扫一扫,分享给好友
问题:用rkmedia_vi_rknn_venc_rtsp_test部署自己rknn模型后界面白色部分变成紫色,识别到的框都是错误的。该rknn在电脑测试输出准确。 rknn信息:输入NCHW,方差1均值0。rknn模型无量化。 请问是否以下设置出错?转rknn已经设置预处理,是否需要自己写C++预处理?
设置: inputs[0].index = 0; inputs[0].type = RKNN_TENSOR_FLOAT16; //换uint8也不行,设置存疑 inputs[0].size = rga_buffer_model_input_size; inputs[0].fmt = RKNN_TENSOR_NCHW; //input tensors n_dims=4 dims=[1 3 576 768] 此处设置存疑 inputs[0].buf = rga_buffer_model_input; inputs[0].pass_through = 0; //从NHWC转换成 NCHW 的过程 outputs[0].want_float = 0; //无量化 输出: [root@RV1126_RV1109:/]# ./oem/usr/bin/wbc -c /oem/usr/share/rtsp-nn.cfg -l /oem/usr/share/rknn_model/nano_labels_list.txt -p /oem/usr/share/rknn_model/wbc.rknn media get entity by name: stream_cif_dvp_id0 is null media get entity by name: stream_cif_dvp_id1 is null media get entity by name: stream_cif_dvp_id2 is null media get entity by name: stream_cif_dvp_id3 is null media get entity by name: rkcif-lvds-subdev is null media get entity by name: rkcif-lite-lvds-subdev is null media get entity by name: stream_cif is null media get entity by name: rkcif-dvp-sof is null media get entity by name: rkisp-mpfbc-subdev is null media get entity by name: rkisp_dmapath is null media get entity by name: rockchip-mipi-dphy-rx is null media get entity by name: rkcif_dvp is null media get entity by name: rkcif_dvp is null media get entity by name: rkcif_lite_mipi_lvds is null [11:35:29.340137][CAMHW]:XCAM ERROR CamHwIsp20.cpp:1022: No free isp&ispp needed by fake camera! rcfg path is /oem/usr/share/rtsp-nn.cfg LABEL_NALE_TXT_PATH is /oem/usr/share/rknn_model/nano_labels_list.txt MODEL_PATH is /oem/usr/share/rknn_model/wbc.rknn #CameraIdx: 0 rtsp path = /live/main_stream. video_type = 5. width = 768. height = 576. video path =rkispp_scale0. image type = 4. rtsp path = /live/sub_stream. video_type = 5. width = 768. height = 576. video path =rkispp_scale1. image type = 4. init rtsp [INFO rtsp_demo.c:281:rtsp_new_demo] rtsp server demo starting on port 554 init mpi ##RKMEDIA Log level: 2 [RKMEDIA][SYS][Info]:text is all=2 [RKMEDIA][SYS][Info]:module is all, log_level is 2 [DEBUG rtsp_demo.c:481:rtsp_new_session] add session path: /live/main_stream[RKMEDIA][SYS][Info]:RK_MPI_SYS_Bind: Bind Mode[VI]:Chn[1] to Mode[VENC]:Chn[1]... rtsp video create rknn_list success x_rate is 1.000000, y_rate is 1.000000 #Start GetMediaBuffer thread, arg:(nil) Loading model ... [RKMEDIA][SYS][Info]:Camera 0 stream 22 is started mpp[657]: h264e_sps: set level to 3.1 mpp[657]: h264e_sps: set level to 3.1 [DEBUG utils.c:160:rtsp_codec_data_parse_from_user_h264] sps 24 [DEBUG utils.c:168:rtsp_codec_data_parse_from_user_h264] pps 4 [DEBUG utils.c:160:rtsp_codec_data_parse_from_user_h264] sps 24 [DEBUG utils.c:168:rtsp_codec_data_parse_from_user_h264] pps 4 model input num: 1, output num: 1 input tensors: index=0 name=data_278 n_dims=4 dims=[1 3 576 768] n_elems=1327104 size=2654208 fmt=0 type=1 qnt_type=0 fl=-81 zp=210095 scale=0.000000 output tensors: index=0 name=Transpose_Transpose_526/out0_0 n_dims=3 dims=[0 1 9180 35] n_elems=321300 size=642600 fmt=0 type=1 qnt_type=0 fl=-81 zp=210095 scale=0.000000 Had init the rga dev ctx = 0x922b8 rga_api version 1.2.6_[0] (RGA is compiling with meson base: $PRODUCT_BASE) 开始识别 |
1个回答
紫色好像亮度过高就会出现,摄像头是400W HDR高动态红外增强广角 OS04A10 MIPI接口24Pin 适配RV1126。rkmedia_vi_rknn_venc_rtsp_test中nv12转rgb24等vi-rstp这一块我没有修改。
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
谁有3566+电池+POE充电的方案,有个项目需要用该功能的主板
437 浏览 0 评论
RK3588的GMAC0与PHY的参考时钟电平匹配问题??????
4425 浏览 1 评论
请问各位大佬,如何解决,瑞芯微 RV1126B 使用 mpp 自带工具 调试时,内核直接报错崩溃!
1802 浏览 0 评论
使用rk3568开发板,核0\\1\\3运行linux,核2运行hal,在核0中怎么关闭核2
2359 浏览 0 评论
2363 浏览 0 评论
/9
GMT+8, 2025-12-2 07:09 , Processed in 0.684801 second(s), Total 70, Slave 52 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
6340
