增加了这两个文件,可以注册CAN了,我调试没有进入can的管脚配置函数
/*-------------------------- CAN CONFIG BEGIN --------------------------*/ /** if you want to use CAN you can use the following instructions. * * STEP 1, open CAN driver framework support in the RT-Thread Settings file * * STEP 2, define macro related to the CAN * such as #define BSP_USING_CAN * #define BSP_USING_CAN1 * * STEP 3, copy your adc init function from stm32xxxx_hal_msp.c generated by stm32cubemx to the end of board.c file * such as void HAL_CAN_MspInit(CAN_HandleTypeDef* canHandle) * * STEP 4, modify your stm32xxxx_hal_config.h file to support adc peripherals. define macro related to the peripherals * such as #define HAL_CAN_MODULE_ENABLED * */ #define BSP_USING_CAN #ifdef BSP_USING_CAN #define BSP_USING_CAN1 #endif /*-------------------------- CAN CONFIG END --------------------------*/ 已经在board.c添加了,调试时没有进入这个函数 void HAL_CAN_MspInit(CAN_HandleTypeDef* canHandle) { GPIO_InitTypeDef GPIO_InitStruct = {0}; if(canHandle->Instance==CAN1) { /* USER CODE BEGIN CAN1_MspInit 0 */ /* USER CODE END CAN1_MspInit 0 */ /* CAN1 clock enable */ __HAL_RCC_CAN1_CLK_ENABLE(); __HAL_RCC_GPIOA_CLK_ENABLE(); /**CAN1 GPIO Configuration PA11 ------> CAN1_RX PA12 ------> CAN1_TX */ GPIO_InitStruct.Pin = GPIO_PIN_11|GPIO_PIN_12; GPIO_InitStruct.Mode = GPIO_MODE_AF_PP; GPIO_InitStruct.Pull = GPIO_NOPULL; GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH; GPIO_InitStruct.Alternate = GPIO_AF9_CAN1; HAL_GPIO_Init(GPIOA, &GPIO_InitStruct); /* USER CODE BEGIN CAN1_MspInit 1 */ /* USER CODE END CAN1_MspInit 1 */ } } |
这个应该是初始化时已经调用了,看你的断点是什么时候打上去的?
打上断点才调试的
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
飞凌嵌入式-ELFBOARD 常用的USB接口及其不同版本介绍第1期
851 浏览 0 评论
【Vision Board创客营连载体验】RA8D1-Vision Board上OSPI-Flash实践
1336 浏览 0 评论
I.MX6ULL-飞凌 ElfBoard ELF1板卡- 应用层更改引脚复用的方法
3611 浏览 0 评论
1724 浏览 0 评论
【英飞凌PSoC 6 RTT开发板试用】串口测试标准输入输出重定向
1246 浏览 0 评论
60481 浏览 21 评论
289512 浏览 79 评论
13720 浏览 52 评论
16524 浏览 55 评论
54806 浏览 31 评论
GMT+8, 2024-7-1 17:06 , Processed in 1.721051 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
