esp32-c3f 烧efuse复位后无法计算sha256,必须重新上电
测试了用不用batch mode都会概率出现 模块为 ESP32-C3-MINI-1-N4 程序 Hello world 日志: ESP-ROM:esp32c3-api1-20210207 Build:Feb 7 2021 rst:0x15 (USB_UART_CHIP_RESET),boot:0x9 (SPI_FAST_FLASH_BOOT) Saved PC:0x400462e2 SPIWP:0xee mode:DIO, clock div:2 load:0x3fcd6100,len:0x1dbc load:0x403ce000,len:0x9dc load:0x403d0000,len:0x31d0 entry 0x403ce000 I (26) boot: ESP-IDF v4.4-dev-3042-g220590d599-dirty 2nd stage bootloader I (26) boot: compile time 12:09:42 D (26) bootloader_flash: XMC chip detected by RDID (00204016), skip. D (32) bootloader_flash: mmu set block paddr=0x00000000 (was 0xffffffff) I (39) boot: chip revision: 3 D (43) boot.esp32c3: magic e9 D (46) boot.esp32c3: segments 03 D (49) boot.esp32c3: spi_mode 02 D (52) boot.esp32c3: spi_speed 00 D (56) boot.esp32c3: spi_size 02 I (59) boot.esp32c3: SPI Speed : 40MHz I (64) boot.esp32c3: SPI Mode : DIO I (69) boot.esp32c3: SPI Flash Size : 4MB D (73) boot: Enabling RTCWDT(9000 ms) I (77) boot: Enabling RNG early entropy source... D (83) bootloader_flash: mmu set paddr=00010000 count=1 size=c00 src_addr=10000 src_addr_aligned=10000 D (92) boot: mapped partition table 0x10000 at 0x3c000000 D (97) flash_parts: partition table verified, 4 entries I (103) boot: Partition Table: I (106) boot: ## Label Usage Type ST Offset Length D (114) boot: load partition table entry 0x3c000000 D (119) boot: type=1 subtype=2 I (122) boot: 0 nvs WiFi data 01 02 00011000 00006000 D (129) boot: load partition table entry 0x3c000020 D (134) boot: type=1 subtype=1 I (137) boot: 1 phy_init RF data 01 01 00017000 00001000 D (145) boot: load partition table entry 0x3c000040 D (150) boot: type=0 subtype=0 I (153) boot: 2 factory factory app 00 00 00020000 00100000 I (161) boot: End of partition table D (165) boot: Trying partition index -1 offs 0x20000 size 0x100000 D (171) esp_image: reading image header @ 0x20000 D (176) bootloader_flash: mmu set block paddr=0x00020000 (was 0xffffffff) D (183) esp_image: image header: 0xe9 0x06 0x02 0x02 403802d2 I (189) esp_image: segment 0: paddr=00020020 vaddr=3c020020 size=067b0h ( 26544) map D (197) esp_image: free data page_count 0x0000003f D (202) bootloader_flash: mmu set paddr=00020000 count=1 size=67b0 src_addr=20020 src_addr_aligned=20000 D (217) bootloader_flash: mmu set block paddr=0x00020000 (was 0xffffffff) I (218) esp_image: segment 1: paddr=000267d8 vaddr=3fc89a00 size=01374h ( 4980) load D (227) esp_image: free data page_count 0x0000003f D (232) bootloader_flash: mmu set paddr=00020000 count=1 size=1374 src_addr=267d8 src_addr_aligned=20000 D (242) bootloader_flash: mmu set block paddr=0x00020000 (was 0xffffffff) I (248) esp_image: segment 2: paddr=00027b54 vaddr=40380000 size=084c4h ( 33988) load D (257) esp_image: free data page_count 0x0000003f D (261) bootloader_flash: mmu set paddr=00020000 count=2 size=84c4 src_addr=27b54 src_addr_aligned=20000 D (279) bootloader_flash: mmu set block paddr=0x00030000 (was 0xffffffff) I (280) esp_image: segment 3: paddr=00030020 vaddr=42000020 size=14df8h ( 85496) map D (286) esp_image: free data page_count 0x0000003f D (291) bootloader_flash: mmu set paddr=00030000 count=2 size=14df8 src_addr=30020 src_addr_aligned=30000 D (320) bootloader_flash: mmu set block paddr=0x00040000 (was 0xffffffff) I (320) esp_image: segment 4: paddr=00044e20 vaddr=403884c4 size=01338h ( 4920) load D (324) esp_image: free data page_count 0x0000003f D (329) bootloader_flash: mmu set paddr=00040000 count=1 size=1338 src_addr=44e20 src_addr_aligned=40000 D (339) bootloader_flash: mmu set block paddr=0x00040000 (was 0xffffffff) I (345) esp_image: segment 5: paddr=00046160 vaddr=50000000 size=00010h ( 16) load D (354) esp_image: free data page_count 0x0000003f D (358) bootloader_flash: mmu set paddr=00040000 count=1 size=10 src_addr=46160 src_addr_aligned=40000 D (368) bootloader_flash: mmu set block paddr=0x00040000 (was 0xffffffff) D (375) boot: Calculated hash: aa398efa12618d1ac337b4ba0817ea0512046b8e7ed147d2ec8a60bd49ea97d4 I (386) boot: Loaded app from partition at offset 0x20000 I (390) boot: Disabling RNG early entropy source... D (395) boot: Mapping segment 0 as DROM D (399) boot: Mapping segment 3 as IROM D (403) boot: calling set_cache_and_start_app D (407) boot: configure drom and irom and start D (412) boot: start: 0x403802d2 0x403802d2: call_start_cpu0 at D:/Program_Files/esp-idf/components/esp_system/port/cpu_start.c:270 I (415) cpu_start: Pro cpu up. I (431) cpu_start: Pro cpu start user code I (431) cpu_start: cpu freq: 160000000 I (431) cpu_start: Application information: I (433) cpu_start: Project name: hello-world I (439) cpu_start: App version: 1 I (443) cpu_start: Compile time: Dec 10 2021 12:09:43 I (449) cpu_start: ELF file SHA256: 63af5056a1faa2f8... I (455) cpu_start: ESP-IDF: v4.4-dev-3042-g220590d599-dirty I (462) heap_init: Initializing. RAM available for dynamic allocation: I (469) heap_init: At 3FC8BD30 len 000342D0 (208 KiB): DRAM I (476) heap_init: At 3FCC0000 len 0001F060 (124 KiB): STACK/DRAM I (482) heap_init: At 50000010 len 00001FF0 (7 KiB): RTCRAM I (489) spi_flash: detected chip: generic I (490) spi_flash: flash io: dio I (491) sleep: Configure to isolate all GPIO pins in sleep state I (491) sleep: Enable automatic switching of GPIO sleep configuration I (492) cpu_start: Starting scheduler. I (492) efuse: Batch mode of writing fields is enabled ESP-ROM:esp32c3-api1-20210207 Build:Feb 7 2021 rst:0x8 (TG1WDT_SYS_RST),boot:0x9 (SPI_FAST_FLASH_BOOT) Saved PC:0x4004c4cc SPIWP:0xee mode:DIO, clock div:2 load:0x3fcd6100,len:0x1dbc load:0x403ce000,len:0x9dc load:0x403d0000,len:0x31d0 entry 0x403ce000 I (25) boot: ESP-IDF v4.4-dev-3042-g220590d599-dirty 2nd stage bootloader I (25) boot: compile time 12:09:42 D (26) bootloader_flash: XMC chip detected by RDID (00204016), skip. D (32) bootloader_flash: mmu set block paddr=0x00000000 (was 0xffffffff) I (39) boot: chip revision: 3 D (42) boot.esp32c3: magic e9 D (45) boot.esp32c3: segments 03 D (49) boot.esp32c3: spi_mode 02 D (52) boot.esp32c3: spi_speed 00 D (55) boot.esp32c3: spi_size 02 I (59) boot.esp32c3: SPI Speed : 40MHz I (64) boot.esp32c3: SPI Mode : DIO I (68) boot.esp32c3: SPI Flash Size : 4MB W (73) boot.esp32c3: PRO CPU has been reset by WDT. D (78) boot: Enabling RTCWDT(9000 ms) I (82) boot: Enabling RNG early entropy source... D (88) bootloader_flash: mmu set paddr=00010000 count=1 size=c00 src_addr=10000 src_addr_aligned=10000 D (97) boot: mapped partition table 0x10000 at 0x3c000000 D (102) flash_parts: partition table verified, 4 entries I (108) boot: Partition Table: I (112) boot: ## Label Usage Type ST Offset Length D (119) boot: load partition table entry 0x3c000000 D (124) boot: type=1 subtype=2 I (127) boot: 0 nvs WiFi data 01 02 00011000 00006000 D (135) boot: load partition table entry 0x3c000020 D (139) boot: type=1 subtype=1 I (143) boot: 1 phy_init RF data 01 01 00017000 00001000 D (150) boot: load partition table entry 0x3c000040 D (155) boot: type=0 subtype=0 I (158) boot: 2 factory factory app 00 00 00020000 00100000 I (166) boot: End of partition table D (170) boot: Trying partition index -1 offs 0x20000 size 0x100000 D (176) esp_image: reading image header @ 0x20000 D (181) bootloader_flash: mmu set block paddr=0x00020000 (was 0xffffffff) D (188) esp_image: image header: 0xe9 0x06 0x02 0x02 403802d2 I (194) esp_image: segment 0: paddr=00020020 vaddr=3c020020 size=067b0h ( 26544) map D (202) esp_image: free data page_count 0x0000003f D (207) bootloader_flash: mmu set paddr=00020000 count=1 size=67b0 src_addr=20020 src_addr_aligned=20000 D (223) bootloader_flash: mmu set block paddr=0x00020000 (was 0xffffffff) I (223) esp_image: segment 1: paddr=000267d8 vaddr=3fc89a00 size=01374h ( 4980) load D (232) esp_image: free data page_count 0x0000003f D (237) bootloader_flash: mmu set paddr=00020000 count=1 size=1374 src_addr=267d8 src_addr_aligned=20000 D (248) bootloader_flash: mmu set block paddr=0x00020000 (was 0xffffffff) I (253) esp_image: segment 2: paddr=00027b54 vaddr=40380000 size=084c4h ( 33988) load D (262) esp_image: free data page_count 0x0000003f D (267) bootloader_flash: mmu set paddr=00020000 count=2 size=84c4 src_addr=27b54 src_addr_aligned=20000 D (285) bootloader_flash: mmu set block paddr=0x00030000 (was 0xffffffff) I (285) esp_image: segment 3: paddr=00030020 vaddr=42000020 size=14df8h ( 85496) map D (291) esp_image: free data page_count 0x0000003f D (296) bootloader_flash: mmu set paddr=00030000 count=2 size=14df8 src_addr=30020 src_addr_aligned=30000 D (325) bootloader_flash: mmu set block paddr=0x00040000 (was 0xffffffff) I (326) esp_image: segment 4: paddr=00044e20 vaddr=403884c4 size=01338h ( 4920) load D (329) esp_image: free data page_count 0x0000003f D (334) bootloader_flash: mmu set paddr=00040000 count=1 size=1338 src_addr=44e20 src_addr_aligned=40000 D (345) bootloader_flash: mmu set block paddr=0x00040000 (was 0xffffffff) I (351) esp_image: segment 5: paddr=00046160 vaddr=50000000 size=00010h ( 16) load D (359) esp_image: free data page_count 0x0000003f D (364) bootloader_flash: mmu set paddr=00040000 count=1 size=10 src_addr=46160 src_addr_aligned=40000 D (374) bootloader_flash: mmu set block paddr=0x00040000 (was 0xffffffff) D (380) boot: Calculated hash: 0000000000000000000000000000000000000000000000000000000000000000 E (389) esp_image: Image hash failed - image is corrupt D (395) boot: Expected hash: aa398efa12618d1ac337b4ba0817ea0512046b8e7ed147d2ec8a60bd49ea97d4 E (404) boot: Factory app partition is not bootable D (409) boot: Can't boot from zero-length partition E (414) boot: No bootable app partitions in the partition table ESP-ROM:esp32c3-api1-20210207 Build:Feb 7 2021 rst:0x3 (RTC_SW_SYS_RST),boot:0x9 (SPI_FAST_FLASH_BOOT) Saved PC:0x403d17b6 SPIWP:0xee mode:DIO, clock div:2 load:0x3fcd6100,len:0x1dbc load:0x403ce000,len:0x9dc load:0x403d0000,len:0x31d0 entry 0x403ce000 I (25) boot: ESP-IDF v4.4-dev-3042-g220590d599-dirty 2nd stage bootloader I (25) boot: compile time 12:09:42 D (26) bootloader_flash: XMC chip detected by RDID (00204016), skip. D (32) bootloader_flash: mmu set block paddr=0x00000000 (was 0xffffffff) I (39) boot: chip revision: 3 D (42) boot.esp32c3: magic e9 D (45) boot.esp32c3: segments 03 D (49) boot.esp32c3: spi_mode 02 D (52) boot.esp32c3: spi_speed 00 D (55) boot.esp32c3: spi_size 02 I (59) boot.esp32c3: SPI Speed : 40MHz I (64) boot.esp32c3: SPI Mode : DIO I (68) boot.esp32c3: SPI Flash Size : 4MB D (73) boot: Enabling RTCWDT(9000 ms) I (77) boot: Enabling RNG early entropy source... D (82) bootloader_flash: mmu set paddr=00010000 count=1 size=c00 src_addr=10000 src_addr_aligned=10000 D (91) boot: mapped partition table 0x10000 at 0x3c000000 D (97) flash_parts: partition table verified, 4 entries I (102) boot: Partition Table: I (106) boot: ## Label Usage Type ST Offset Length D (113) boot: load partition table entry 0x3c000000 D (118) boot: type=1 subtype=2 I (121) boot: 0 nvs WiFi data 01 02 00011000 00006000 D (129) boot: load partition table entry 0x3c000020 D (134) boot: type=1 subtype=1 I (137) boot: 1 phy_init RF data 01 01 00017000 00001000 D (145) boot: load partition table entry 0x3c000040 D (149) boot: type=0 subtype=0 I (153) boot: 2 factory factory app 00 00 00020000 00100000 I (160) boot: End of partition table D (164) boot: Trying partition index -1 offs 0x20000 size 0x100000 D (171) esp_image: reading image header @ 0x20000 D (175) bootloader_flash: mmu set block paddr=0x00020000 (was 0xffffffff) D (182) esp_image: image header: 0xe9 0x06 0x02 0x02 403802d2 I (188) esp_image: segment 0: paddr=00020020 vaddr=3c020020 size=067b0h ( 26544) map D (196) esp_image: free data page_count 0x0000003f D (201) bootloader_flash: mmu set paddr=00020000 count=1 size=67b0 src_addr=20020 src_addr_aligned=20000 D (217) bootloader_flash: mmu set block paddr=0x00020000 (was 0xffffffff) I (218) esp_image: segment 1: paddr=000267d8 vaddr=3fc89a00 size=01374h ( 4980) load D (226) esp_image: free data page_count 0x0000003f D (231) bootloader_flash: mmu set paddr=00020000 count=1 size=1374 src_addr=267d8 src_addr_aligned=20000 D (242) bootloader_flash: mmu set block paddr=0x00020000 (was 0xffffffff) I (248) esp_image: segment 2: paddr=00027b54 vaddr=40380000 size=084c4h ( 33988) load D (256) esp_image: free data page_count 0x0000003f D (261) bootloader_flash: mmu set paddr=00020000 count=2 size=84c4 src_addr=27b54 src_addr_aligned=20000 D (279) bootloader_flash: mmu set block paddr=0x00030000 (was 0xffffffff) I (279) esp_image: segment 3: paddr=00030020 vaddr=42000020 size=14df8h ( 85496) map D (286) esp_image: free data page_count 0x0000003f D (291) bootloader_flash: mmu set paddr=00030000 count=2 size=14df8 src_addr=30020 src_addr_aligned=30000 D (320) bootloader_flash: mmu set block paddr=0x00040000 (was 0xffffffff) I (320) esp_image: segment 4: paddr=00044e20 vaddr=403884c4 size=01338h ( 4920) load D (324) esp_image: free data page_count 0x0000003f D (329) bootloader_flash: mmu set paddr=00040000 count=1 size=1338 src_addr=44e20 src_addr_aligned=40000 D (340) bootloader_flash: mmu set block paddr=0x00040000 (was 0xffffffff) I (345) esp_image: segment 5: paddr=00046160 vaddr=50000000 size=00010h ( 16) load D (354) esp_image: free data page_count 0x0000003f D (358) bootloader_flash: mmu set paddr=00040000 count=1 size=10 src_addr=46160 src_addr_aligned=40000 D (368) bootloader_flash: mmu set block paddr=0x00040000 (was 0xffffffff) D (375) boot: Calculated hash: 0000000000000000000000000000000000000000000000000000000000000000 E (383) esp_image: Image hash failed - image is corrupt D (389) boot: Expected hash: aa398efa12618d1ac337b4ba0817ea0512046b8e7ed147d2ec8a60bd49ea97d4 E (398) boot: Factory app partition is not bootable D (404) boot: Can't boot from zero-length partition E (408) boot: No bootable app partitions in the partition table 程序: void app_main(void) { uint8_t data[]={0x11,0x11,0x11,0x11,0x11,0x11,0x11,0x11,0x11,0x11,0x11,0x11,0x11,0x11,0x11,0x11,0x11,0x11,0x11,0x11,0x11,0x11,0x11,0x11,0x11,0x11,0x11,0x11,0x11,0x11,0x11,0x11}; esp_efuse_batch_write_begin(); esp_err_t ret = esp_efuse_write_field_blob(ESP_EFUSE_KEY4,data,32*8); esp_efuse_batch_write_commit(); printf("Hello world!n"); vTaskDelay(1000 / portTICK_PERIOD_MS); printf("Restarting now.n"); REG_WRITE(RTC_CNTL_OPTIONS0_REG, RTC_CNTL_SW_SYS_RST); while(1); } |
只有小组成员才能发言,加入小组>>
944 浏览 0 评论
1671 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1330 浏览 1 评论
1233 浏览 1 评论
5015 浏览 2 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1252浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
927浏览 3评论
2333浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2526浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1051浏览 2评论
/9
GMT+8, 2025-12-1 23:55 , Processed in 0.665696 second(s), Total 70, Slave 53 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
377
