1. 先把默认的Android系统烧写成Ubuntu18.04系统
(1) 下载最新的Ubuntu18.04(GPT) 找到官网首页[资料下载]中的ROC-RK3328-PC的固件中的Ubuntu18.04(GPT),点击下载 下载: ROC-RK3328-PC-UBUNTU18.04-GPT-20200630-1405.img.7z (2) 解压7z文件,得到官方原始镜像ROC-RK3328-PC-UBUNTU18.04-GPT-20200630-1405.img apt-get install p7zip-full 7z x ROC-RK3328-PC-UBUNTU18.04-GPT-20200630-1405.img.7z tree 显示: . ├── pack │ ├── Linux_Upgrade_Tool │ │ ├── config.ini │ │ ├── Linux开发工具使用手册_v1.32.pdf │ │ ├── Readme.txt │ │ └── upgrade_tool │ └── ROC-RK3328-PC-UBUNTU18.04-GPT-20200630-1405.img └── ROC-RK3328-PC-UBUNTU18.04-GPT-20200630-1405.img.7z (3) 为了方便使用,修改原始镜像的名字为: r.img cd pack mv ROC-RK3328-PC-UBUNTU18.04-GPT-20200630-1405.img r.img (4) 烧录原始统一镜像 方式1: 使用上面镜像压缩包中的Linux_Upgrade_Tool,进行烧写 a. cd pack/Linux_Upgrade_Tool b. mv ../r.img ./ c. rk3328插入AV口(RECOVERY按键在里面),一直长按RECOVERY键, 使用电源线的USB连接到电脑上 d. sudo ./upgrade_tool 找到一个设备, 输入1 Program Data in /home/xxx/.config/upgrade_tool List of rocku*** connected DevNo=1 Vid=xxx,Pid=xxx,LocationID=xxx Mode=Loader SerialNo=xxx Found 1 rocku***,Select input DevNo,Rescan press :1 显示: ---------------------Tool Usage --------------------- Help: H Quit: Q Version: V Clear Screen: CS ------------------Upgrade Command ------------------ ChooseDevice: CD ListDevice: LD SwitchDevice: SD UpgradeFirmware: UF UpgradeLoader: UL DownloadImage: DI <-p|-b|-k|-s|-r|-m|-u|-t|-re image> DownloadBoot: DB EraseFlash: EF PartitionList: PL ----------------Professional Command ----------------- TestDevice: TD ResetDevice: RD [subcode] ResetPipe: RP [pipe] ReadCapability: RCB ReadFlashID: RID ReadFlashInfo: RFI ReadChipInfo: RCI ReadSector: RS WriteSector: WS ReadLBA: RL WriteLBA: WL EraseLBA: EL EraseBlock: EB ------------------------------------------------------- e. 烧写镜像, 等待完成 uf r.img 显示: Rocku***>uf r.img Loading firmware... Support Type:RK322H FW Ver:8.1.276 FW Time:2020-06-30 14:05:48 Loader ver:2.50 Loader Time:2020-06-30 11:48:03 Upgrade firmware ok. 方式2: 使用Windows系统,借助AndroidTool烧写统一镜像 a. 下载官网的AndroidTool和RK驱动助手 注意: 下面是官方的推荐, 这里说明下,使用AndroidTool_v2.58, 如果自己之后重新打统一镜像后,升级时会出现rootfs分区不够存储镜像的问题,这里推荐使用AndroidTool_v2.71 烧录工具下载 Windows下: Linux 或者 Android8.1 系统 AndroidTool_v2.58 Android7.1 系统 AndroidTool_v2.38 Android10 系统 AndroidTool_v2.71 Linux下: Linux 系统或者 Android8.1 系统 Upgrade_Tool_v1.34 Android7.1 系统 Upgrade_Tool_v1.24 Android10 系统 Upgrade_Tool_v1.49 b. 安装RK驱动助手和AndroidTool后, 使用电源线通过USB连接到Windows电脑 打开[AndroidTool], 等待显示: 发现一个ADB设备, 点击菜单中[下载镜像]的[切换]按钮 显示变成: 发现一个LOADER设备 c. 选择升级固件: 点击[升级固件], 选择[固件]按钮,双击,选择上面Linux系统的r.img拷贝到windows电脑目录中的r.img 等待一会,不报错,会显示: 固件版本8.1.276 Loader版本: 2.50 芯片信息:RK322H 固件: D:r_imgr.img # 自己电脑的官方原始固件位置 d. 可以点击: [升级固件]页面的[升级]按钮了 会显示:升级信息 测试设备开始 测试设备成功 校验芯片开始 校验芯片成功 获取FlashInfo开始 获取FlashInfo成功 准备IDB开始 准备IDB成功 下载IDB开始 下载IDB成功 下载固件开始 正在下载固件(100%) 下载固件成功 重启设备开始 重启设备成功 2.开机初始配置 通过type-c数据线连接显示屏,插入网线,鼠标,键盘,和电源线, 开机进行初始的网络配置和ssh配置 通过电脑右上侧的网络配置图形页面,配置ip,子网掩码,网关,DNS 修改sshd服务器: sudo vi /etc/ssh/sshd_config 修改为: PermitRootLogin yes sudo /etc/init.d/ssh restart # 重启ssh 之后通过ssh可以连接rk3328设备了, 之后修改ip可以通过ubuntu18.04系统支持的/etc/netplan, 此处不做详细说明 3.部署生产环境 ssh连接rk3328,部署生产环境 部署完成后,可以考虑刻录完整镜像了,用于生产 4.制作根文件系统镜像 说明: 本文采取的打包完整统一镜像的方式为: 使用原厂的原始镜像解包, 替换rootfs.img文件系统, 再使用AndroidTool工具进行打包和烧录 (1). 导出开发板文件系统(参考AIO-3288C的官网资料) a. sudo apt-get install -y ssh rsync b. 在PC机中同步开发板的文件系统,请先将开发板和 PC 机置于同一局域网内。(假设开发板地址为 192.168.9.179) mkdir rootfs sudo rsync -avx :/ ./rootfs c. 此时,rootfs 目录中保存的就是开发板文件系统中的所有文件,可以开始制作根文件系统镜像: dd if=/dev/zero of=rootfs.img bs=1M count=4000 # count大小为了节省空间同时保证可以放下整个系统, 可以在开发板上使用df -h, 我这里为: /root-ro 和 /userdata的大小之和, 即: rootfs+userdata的大小,这个会被制成新的文件系统, 2.6G+1.4G, 同时: du -sh ./rootfs 显示: 3.7G rootfs, 可以使用4000 mkfs.ext4 rootfs.img mkdir temp && sudo mount rootfs.img ./temp sudo cp -rfp rootfs/* temp/ sudo umount temp/ e2fsck -p -f rootfs.img resize2fs -M rootfs.img d. 查看大小: du -sh rootfs.img # 3.8G ./rootfs.img ls -al rootfs.img # 4194304000 4月 30 16:31 rootfs.img 5.制作完整统一镜像 (1). AndroidTool解包原始固件r.img a. 选择[高级功能]中的[解包]按钮前面的[...]按钮, 选中原始固件D:r_imgr.img, 再点击[解包] b. 等待片刻, 在AndroidTool_Release_v2.71Output目录下会生成统一镜像r.img的解包镜像: 包括: boot.bin, firmware.img, Android目录 实际是引导程序bootloader和使用AFPTool打包各个分区镜像生成的firmware.img Android目录实际是firmware.img通过AFPTool解包生成的各个分区镜像,我们主要使用这个目录 (2). 用导出的开发板文件系统rootfs.img 替换 OutputAndroidImage下的原始rootfs.img (3). 同时要修改分区信息表文件parameter.txt中的rootfs分区的大小和userdata分区的起始位置 parameter.txt内容: FIRMWARE_VER: 8.1 MACHINE_MODEL: RK3328 MACHINE_ID: 007 MANUFACTURER: RK3328 MAGIC: 0x5041524B ATAG: 0x00200800 MACHINE: 3328 CHECK_MASK: 0x80 PWR_HLD: 0,0,A,0,1 TYPE: GPT CMDLINE: mtdparts=rk29xxnand:0x00002000@0x00004000(uboot),0x00002000@0x00006000(trust),0x00002000@0x00008000(misc),0x00010000@0x0000a000(boot),0x00010000@0x0001a000(recovery),0x00010000@0x0002a000(backup),0x588400@0x0005a000(rootfs),-@0x5e2400(userdata:grow) uuid:rootfs=614e0000-0000-4b53-8000-1d28000054a9 例如: 0x588400@0x0005a000(rootfs) 扇区大小@起始位置(分区名) 每个扇区512字节, 像我上面rootfs.img大小: 4194304000, 扇区大小: 4194304000/512=8192000 转16进制: 0x7d0000 如果以0x7d0000修改上面的parameter.txt, 则: 0x7d0000@0x0005a000(rootfs),-@0x82a000(userdata:grow) 但是这种很容易在打包镜像完成后,烧写镜像升级时,出现rootfs分区不够存放镜像, 官方在处理这个大小时加上了大约50M大小,在重新计算这个这个扇区数量 可以使用官方的linux打包和解包工具,自动根据rootfs.img的大小,自动修改parameter.txt # ROC-RK3399-PC中的解合包工具(Linux), firefly-rk3399-linux-repack.tgz cd firefly-rk3399-linux-repack tree: . ├── bin/ │ ├── afptool* │ └── rkImageMaker* ├── output/ │ ├── Image/ │ │ ├── boot.img │ │ ├── MiniLoaderAll.bin │ │ ├── misc.img │ │ ├── parameter.txt │ │ ├── recovery.img │ │ ├── rootfs.img │ │ ├── trust.img │ │ └── uboot.img │ └── package-file ├── pack.sh* ├── Readme.md └── unpack.sh* 查看Readme.md, 通过unpack.sh和pack.sh打包和解包,需要在ubuntu18下运行有效,同时安装32位系统支持, afptool和rkImageMaker是32位系统的可执行程序 我这里ubuntu16下只通过pack.sh自动修改parameter.txt,afptool报错不用管. |
(4) 拷贝pack.sh自动修改后的parameter.txt到windows电脑,替换掉 AndroidTool_Release_v2.71OutputAndroidImageparameter.txt
parameter.txt修改后的内容: FIRMWARE_VER: 8.1 MACHINE_MODEL: RK3328 MACHINE_ID: 007 MANUFACTURER: RK3328 MAGIC: 0x5041524B ATAG: 0x00200800 MACHINE: 3328 CHECK_MASK: 0x80 PWR_HLD: 0,0,A,0,1 TYPE: GPT CMDLINE: mtdparts=rk29xxnand:0x00002000@0x00004000(uboot),0x00002000@0x00006000(trust),0x00002000@0x00008000(misc),0x00010000@0x0000a000(boot),0x00010000@0x0001a000(recovery),0x00010000@0x0002a000(backup),0x7e9200@0x0005a000(rootfs),-@0x843200(userdata:grow) uuid:rootfs=614e0000-0000-4b53-8000-1d28000054a9 (5) 打包镜像 Windows下: cd D:AndroidTool_Release_v2.71bin D: AFPTool.exe -pack D:AndroidTool_Release_v2.71OutputAndroid update.img RKImageMaker.exe -RK322H D:AndroidTool_Release_v2.71Outputboot.bin update.img update_new.img -os_type:androidos 在D:AndroidTool_Release_v2.71bin下生成update_new.img, 此为最新的统一完整固件,可以直接使用AndroidTool工具重新烧写镜像,完成开发板到其他开发板的环境备份. 总结 特别说明: 之前我使用官网推荐的AndroidTool_Release_v2.58进行固件的打包和烧写,会出现使用上面这个好的parameter.txt也会出现rootfs分区不够存储镜像的问题,有些坑人! 特别提示: 在完成上面的根文件系统制作,统一镜像的打包后,烧写统一镜像update_new.img, 设备启动后redis和postgresql无法启动,其余正常! 经过测试验证, 经过挖坑填坑, 发现问题出现在redis和postgresql的用户权限管理出现问题, 查看redis和postgresql的相关文件,发现其文件所有者和文件所在组的名称,都变成了用户标识号的UID和GID, 如下: root@firefly:/# ls /etc/postgresql/10/main/ -al total 60 drwxr-xr-x 3 124 132 4096 4月 23 17:32 . drwxr-xr-x 3 124 132 4096 4月 23 17:29 .. drwxr-xr-x 2 124 132 4096 4月 23 17:29 conf.d -rw-r--r-- 1 124 132 315 4月 23 17:29 environment -rw-r--r-- 1 124 132 143 4月 23 17:29 pg_ctl.conf -rw-r----- 1 124 132 4681 4月 23 17:32 pg_hba.conf -rw-r----- 1 124 132 1636 4月 23 17:29 pg_ident.conf -rw-r--r-- 1 124 132 23137 4月 30 16:12 postgresql.conf -rw-r--r-- 1 124 132 317 4月 23 17:29 start.conf 正常的显示为: drwxr-xr-x 3 postgres postgres 4096 4月 23 17:32 . drwxr-xr-x 3 postgres postgres 4096 4月 23 17:29 .. drwxr-xr-x 2 postgres postgres 4096 4月 23 17:29 conf.d -rw-r--r-- 1 postgres postgres 315 4月 23 17:29 environment -rw-r--r-- 1 postgres postgres 143 4月 23 17:29 pg_ctl.conf -rw-r----- 1 postgres postgres 4681 4月 23 17:32 pg_hba.conf -rw-r----- 1 postgres postgres 1636 4月 23 17:29 pg_ident.conf -rw-r--r-- 1 postgres postgres 23137 4月 30 16:12 postgresql.conf -rw-r--r-- 1 postgres postgres 317 4月 23 17:29 start.conf 并且: /etc/passwd的用户管理中postgres的UID和GID, 和上面错误的显示124 132, 并不相符 firefly:x:1000:1000:firefly,,,:/home/firefly:/bin/bash postgres:x:116:123:PostgreSQL administrator,,,:/var/lib/postgresql:/bin/bash redis:x:117:124::/var/lib/redis:/usr/***in/nologin 后来发现自己做文件系统镜像的PC主机的postgres的UID和GID,正好是: 124:132 redis:x:123:131::/var/lib/redis:/bin/false postgres:x:124:132:PostgreSQL administrator,,,:/var/lib/postgresql:/bin/bash 所有最后: 制作了2台环境基本相同的rk3328开发板, 一台用于刻录备份完整镜像, 一台充当制作rootfs.img的pc主机,并且保证这两台开发板的/etc/passwd等用户管理文件的redis和postgres的UID和GID一致, 避免文件所有者和文件所在组的名称,因为找不到相同的UID和GID,变成相应的ID值,同时文件无法使用. |
(1) 下载最新的Ubuntu18.04(GPT) 找到官网首页[资料下载]中的ROC-RK3328-PC的固件中的Ubuntu18.04(GPT),点击下载 下载: ROC-RK3328-PC-UBUNTU18.04-GPT-20200630-1405.img.7z (2) 解压7z文件,得到官方原始镜像ROC-RK3328-PC-UBUNTU18.04-GPT-20200630-1405.img apt-get install p7zip-full 7z x ROC-RK3328-PC-UBUNTU18.04-GPT-20200630-1405.img.7z tree 显示: 。 ├── pack │ ├── Linux_Upgrade_Tool │ │ ├── config.ini │ │ ├── Linux开发工具使用手册_v1.32.pdf │ │ ├── Readme.txt │ │ └── upgrade_tool │ └── ROC-RK3328-PC-UBUNTU18.04-GPT-20200630-1405.img └── ROC-RK3328-PC-UBUNTU18.04-GPT-20200630-1405.img.7z (3) 为了方便使用,修改原始镜像的名字为: r.img cd pack mv ROC-RK3328-PC-UBUNTU18.04-GPT-20200630-1405.img r.img (4) 烧录原始统一镜像 方式1: 使用上面镜像压缩包中的Linux_Upgrade_Tool,进行烧写 a. cd pack/Linux_Upgrade_Tool b. mv 。./r.img 。/ c. rk3328插入AV口(RECOVERY按键在里面),一直长按RECOVERY键, 使用电源线的USB连接到电脑上 d. sudo 。/upgrade_tool 找到一个设备, 输入1 Program Data in /home/xxx/.config/upgrade_tool List of rocku*** connected DevNo=1 Vid=xxx,Pid=xxx,LocationID=xxx Mode=Loader SerialNo=xxx Found 1 rocku***,Select input DevNo,Rescan press 《R》,Quit press 《Q》:1 显示: ---------------------Tool Usage --------------------- Help: H Quit: Q Version: V Clear Screen: CS ------------------Upgrade Command ------------------ ChooseDevice: CD ListDevice: LD SwitchDevice: SD UpgradeFirmware: UF 《Firmware》 [-noreset] UpgradeLoader: UL 《Loader》 [-noreset] DownloadImage: DI 《-p|-b|-k|-s|-r|-m|-u|-t|-re image》 DownloadBoot: DB 《Loader》 EraseFlash: EF 《Loader|firmware》 [DirectLBA] PartitionList: PL ----------------Professional Command ----------------- TestDevice: TD ResetDevice: RD [subcode] ResetPipe: RP [pipe] ReadCapability: RCB ReadFlashID: RID ReadFlashInfo: RFI ReadChipInfo: RCI ReadSector: RS 《BeginSec》 《SectorLen》 [-decode] [File] WriteSector: WS 《BeginSec》 《File》 ReadLBA: RL 《BeginSec》 《SectorLen》 [File] WriteLBA: WL 《BeginSec》 《File》 EraseLBA: EL 《BeginSec》 《EraseCount》 EraseBlock: EB 《CS》 《BeginBlock》 《BlokcLen》 [--Force] ------------------------------------------------------- e. 烧写镜像, 等待完成 uf r.img 显示: Rocku***》uf r.img Loading firmware.。. Support Type:RK322H FW Ver:8.1.276 FW Time:2020-06-30 14:05:48 Loader ver:2.50 Loader Time:2020-06-30 11:48:03 Upgrade firmware ok. 方式2: 使用Windows系统,借助AndroidTool烧写统一镜像 a. 下载官网的AndroidTool和RK驱动助手 注意: 下面是官方的推荐, 这里说明下,使用AndroidTool_v2.58, 如果自己之后重新打统一镜像后,升级时会出现rootfs分区不够存储镜像的问题,这里推荐使用AndroidTool_v2.71 烧录工具下载 Windows下: Linux 或者 Android8.1 系统 AndroidTool_v2.58 Android7.1 系统 AndroidTool_v2.38 Android10 系统 AndroidTool_v2.71 Linux下: Linux 系统或者 Android8.1 系统 Upgrade_Tool_v1.34 Android7.1 系统 Upgrade_Tool_v1.24 Android10 系统 Upgrade_Tool_v1.49 b. 安装RK驱动助手和AndroidTool后, 使用电源线通过USB连接到Windows电脑 打开[AndroidTool], 等待显示: 发现一个ADB设备, 点击菜单中[下载镜像]的[切换]按钮 显示变成: 发现一个LOADER设备 c. 选择升级固件: 点击[升级固件], 选择[固件]按钮,双击,选择上面Linux系统的r.img拷贝到windows电脑目录中的r.img 等待一会,不报错,会显示: 固件版本8.1.276 Loader版本: 2.50 芯片信息:RK322H 固件: D:r_imgr.img # 自己电脑的官方原始固件位置 d. 可以点击: [升级固件]页面的[升级]按钮了 会显示:升级信息 测试设备开始 测试设备成功 校验芯片开始 校验芯片成功 获取FlashInfo开始 获取FlashInfo成功 准备IDB开始 准备IDB成功 下载IDB开始 下载IDB成功 下载固件开始 正在下载固件(100%) 下载固件成功 重启设备开始 重启设备成功 2.开机初始配置 通过type-c数据线连接显示屏,插入网线,鼠标,键盘,和电源线, 开机进行初始的网络配置和ssh配置 通过电脑右上侧的网络配置图形页面,配置ip,子网掩码,网关,DNS 修改sshd服务器: sudo vi /etc/ssh/sshd_config 修改为: PermitRootLogin yes sudo /etc/init.d/ssh restart # 重启ssh 之后通过ssh可以连接rk3328设备了, 之后修改ip可以通过ubuntu18.04系统支持的/etc/netplan, 此处不做详细说明 3.部署生产环境 ssh连接rk3328,部署生产环境 部署完成后,可以考虑刻录完整镜像了,用于生产 4.制作根文件系统镜像 说明: 本文采取的打包完整统一镜像的方式为: 使用原厂的原始镜像解包, 替换rootfs.img文件系统, 再使用AndroidTool工具进行打包和烧录 (1)。 导出开发板文件系统(参考AIO-3288C的官网资料) a. sudo apt-get install -y ssh rsync b. 在PC机中同步开发板的文件系统,请先将开发板和 PC 机置于同一局域网内。(假设开发板地址为 192.168.9.179) mkdir rootfs sudo rsync -avx root@192.168.9.179:/ 。/rootfs c. 此时,rootfs 目录中保存的就是开发板文件系统中的所有文件,可以开始制作根文件系统镜像: dd if=/dev/zero of=rootfs.img bs=1M count=4000 # count大小为了节省空间同时保证可以放下整个系统, 可以在开发板上使用df -h, 我这里为: /root-ro 和 /userdata的大小之和, 即: rootfs+userdata的大小,这个会被制成新的文件系统, 2.6G+1.4G, 同时: du -sh 。/rootfs 显示: 3.7G rootfs, 可以使用4000 mkfs.ext4 rootfs.img mkdir temp && sudo mount rootfs.img 。/temp sudo cp -rfp rootfs/* temp/ sudo umount temp/ e2fsck -p -f rootfs.img resize2fs -M rootfs.img d. 查看大小: du -sh rootfs.img # 3.8G 。/rootfs.img ls -al rootfs.img # 4194304000 4月 30 16:31 rootfs.img 5.制作完整统一镜像 (1)。 AndroidTool解包原始固件r.img a. 选择[高级功能]中的[解包]按钮前面的[。..]按钮, 选中原始固件D:r_imgr.img, 再点击[解包] b. 等待片刻, 在AndroidTool_Release_v2.71Output目录下会生成统一镜像r.img的解包镜像: 包括: boot.bin, firmware.img, Android目录 实际是引导程序bootloader和使用AFPTool打包各个分区镜像生成的firmware.img Android目录实际是firmware.img通过AFPTool解包生成的各个分区镜像,我们主要使用这个目录 (2)。 用导出的开发板文件系统rootfs.img 替换 OutputAndroidImage下的原始rootfs.img (3)。 同时要修改分区信息表文件parameter.txt中的rootfs分区的大小和userdata分区的起始位置 parameter.txt内容: FIRMWARE_VER: 8.1 MACHINE_MODEL: RK3328 MACHINE_ID: 007 MANUFACTURER: RK3328 MAGIC: 0x5041524B ATAG: 0x00200800 MACHINE: 3328 CHECK_MASK: 0x80 PWR_HLD: 0,0,A,0,1 TYPE: GPT CMDLINE: mtdparts=rk29xxnand:0x00002000@0x00004000(uboot),0x00002000@0x00006000(trust),0x00002000@0x00008000(misc),0x00010000@0x0000a000(boot),0x00010000@0x0001a000(recovery),0x00010000@0x0002a000(backup),0x588400@0x0005a000(rootfs),-@0x5e2400(userdata:grow) uuid:rootfs=614e0000-0000-4b53-8000-1d28000054a9 例如: 0x588400@0x0005a000(rootfs) 扇区大小@起始位置(分区名) 每个扇区512字节, 像我上面rootfs.img大小: 4194304000, 扇区大小: 4194304000/512=8192000 转16进制: 0x7d0000 如果以0x7d0000修改上面的parameter.txt, 则: 0x7d0000@0x0005a000(rootfs),-@0x82a000(userdata:grow) 但是这种很容易在打包镜像完成后,烧写镜像升级时,出现rootfs分区不够存放镜像, 官方在处理这个大小时加上了大约50M大小,在重新计算这个这个扇区数量 可以使用官方的linux打包和解包工具,自动根据rootfs.img的大小,自动修改parameter.txt # ROC-RK3399-PC中的解合包工具(Linux), firefly-rk3399-linux-repack.tgz cd firefly-rk3399-linux-repack tree: 。 ├── bin/ │ ├── afptool* │ └── rkImageMaker* ├── output/ │ ├── Image/ │ │ ├── boot.img │ │ ├── MiniLoaderAll.bin │ │ ├── misc.img │ │ ├── parameter.txt │ │ ├── recovery.img │ │ ├── rootfs.img │ │ ├── trust.img │ │ └── uboot.img │ └── package-file ├── pack.sh* ├── Readme.md └── unpack.sh* 查看Readme.md, 通过unpack.sh和pack.sh打包和解包,需要在ubuntu18下运行有效,同时安装32位系统支持, afptool和rkImageMaker是32位系统的可执行程序 我这里ubuntu16下只通过pack.sh自动修改parameter.txt,afptool报错不用管。 (4) 拷贝pack.sh自动修改后的parameter.txt到windows电脑,替换掉 AndroidTool_Release_v2.71OutputAndroidImageparameter.txt parameter.txt修改后的内容: FIRMWARE_VER: 8.1 MACHINE_MODEL: RK3328 MACHINE_ID: 007 MANUFACTURER: RK3328 MAGIC: 0x5041524B ATAG: 0x00200800 MACHINE: 3328 CHECK_MASK: 0x80 PWR_HLD: 0,0,A,0,1 TYPE: GPT CMDLINE: mtdparts=rk29xxnand:0x00002000@0x00004000(uboot),0x00002000@0x00006000(trust),0x00002000@0x00008000(misc),0x00010000@0x0000a000(boot),0x00010000@0x0001a000(recovery),0x00010000@0x0002a000(backup),0x7e9200@0x0005a000(rootfs),-@0x843200(userdata:grow) uuid:rootfs=614e0000-0000-4b53-8000-1d28000054a9 (5) 打包镜像 Windows下: cd D:AndroidTool_Release_v2.71bin D: AFPTool.exe -pack D:AndroidTool_Release_v2.71OutputAndroid update.img RKImageMaker.exe -RK322H D:AndroidTool_Release_v2.71Outputboot.bin update.img update_new.img -os_type:androidos 在D:AndroidTool_Release_v2.71bin下生成update_new.img, 此为最新的统一完整固件,可以直接使用AndroidTool工具重新烧写镜像,完成开发板到其他开发板的环境备份。 总结 特别说明: 之前我使用官网推荐的AndroidTool_Release_v2.58进行固件的打包和烧写,会出现使用上面这个好的parameter.txt也会出现rootfs分区不够存储镜像的问题,有些坑人! |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
基于米尔瑞芯微RK3576核心板/开发板的人脸疲劳检测应用方案
343 浏览 0 评论
696 浏览 1 评论
602 浏览 1 评论
1833 浏览 1 评论
3083 浏览 1 评论
GMT+8, 2024-12-20 14:54 , Processed in 0.822330 second(s), Total 78, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
