电子发烧友论坛|
买了一块ESP32-S3的开发板,在VSCODE环境下安装ESP-IDFV4.3.2成功,编译加烧写均可以完成,但烧写后开发板上运行不正常,到论坛上查到说明需要ESP-IDF V4.4,安装后编译总有问题。
> Executing task: cmake -G Ninja -DPYTHON_DEPS_CHECKED=1 -DESP_PLATFORM=1 .. < -- Found Git: D:/.espressif/tools/idf-git/2.30.1/cmd/git.exe (found version "2.30.1.windows.1") fatal: not a git repository (or any of the parent directories): .git -- The C compiler identification is GNU 8.4.0 -- The CXX compiler identification is GNU 8.4.0 -- The ASM compiler identification is GNU -- Found assembler: D:/.espressif/tools/xtensa-esp32s3-elf/esp-2021r2-8.4.0/xtensa-esp32s3-elf/bin/xtensa-esp32s3-elf-gcc.exe -- Detecting C compiler ABI info -- Detecting C compiler ABI info - done -- Check for working C compiler: D:/.espressif/tools/xtensa-esp32s3-elf/esp-2021r2-8.4.0/xtensa-esp32s3-elf/bin/xtensa-esp32s3-elf-gcc.exe - skipped -- Detecting C compile features -- Detecting C compile features - done -- Detecting CXX compiler ABI info -- Detecting CXX compiler ABI info - done -- Check for working CXX compiler: D:/.espressif/tools/xtensa-esp32s3-elf/esp-2021r2-8.4.0/xtensa-esp32s3-elf/bin/xtensa-esp32s3-elf-g++.exe - skipped -- Detecting CXX compile features -- Detecting CXX compile features - done -- Project is not inside a git repository, or git repository has no commits; will not use 'git describe' to determine PROJECT_VER. -- Building ESP-IDF components for target esp32s3 -- Project sdkconfig file E:/ESP32-S3/esp32_demo/hello_world/sdkconfig CMake Error at D:/ESP32/esp-idf/tools/cmake/component.cmake:301 (message): Include directory 'D:/ESP32/esp-idf/components/mbedtls/mbedtls/include' is not a directory. Call Stack (most recent call first): D:/ESP32/esp-idf/tools/cmake/component.cmake:472 (__component_add_include_dirs) D:/ESP32/esp-idf/components/mbedtls/CMakeLists.txt:10 (idf_component_register) -- Configuring incomplete, errors occurred! See also "E:/ESP32-S3/esp32_demo/hello_world/build/CMakeFiles/CMakeOutput.log". 终端进程“C:WINDOWSSystem32WindowsPowerShellv1.0powershell.exe -Command cmake -G Ninja -DPYTHON_DEPS_CHECKED=1 -DESP_PLATFORM=1 ..”已终止,退出代码: 1。 |
只有小组成员才能发言,加入小组>>
933 浏览 0 评论
1653 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1284 浏览 1 评论
1218 浏览 1 评论
4959 浏览 2 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1249浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
927浏览 3评论
2329浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2524浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1051浏览 2评论
/9
GMT+8, 2025-12-1 18:17 , Processed in 0.405610 second(s), Total 39, Slave 32 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
684
