电子发烧友论坛|
使用内部晶振程序是可以跑起来的,但是使用外部晶振,程序一直在等待,请问这是什么原因?(晶振使用的是12M无源晶振,不知道是不是有源无源的问题)
void SYS_Init(void) { /*---------------------------------------------------------------------------------------------------------*/ /* Init System Clock */ /*---------------------------------------------------------------------------------------------------------*/ /* Enable Internal RC 22.1184MHz clock */ CLK->PWRCON |= CLK_PWRCON_OSC22M_EN_Msk; /* Waiting for Internal RC clock ready */ while(!(CLK->CLKSTATUS & CLK_CLKSTATUS_OSC22M_STB_Msk)); /* Switch HCLK clock source to Internal RC */ CLK->CLKSEL0 &= ~CLK_CLKSEL0_HCLK_S_Msk; CLK->CLKSEL0 |= CLK_CLKSEL0_HCLK_S_HIRC; /* Enable external XTAL 12MHz clock */ CLK->PWRCON |= CLK_PWRCON_XTL12M_EN_Msk; /* Waiting for external XTAL clock ready */ //死在这里!! while(!(CLK->CLKSTATUS & CLK_CLKSTATUS_XTL12M_STB_Msk)); /* Set core clock as PLL_CLOCK from PLL */ CLK->PLLCON = PLLCON_SETTING; while(!(CLK->CLKSTATUS & CLK_CLKSTATUS_PLL_STB_Msk)); CLK->CLKSEL0 &= (~CLK_CLKSEL0_HCLK_S_Msk); CLK->CLKSEL0 |= CLK_CLKSEL0_HCLK_S_PLL; /* Update System Core Clock */ /* User can use SystemCoreClockUpdate() to calculate PllClock, SystemCoreClock and CycylesPerUs automatically. */ //SystemCoreClockUpdate(); PllClock = PLL_CLOCK; // PLL SystemCoreClock = PLL_CLOCK / 1; // HCLK CyclesPerUs = PLL_CLOCK / 1000000; // For SYS_SysTickDelay() /* Enable UART module clock */ CLK->APBCLK |= CLK_APBCLK_UART0_EN_Msk | CLK_APBCLK_I2C0_EN_Msk; /* Select UART module clock source */ CLK->CLKSEL1 &= ~CLK_CLKSEL1_UART_S_Msk; CLK->CLKSEL1 |= CLK_CLKSEL1_UART_S_HXT; /*---------------------------------------------------------------------------------------------------------*/ /* Init I/O Multi-function */ /*---------------------------------------------------------------------------------------------------------*/ /* Set P3 multi-function pins for UART0 RXD and TXD, and set P3.4 and P3.5 for I2C0 SDA and SCL */ SYS->P3_MFP &= ~(SYS_MFP_P30_Msk | SYS_MFP_P31_Msk | SYS_MFP_P34_Msk | SYS_MFP_P35_Msk); SYS->P3_MFP |= (SYS_MFP_P30_RXD0 | SYS_MFP_P31_TXD0 | SYS_MFP_P34_SDA0 | SYS_MFP_P35_SCL0); } |
1个回答
sp; */ /*---------------------------------------------------------------------------------------------------------*/ /* Unlock protected registers */ SYS_UnlockReg(); /* Enable HIRC clock (internal 22.1184MHz) */ CLK_EnableXtalRC(CLK_PWRCTL_HIRCEN_Msk); /* Waiting for HIRC clock ready */ CLK_WaitClockReady(CLK_STATUS_HIRCSTB_Msk); /* 选择外部晶振模式 */ CLK_SetHXT(CLK_CLKSEL0_HXTSEL_HXT, CLK_CLKDIV0_HXT(1)); /* Waiting for clock ready */ CLK_WaitClockReady(CLK_STATUS_HXTSTB_Msk); /* HCLK clock source. */ CLK_SetCoreClock(FREQ_36MHZ); /* Enable peripheral clock */ CLK_EnableModuleClock(UART0_MODULE); /* Disable PLL first to avoid unstable when setting PLL */ CLK_DisablePLL(); /* Configure PLL frequency */ CLK_SetPLL(CLK_PLLCTL_PLLSRC_HXT, CLK_PLLCTL_PLLDIV(3), CLK_PLLCTL_MUL3); /* Waiting for PLL ready */ CLK_WaitClockReady(CLK_STATUS_PLLSTB_Msk); /* Set HCLK clock */ CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_PLL, CLK_CLKDIV0_HCLK(1)); /* Set PCLK0/PCLK1 clock */ CLK_SetModuleClock(PWM01_MODULE, CLK_CLKSEL1_PWM01SEL_HXT, 0); CLK_SetModuleClock(PWM23_MODULE, CLK_CLKSEL1_PWM23SEL_HXT, 0); CLK_SetModuleClock(TMR0_MODULE, CLK_CLKSEL1_TMR0SEL_HXT, 0); CLK_SetModuleClock(TMR1_MODULE, CLK_CLKSEL1_TMR1SEL_HXT, 0); CLK_SetModuleClock(TMR2_MODULE, CLK_CLKSEL1_TMR2SEL_HXT, 0); CLK_SetModuleClock(TMR3_MODULE, CLK_CLKSEL1_TMR3SEL_HXT, 0); /* Enable PLL */ CLK_EnablePLL(); /* Waiting for PLL ready */ CLK_WaitClockReady(CLK_STATUS_PLLSTB_Msk); /* Lock protected registers */ SYS_LockReg();}
无法使用外部晶振可能有以下原因: 1. 晶振没有正确连接至芯片。 2. 晶振的频率不正确。 3. 用户程序没有执行正确的初始化代码。 4. 晶振是有源晶振,但没有正确的供电。 通过上述代码可以看出,程序已经完成了对外部晶振的初始化设置。如果以上情况都排除,还无法使用外部晶振,可以考虑更换晶振或者与芯片厂商联系。 |
只有小组成员才能发言,加入小组>>
1691 浏览 0 评论
imx6ull 和 lan8742 工作起来不正常, ping 老是丢包
4753 浏览 0 评论
4238 浏览 9 评论
3830 浏览 16 评论
4406 浏览 1 评论
4221浏览 3评论
2391浏览 0评论
3404浏览 0评论
1170浏览 0评论
2854浏览 0评论
/9
GMT+8, 2025-12-4 13:25 , Processed in 0.736321 second(s), Total 79, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
620
