如题我在ubuntu18.4环境下对IMX8Mnano_EVK(模式为下载模式:SW1101设置为1000)进行烧录时失败,在windows环境下正常
dx@ubuntu:~/android_build/out/target/product/evk_8mn$ lsusb Bus 001 Device 002: ID 1fc9:013e NXP Semiconductors Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 002 Device 003: ID 0e0f:0002 VMware, Inc. Virtual USB Hub Bus 002 Device 002: ID 0e0f:0003 VMware, Inc. Virtual Mouse Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub dx@ubuntu:~/android_build/out/target/product/evk_8mn$ uuu uuu (Universal Update Utility) for nxp imx chips -- libuuu_1.4.182-0-ga561ed7 uuu [-d -m -v -V] bootloader download bootloader to board by usb cmdlist run all commands in cmdlist file If it is path, search uuu.auto in dir If it is zip, search uuu.auto in zip cmd Run one command, use -H see detail example: SDPS: boot -f flash.bin -d Daemon mode, wait for forever. -v -V verbose mode, -V enable libusb error\warning info -dry Dry run mode, check if script or cmd correct -m USBPATH Only monitor these paths. -m 1:2 -m 1:3 -t Timeout second for wait known usb device appeared -T Timeout second for wait next known usb device appeared at stage switch -e set environment variable key=value -pp usb polling period in milliseconds uuu -s Enter shell mode. uuu.inputlog record all input commands you can use "uuu uuu.inputlog" next time to run all commands uuu -udev linux: show udev rule to avoid sudo each time uuu -lsusb List connected know devices uuu -IgSerNum Set windows registry to ignore USB serial number for known uuu devices uuu -h show general help uuu -H show general help and detailed help for commands uuu [-d -m -v] -b[run] Run Built-in scripts emmc burn boot loader to eMMC boot partition arg0: _flash.bin bootloader arg1: _image[Optional] image burn to emmc, default is the same as bootloader emmc_all burn whole image to eMMC arg0: _flash.bin bootloader, which can extract from wic image arg1: _image[Optional] wic image burn to emmc. fat_write update one file in fat partition, require uboot fastboot running in board arg0: _image image, which cp to fat partition arg1: _device storage device, mmc\sata arg2: _partition fat partition number, like 1:1 arg3: _filename[Optional] file name in target fat partition, only support rootdir now nand burn boot loader to NAND flash arg0: _flash.bin bootloader arg1: _image[Optional] image burn to nand, default is the same as bootloader qspi burn boot loader to qspi nor flash arg0: _flexspi.bin bootloader arg1: _image[Optional] image burn to flexspi, default is the same as bootloader sd burn boot loader to sd card arg0: _flash.bin bootloader arg1: _image[Optional] image burn to emmc, default is the same as bootloader sd_all burn whole image to sd card arg0: _flash.bin bootloader, which can extract from wic image arg1: _image[Optional] wic image burn to emmc. spl boot spl and uboot arg0: _flash.bin uuu -bshow Show built-in script Enjoy auto [tab] command complete by put below script into /etc/bash_completion.d/uuu _uuu_autocomplete() { COMPREPLY=($(/usr/local/bin/uuu $1 $2 $3)) } complete -o nospace -F _uuu_autocomplete uuu dx@ubuntu:~/android_build/out/target/product/evk_8mn$ sudo ./uuu_imx_android_flash.sh -f imx8mn -a -e -u ddr4 -d ddr4 -t sd -c 28 [sudo] dx 的密码: 对不起,请重试。 [sudo] dx 的密码: This script is validated with uuu 1.4.182 version, it is recommended to align with this version. dtbo is supported dual slot is supported dynamic parttition is supported vendor_boot parttition is supported init_boot parttition is supported generate lines to flash u-boot-imx8mn-ddr4.imx to the partition of bootloader0 generate lines to flash partition-table-28GB.img to the partition of gpt generate lines to flash dtbo-imx8mn-ddr4.img to the partition of dtbo_a generate lines to flash boot.img to the partition of boot_a generate lines to flash vendor_boot.img to the partition of vendor_boot_a generate lines to flash init_boot.img to the partition of init_boot_a generate lines to flash vbmeta-imx8mn-ddr4.img to the partition of vbmeta_a generate lines to flash super.img to the partition of super uuu script generated, start to invoke uuu with the generated uuu script uuu (Universal Update Utility) for nxp imx chips -- libuuu_1.4.182-0-ga561ed7 Success 0 Failure 1 1:1 1/ 1 [HID(W):LIBUSB_ERROR_TIMEOUT ] SDPS: boot -f u-boot-imx8mn-ddr4-evk-uuu.imx15723 dx@ubuntu:~/android_build/out/target/product/evk_8mn$ uuu -lsusb uuu (Universal Update Utility) for nxp imx chips -- libuuu_1.4.182-0-ga561ed7 Connected Known USB Devices Path Chip Pro Vid Pid BcdVersion ================================================== 1:1 MX815 SDPS: 0x1FC9 0x013E 0x0001 dx@ubuntu:~/android_build/out/target/product/evk_8mn$ |
只有小组成员才能发言,加入小组>>
2135个成员聚集在这个小组
加入小组我的项目我做主,使用GN+Ninja来完成构建系统(VSCode开发RT106X)
37376 浏览 0 评论
NXP IMX8应用处理器快速入门必备:技巧、使用、设计指南
6775 浏览 1 评论
7793 浏览 1 评论
7642 浏览 0 评论
NXP i.MX6UL开发板(linux系统烧录+规格+硬件+模块移植)使用手册
5071 浏览 0 评论
1556浏览 2评论
关于NINA-W132 Wi-Fi模块SPI通信遇到的疑问求解
1207浏览 2评论
如何在MPC PowerPC MCU上首次刷写后禁用BDM?
749浏览 1评论
将HFREFR和LFREFR寄存器值设置为错误的值来将故障注入CMU,但CMU_ISR值始终为零,为什么?
735浏览 1评论
将SPSDK for FRDM-MCX-W71 SDK与VS一起安装时出现hidapi构建错误怎么解决?
678浏览 1评论
/9
GMT+8, 2025-12-1 22:31 , Processed in 0.676117 second(s), Total 70, Slave 53 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1431
