __LINE__); } sConfigOC.OCMode = TIM_OCMODE_TOGGLE; sConfigOC.Pulse = 0; sConfigOC.OCPolarity = TIM_OCPOLARITY_HIGH; sConfigOC.OCFastMode = TIM_OCFAST_DISABLE; if (HAL_TIM_OC_ConfigChannel( htim2, sConfigOC, TIM_CHANNEL_1) != HAL_OK) { Error_Handler(__FILE__, __LINE__); } sConfigOC.OCMode = TIM_OCMODE_PWM1; sConfigOC.Pulse = 200; sConfigOC.OCPolarity = TIM_OCPOLARITY_HIGH; sConfigOC.OCFastMode = TIM_OCFAST_DISABLE; if (HAL_TIM_PWM_ConfigChannel( htim2, sConfigOC, TIM_CHANNEL_2) != HAL_OK) { Error_Handler(__FILE__, __LINE__); } sConfigIC.ICPolarity = TIM_INPUTCHANNELPOLARITY_RISING; sConfigIC.ICSelection = TIM_ICSELECTION_DIRECTTI; sConfigIC.ICPrescaler = TIM_ICPSC_DIV1; sConfigIC.ICFilter = 0; if (HAL_TIM_IC_ConfigChannel( htim2, sConfigIC, TIM_CHANNEL_3) != HAL_OK) { Error_Handler(__FILE__, __LINE__); } sConfigOC.Pulse = 1000; sConfigOC.OCPolarity = TIM_OCPOLARITY_HIGH; sConfigOC.OCFastMode = TIM_OCFAST_DISABLE; if (HAL_TIM_PWM_ConfigChannel( htim2, sConfigOC, TIM_CHANNEL_4) != HAL_OK) { Error_Handler(__FILE__, __LINE__); } /* USER CODE BEGIN TIM2_Init 2 */ /* USER CODE END TIM2_Init 2 */ HAL_TIM_MspPostInit( htim2); __HAL_TIM_DISABLE_OCxPRELOAD( htim2,TIM_CHANNEL_1); __HAL_TIM_ENABLE_OCxPRELOAD( htim2,TIM_CHANNEL_2); __HAL_TIM_ENABLE_OCxPRELOAD( htim2,TIM_CHANNEL_4); __HAL_TIM_ENABLE_IT( htim2, TIM_IT_CC2); __HAL_TIM_ENABLE_IT( htim2, TIM_IT_CC4); // TIM_CCxChannelCmd(TIM2, TIM_CHANNEL_1,TIM_CCx_ENABLE); // TIM_CCxChannelCmd(TIM2, TIM_CHANNEL_2,TIM_CCx_ENABLE); // TIM_CCxChannelCmd(TIM2, TIM_CHANNEL_4,TIM_CCx_ENABLE); HAL_TIM_PWM_Start_DMA( htim2, TIM_CHANNEL_1,Data_Pwm,2); //HAL_TIM_OC_Start_DMA( htim2, TIM_CHANNEL_2,Data_Pwm1,2); // __HAL_TIM_CLEAR_IT( htim2,TIM_IT_UPDATE); __HAL_TIM_ENABLE_IT( htim2,TIM_IT_UPDATE); HAL_TIM_IC_Start_IT( htim2,TIM_CHANNEL_3); HAL_TIM_PWM_Start( htim2,TIM_CHANNEL_2); __HAL_TIM_ENABLE( htim2); |
1个回答
根据您提供的代码片段,可能是以下几个原因导致第一次输出不正确:
1. DMA数据传输长度设置错误:根据您的描述,您的DMA传输长度应为3,因为有3个数据需要传输。请确保您已正确配置DMA传输长度。 2. DMA传输地址设置错误:请确保DMA传输目标地址与定时器比较输出寄存器的地址匹配,以确保正确传输数据。 3. 定时器比较输出模式配置有误:请确保您已正确配置定时器2的比较输出模式。您可以通过设置TIM_CCMR1寄存器的OC1M和OC2M位来选择PWM1和PWM2模式。 4. 定时器计数值设置错误:请确保您已正确配置定时器2的计数值和预分频器,以确保定时器的周期正确。 5. PWM输出引脚配置错误:请确保您已正确配置相关引脚为定时器2的比较输出功能。 另外,关于相位差的问题,您可以通过调整DMA传输目标地址的偏移量来实现相位差。例如,在Data_Pwm1数组中,将元素设置为0的目的是为了产生相位差,您可以尝试调整该值来调整相位差的大小。 最后,如果您希望进一步解决问题,建议您提供更完整的代码,以及定时器和DMA初始化的配置信息。这样可以更好地帮助我们找出问题所在。 |
只有小组成员才能发言,加入小组>>
调试STM32H750的FMC总线读写PSRAM遇到的问题求解?
4130 浏览 1 评论
X-NUCLEO-IHM08M1板文档中输出电流为15Arms,15Arms是怎么得出来的呢?
3221 浏览 1 评论
2747 浏览 2 评论
STM32F030F4 HSI时钟温度测试过不去是怎么回事?
2175 浏览 2 评论
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
14939 浏览 2 评论
STM32仿真器是选择ST-LINK还是选择J-LINK?各有什么优势啊?
3084浏览 4评论
stm32f4下spi+dma读取数据不对是什么原因导致的?
1894浏览 3评论
STM32F0_TIM2输出pwm2后OLED变暗或者系统重启是怎么回事?
2064浏览 3评论
1976浏览 3评论
stm32cubemx生成mdk-arm v4项目文件无法打开是什么原因导致的?
2165浏览 3评论
/9
GMT+8, 2025-12-2 02:57 , Processed in 0.639551 second(s), Total 75, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3596
