电子发烧友论坛|
烧录工具 STM32CubeProg V2.9, 烧录器 ST-link V2.
板上烧录,FUS 烧录完成,显示no error, 版本1.2.0, 烧录Stack时,显示错误:Error: The FUS version you're trying to install is older/equal to the FUS version already installed ! 请问如何处理这个问题? 以下为LOG: 11:06:18 : STM32CubeProgrammer API v2.9.011:06:27 : ST-LINK SN : 55FF7306498055575449198711:06:27 : ST-LINK FW : V2J38S711:06:27 : Board : --11:06:27 : Voltage : 2.90V11:06:27 : SWD freq : 4000 KHz11:06:27 : Connect mode: Under Reset11:06:27 : Reset mode : Hardware reset11:06:27 : Device ID : 0x49511:06:27 : Revision ID : Rev Y11:06:27 : ST-LINK SN : 55FF7306498055575449198711:06:27 : ST-LINK FW : V2J38S711:06:27 : Board : --11:06:27 : Voltage : 2.93V11:06:28 : SWD freq : 4000 KHz11:06:28 : Connect mode: Under Reset11:06:28 : Reset mode : Hardware reset11:06:28 : Device ID : 0x49511:06:28 : Revision ID : Rev Y11:06:28 : Debug in Low Power mode enabled.11:06:29 : UPLOADING OPtiON BYTES DATA ...11:06:29 : Bank : 0x0011:06:29 : Address : 0x5800402011:06:29 : Size : 96 Bytes11:06:29 : Bank : 0x0111:06:29 : Address : 0x5800408011:06:29 : Size : 8 Bytes11:06:29 : UPLOADING ...11:06:29 : Size : 1024 Bytes11:06:29 : Address : 0x800000011:06:29 : Read progress:11:06:29 : Data read successfully11:06:29 : Time elapsed during the read operation is: 00:00:00.01211:06:38 : Flash sector erase ...11:08:38 : Error: Sector erase operation has failed at least for one of the existing specified sectors.Please verify flash memory protection.11:08:43 : Warning: Option Byte: nSWboot0, value: 0x0, was not modified.11:08:43 : Warning: Option Byte: nboot0, value: 0x1, was not modified.11:08:43 : Warning: Option Byte: nboot1, value: 0x1, was not modified.11:08:43 : Warning: Option Bytes are unchanged, Data won't be downloaded11:08:43 : Succeeded to set nSWboot0=0 nboot1=1 nboot0=111:08:43 : Memory Programming ...11:08:43 : Opening and parsing file: 0x495_FUS_Operator.bin11:08:43 : File : 0x495_FUS_Operator.bin11:08:43 : Size : 8 KBytes11:08:43 : Address : 0x0800000011:08:43 : Erasing memory corresponding to segment 0:11:08:43 : Erasing internal memory sectors [0 1]11:08:43 : Download in Progress:11:08:44 : File download complete11:08:44 : Time elapsed during download operation: 00:00:00.97211:08:44 : Application is running, Please Hold on...11:08:44 : Reconnecting...11:08:44 : Reconnected !11:08:45 : FUS_STATE_IDLE11:08:45 : Read FUS state command execution finished11:08:45 : UPLOADING ...11:08:45 : Size : 4 Bytes11:08:45 : Address : 0x2001001011:08:45 : Read progress:11:08:45 : Data read successfully11:08:45 : Time elapsed during the read operation is: 00:00:00.00811:08:45 : UPLOADING ...11:08:45 : Size : 4 Bytes11:08:45 : Address : 0x8001FFC11:08:45 : Read progress:11:08:45 : Data read successfully11:08:45 : Time elapsed during the read operation is: 00:00:00.00711:08:54 : UPLOADING ...11:08:54 : Size : 4 Bytes11:08:54 : Address : 0x1FFF807011:08:54 : Read progress:11:08:54 : Data read successfully11:08:54 : Time elapsed during the read operation is: 00:00:00.00811:08:56 : Old Firmware delete ...11:08:56 : Warning: Option Byte: nSWboot0, value: 0x0, was not modified.11:08:56 : Warning: Option Byte: nboot0, value: 0x1, was not modified.11:08:56 : Warning: Option Byte: nboot1, value: 0x1, was not modified.11:08:56 : Warning: Option Bytes are unchanged, Data won't be downloaded11:08:56 : Succeeded to set nSWboot0=0 nboot1=1 nboot0=111:08:56 : Memory Programming ...11:08:56 : Opening and parsing file: 0x495_FUS_Operator.bin11:08:56 : File : 0x495_FUS_Operator.bin11:08:56 : Size : 8 KBytes11:08:56 : Address : 0x0800000011:08:56 : Erasing memory corresponding to segment 0:11:08:57 : Erasing internal memory sectors [0 1]11:08:57 : Download in Progress:11:08:58 : File download complete11:08:58 : Time elapsed during download operation: 00:00:02.00911:08:58 : Application is running, Please Hold on...11:09:05 : Reconnecting...11:09:06 : Reconnected !11:09:06 : Warning: FUS_STATE_IMG_NOT_FOUND, Flash already empty !11:09:07 : Firmware delete Success11:09:07 : Download Stack/FUS image at address 0x80ca000 ...11:09:07 : Memory Programming ...11:09:07 : Opening and parsing file: stm32wb5x_BLE_Stack_full_fw.bin11:09:07 : File : stm32wb5x_BLE_Stack_full_fw.bin11:09:07 : Size : 170604 Bytes11:09:07 : Address : 0x080CA00011:09:07 : Erasing memory corresponding to segment 0:11:09:08 : Erasing internal memory sectors [202 243]11:09:09 : Download in Progress:11:09:13 : File download complete11:09:13 : Time elapsed during download operation: 00:00:05.94911:09:13 : Verifying ...11:09:13 : Read progress:11:09:16 : Download verified successfully11:09:16 : Firmware Upgrade process started ...11:09:17 : Application is running, Please Hold on...11:09:29 : Reconnecting...11:09:29 : Reconnected !11:09:29 : Error: The FUS version you're trying to install is older/equal to the FUS version already installed ! |
2个回答
这个FUS 是有anti-rollback , 不要使能它,否则就回不去了。 建议start FUS 成功后,读取一下版本。 如果stack版本是0,多半是使能了。
根据您提供的信息,烧录Stack时显示了错误信息:“Error: The FUS version you're trying to install is older/equal to the FUS version already installed!” 这个错误提示意味着您正在尝试安装一个比已安装的FUS版本旧或相等的版本。
要解决这个问题,您可以尝试以下步骤: 1. 确保您使用的是最新版本的STM32CubeProgrammer和ST-Link固件。您可以从ST官方网站上下载最新版本的这些工具。 2. 在烧录之前,检查您的FUS版本和目标设备的FUS版本是否匹配。您可以通过使用STM32CubeProgrammer检查目标设备的FUS版本,并确保您正在尝试烧录一个更高版本的FUS。 3. 如果您的目标设备已经安装了一个较新的FUS版本,并且您想要降级到一个较旧的FUS版本,那么您可能需要在目标设备上进行一些额外的配置。请参考ST官方文档或资料,查找关于如何降级FUS版本的指导。 4. 如果问题仍然存在,您可以尝试将STM32CubeProgrammer和ST-Link固件恢复到出厂默认设置,并重新开始烧录过程。 如果这些步骤都不能解决问题,建议您联系ST官方的技术支持团队,以获取更详细的帮助和支持。 |
只有小组成员才能发言,加入小组>>
调试STM32H750的FMC总线读写PSRAM遇到的问题求解?
4204 浏览 1 评论
X-NUCLEO-IHM08M1板文档中输出电流为15Arms,15Arms是怎么得出来的呢?
3263 浏览 1 评论
2795 浏览 2 评论
STM32F030F4 HSI时钟温度测试过不去是怎么回事?
2227 浏览 2 评论
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
15146 浏览 2 评论
STM32仿真器是选择ST-LINK还是选择J-LINK?各有什么优势啊?
3168浏览 4评论
stm32f4下spi+dma读取数据不对是什么原因导致的?
1942浏览 3评论
STM32F0_TIM2输出pwm2后OLED变暗或者系统重启是怎么回事?
2108浏览 3评论
2019浏览 3评论
stm32cubemx生成mdk-arm v4项目文件无法打开是什么原因导致的?
2216浏览 3评论
/9
GMT+8, 2025-12-13 18:22 , Processed in 0.918358 second(s), Total 77, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
586
