使用例程执行 . $HOME/esp/esp-idf/export.sh 命令进入IDF环境时弹出那么多警告是怎么回事?
Detecting the Python interpreter Checking "python" ... Python 3.6.9 "python" has been detected Adding ESP-IDF tools to PATH... Using Python interpreter in /home/jk007/.espressif/python_env/idf4.4_py3.6_env/bin/python Checking if Python packages are up to date... Python requirements from /home/jk007/esp/esp-idf/requirements.txt are satisfied. Added the following directories to PATH: /home/jk007/esp/esp-idf/components/esptool_py/esptool /home/jk007/esp/esp-idf/components/espcoredump /home/jk007/esp/esp-idf/components/partition_table /home/jk007/esp/esp-idf/components/app_update Done! You can now compile ESP-IDF projects. Go to the project directory and run: idf.py build Traceback (most recent call last): File "/home/jk007/esp/esp-idf/tools/idf.py", line 812, in main() File "/home/jk007/esp/esp-idf/tools/idf.py", line 730, in main cli(sys.argv[1:], prog_name=PROG, complete_var='_IDF.PY_COMPLETE') File "/home/jk007/.espressif/python_env/idf4.4_py3.6_env/lib/python3.6/site-packages/click/core.py", line 1137, in __call__ return self.main(*args, **kwargs) File "/home/jk007/.espressif/python_env/idf4.4_py3.6_env/lib/python3.6/site-packages/click/core.py", line 1057, in main self._main_shell_completion(extra, prog_name, complete_var) File "/home/jk007/.espressif/python_env/idf4.4_py3.6_env/lib/python3.6/site-packages/click/core.py", line 1132, in _main_shell_completion rv = shell_complete(self, ctx_args, prog_name, complete_var, instruction) File "/home/jk007/.espressif/python_env/idf4.4_py3.6_env/lib/python3.6/site-packages/click/shell_completion.py", line 45, in shell_complete echo(comp.source()) File "/home/jk007/.espressif/python_env/idf4.4_py3.6_env/lib/python3.6/site-packages/click/shell_completion.py", line 324, in source self._check_version() File "/home/jk007/.espressif/python_env/idf4.4_py3.6_env/lib/python3.6/site-packages/click/shell_completion.py", line 320, in _check_version _("Couldn't detect Bash version, shell completion is not supported.") RuntimeError: Couldn't detect Bash version, shell completion is not supported. |
只有小组成员才能发言,加入小组>>
944 浏览 0 评论
1671 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1330 浏览 1 评论
1233 浏览 1 评论
5015 浏览 2 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1252浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
927浏览 3评论
2333浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2526浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1051浏览 2评论
/9
GMT+8, 2025-12-2 00:29 , Processed in 0.450992 second(s), Total 39, Slave 32 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
466
