电子发烧友论坛|
你好。我有一个新的 NodeMCU v3。我正在尝试使用 ESPLorer/PyFlasher/ESP8266Flasher/Arduino IDE 对其进行刷写。但什么也没发生。在 ESPLorer 中,当我尝试打开 COM 端口时崩溃。PyFlasher 和 ESP8266 卡在连接上。在 Arduino IDE 中我有这个错误
代码:全选esptool.py v3.0 Serial port COM11 Connecting....Traceback (most recent call last): File "C:\Users\Seeroy\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/upload.py", line 66, in esptool.main(cmdline) File "C:/Users/Seeroy/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool\esptool.py", line 3552, in main esp.connect(args.before, args.connect_attempts) File "C:/Users/Seeroy/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool\esptool.py", line 519, in connect last_error = self._connect_attempt(mode=mode, esp32r0_delay=False) File "C:/Users/Seeroy/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool\esptool.py", line 499, in _connect_attempt self.sync() File "C:/Users/Seeroy/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool\esptool.py", line 438, in sync timeout=SYNC_TIMEOUT) File "C:/Users/Seeroy/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool\esptool.py", line 376, in command self.write(pkt) File "C:/Users/Seeroy/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool\esptool.py", line 339, in write self._port.write(buf) File "C:/Users/Seeroy/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/pyserial\serial\serialwin32.py", line 325, in write raise SerialTimeoutException('Write timeout') serial.serialutil.SerialTimeoutException: Write timeout . |
只有小组成员才能发言,加入小组>>
945 浏览 0 评论
1672 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1330 浏览 1 评论
1233 浏览 1 评论
5021 浏览 2 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1253浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
927浏览 3评论
2336浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2526浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1051浏览 2评论
/9
GMT+8, 2025-12-2 03:55 , Processed in 0.531324 second(s), Total 40, Slave 33 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
467
