刚接触SMBUS,想实现一下它的基本传输,平台是f3discovery;我用Cube选择了two-wire模式的SMBus1和SMBus2生成了基本代码,打算把1作为master,2作为slave采用中断方式去完成收发的demo(不知道可不可行),我在生成的SMBus2配置项中把ownaddress1 设置为0xA0 即从机地址;
请问在main里面应该怎样调用HAL库能实现带PEC的基本传输? |
1个回答
要在main函数中调用HAL库实现带PEC的基本传输,你可以按照以下步骤进行操作:
1. 在main函数的开头,添加HAL库的头文件: ```c #include "stm32f3xx_hal.h" ``` 2. 在main函数中初始化HAL库: ```c HAL_Init(); ``` 3. 配置SMBus1和SMBus2的GPIO引脚和时钟: ```c __HAL_RCC_GPIOA_CLK_ENABLE(); // 使能GPIOA时钟 __HAL_RCC_GPIOB_CLK_ENABLE(); // 使能GPIOB时钟 /* 配置GPIO引脚 */ GPIO_InitTypeDef GPIO_InitStruct; GPIO_InitStruct.Pin = GPIO_PIN_6 | GPIO_PIN_7; GPIO_InitStruct.Mode = GPIO_MODE_AF_OD; GPIO_InitStruct.Pull = GPIO_PULLUP; GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_HIGH; GPIO_InitStruct.Alternate = GPIO_AF4_I2C1; HAL_GPIO_Init(GPIOB, &GPIO_InitStruct); GPIO_InitStruct.Pin = GPIO_PIN_10 | GPIO_PIN_11; GPIO_InitStruct.Mode = GPIO_MODE_AF_OD; GPIO_InitStruct.Pull = GPIO_PULLUP; GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_HIGH; GPIO_InitStruct.Alternate = GPIO_AF4_I2C2; HAL_GPIO_Init(GPIOB, &GPIO_InitStruct); ``` 4. 初始化SMBus1和SMBus2的外设: ```c __HAL_RCC_I2C1_CLK_ENABLE(); // 使能I2C1时钟 __HAL_RCC_I2C2_CLK_ENABLE(); // 使能I2C2时钟 /* 配置SMBus1 */ I2C_HandleTypeDef hi2c1; hi2c1.Instance = I2C1; hi2c1.Init.ClockSpeed = 100000; // 设置时钟速度 hi2c1.Init.DutyCycle = I2C_DUTYCYCLE_2; hi2c1.Init.OwnAddress1 = 0xA0; hi2c1.Init.AddressingMode = I2C_ADDRESSINGMODE_7BIT; hi2c1.Init.DualAddressMode = I2C_DUALADDRESS_DISABLE; hi2c1.Init.OwnAddress2 = 0xFF; hi2c1.Init.GeneralCallMode = I2C_GENERALCALL_DISABLE; hi2c1.Init.NoStretchMode = I2C_NOSTRETCH_DISABLE; HAL_I2C_Init(&hi2c1); /* 配置SMBus2 */ I2C_HandleTypeDef hi2c2; hi2c2.Instance = I2C2; hi2c2.Init.ClockSpeed = 100000; // 设置时钟速度 hi2c2.Init.DutyCycle = I2C_DUTYCYCLE_2; hi2c2.Init.OwnAddress1 = 0xA0; hi2c2.Init.AddressingMode = I2C_ADDRESSINGMODE_7BIT; hi2c2.Init.DualAddressMode = I2C_DUALADDRESS_DISABLE; hi2c2.Init.OwnAddress2 = 0xFF; hi2c2.Init.GeneralCallMode = I2C_GENERALCALL_DISABLE; hi2c2.Init.NoStretchMode = I2C_NOSTRETCH_DISABLE; HAL_I2C_Init(&hi2c2); ``` 5. 在main函数中使用HAL库的函数进行数据传输: ```c uint8_t dataBuffer[10] = {0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08, 0x09, 0x0A}; uint8_t receiveBuffer[10] = {0}; HAL_I2C_Master_Transmit(&hi2c1, 0xA0, dataBuffer, 10, 1000); // 向从机发送数据 HAL_I2C_Master_Receive(&hi2c2, 0xA0, receiveBuffer, 10, 1000); // 从从机接收数据 ``` 注意,在上面的代码中,我们使用了`HAL_I2C_Master_Transmit`函数向从机发送数据,使用了`HAL_I2C_Master_Receive`函数从从机接收数据。可以根据你的需求调整这些函数的参数。 希望这些信息能帮助到你!请随时告诉我如果你有任何其他问题。 |
只有小组成员才能发言,加入小组>>
调试STM32H750的FMC总线读写PSRAM遇到的问题求解?
1614 浏览 1 评论
X-NUCLEO-IHM08M1板文档中输出电流为15Arms,15Arms是怎么得出来的呢?
1541 浏览 1 评论
970 浏览 2 评论
STM32F030F4 HSI时钟温度测试过不去是怎么回事?
682 浏览 2 评论
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
1592 浏览 2 评论
1863浏览 9评论
STM32仿真器是选择ST-LINK还是选择J-LINK?各有什么优势啊?
644浏览 4评论
STM32F0_TIM2输出pwm2后OLED变暗或者系统重启是怎么回事?
515浏览 3评论
531浏览 3评论
stm32cubemx生成mdk-arm v4项目文件无法打开是什么原因导致的?
504浏览 3评论
GMT+8, 2024-11-22 00:29 , Processed in 0.931333 second(s), Total 80, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
