扫一扫,分享给好友
如下图:
图1 对应的时钟与BPS的关系以及发送的逻辑
图2 对应的数据与BPS的对应关系
图3 要求的循环发送以及时间
对应的具体代码段如下:
module UART_transmit( input wire clk, input wire rst_n, input wire [7:0] data, //外部输入需要发送的数据 output reg uart_tx, output reg led ); parameter CNT_1S_MAX = 26'd50_000_000 - 1; parameter BPS_CNT_MAX = 16'd5208 - 1; //波特率的周期 reg [25:0] counter1; reg uart_state; // 0 busy 1 free reg [3:0] bit_counter; reg [15:0] bps_counter; reg bit_flag; reg [7:0] data_req; //对应的1S计数 always @(posedge clk or negedge rst_n) if( rst_n == 1'b0 ) counter1 <= 26'b0; else if( counter1 == CNT_1S_MAX ) counter1 <= 26'b0; else counter1 <= counter1 + 1'b1; //UART发送状态使能模块 always @(posedge clk or negedge rst_n) if( rst_n == 1'b0 ) uart_state <= 1'b0; else if( counter1 == CNT_1S_MAX || (bit_counter == 4'd10 && bps_counter == BPS_CNT_MAX) ) uart_state <= ~uart_state; else uart_state <= uart_state; //锁定外部输入的发送数据 always @(posedge clk or negedge rst_n) if( rst_n == 1'b0 ) data_req <= 8'b0; else if( counter1 == CNT_1S_MAX ) data_req <= data; else data_req <= data_req; //生成波特率发送信号 always @(posedge clk or negedge rst_n) if( rst_n == 1'b0 ) bps_counter <= 16'b0; else if( uart_state == 1'b1 )begin if ( bps_counter == BPS_CNT_MAX ) begin bps_counter <= 16'b0; end else bps_counter <= bps_counter + 1'b1; end else bps_counter <= 16'b0; //单位数据发送的标志信号 always @(posedge clk or negedge rst_n) if( rst_n == 1'b0 ) bit_flag <= 1'b0; else if( bps_counter == 16'd2603 ) bit_flag <= 1'b1; else bit_flag <= 1'b0; //bit计数 always @(posedge clk or negedge rst_n) if( rst_n == 1'b0 ) bit_counter <= 4'b0; else if( uart_state == 1'b1 ) begin if( bit_flag == 1'b1 ) bit_counter <= bit_counter + 1'b1; else if( bit_counter == 4'd10 && bps_counter == BPS_CNT_MAX ) bit_counter <= 4'b0; end else bit_counter <= 4'b0; //逐位发送数据 always @(posedge clk or negedge rst_n)begin if( rst_n == 1'b0 )begin uart_tx <= 1'b1; end else begin case( bit_counter ) 0 : uart_tx <= 1'b1; 1 : uart_tx <= 1'b0; 2 : uart_tx <= data_req[0]; 3 : uart_tx <= data_req[1]; 4 : uart_tx <= data_req[2]; 5 : uart_tx <= data_req[3]; 6 : uart_tx <= data_req[4]; 7 : uart_tx <= data_req[5]; 8 : uart_tx <= data_req[6]; 9 : uart_tx <= data_req[7]; 10: uart_tx <= 1'b1; default : uart_tx <= 1'b1; endcase end end //变更LED状态 always @(posedge clk or negedge rst_n) if( rst_n == 1'b0 ) led <= 1'b0; else if( bit_counter == 4'd10 && bps_counter == BPS_CNT_MAX ) led <= ~led; else led <= led; endmodule
对应的测试用的code,如下:
`timescale 1ns/1ns module tb_UART_transmit(); //****************** Parameter and Internal Signal *******************// //wire define wire led; wire uart_tx; //reg define reg clk; reg rst_n; reg [7:0] data; //***************************** Main Code ****************************// initial begin rst_n <= 1'b0; data <= 8'b1010_1010; #201 rst_n <= 1'b1; #300_000_00; data <= 8'b0101_0101; #300_000_00; $stop; end // creator clk initial clk = 1'b1; always #10 clk <= ~clk; defparam UART_transmit_inst.CNT_1S_MAX = 26'd500_000 - 1; //*************************** Instantiation **************************// UART_transmit UART_transmit_inst ( .clk ( clk ), .rst_n ( rst_n ), .data ( data ), .led ( led ), .uart_tx ( uart_tx ) ); endmodule
对应的仿真图,如下:
FPGAUart串口fpga
【开源FPGA硬件】硬件黑客集结:开源FPGA开发板测评活动全网火热招募中......
JEDSD204B标准verilog实现-协议演进
NVMe高速传输之摆脱XDMA设计16:TLP优化
RDMA over RoCE V2设计1:通用,稳定及高性能!
【高云GW5AT-LV60 开发套件试用体验】三、LED灯控制实验
【高云GW5AT-LV60 开发套件试用体验】基于开发板进行深度学习实践,并尽量实现皮肤病理图片的识别,第四阶段
【RK3568+PG2L50H开发板实验例程】FPGA部分 | 光纤通信测试实验例程
【RK3568+PG2L50H开发板实验例程】FPGA部分 | DDR3 读写实验例程
【RK3568+PG2L50H开发板实验例程】FPGA部分 | ROM、RAM、FIFO 的使用
【RK3568+PG2L50H开发板实验例程】FPGA部分 | Pango 的时钟资源——锁相环
电子发烧友网
电子发烧友论坛
