电子发烧友论坛|
调用ets_efuse_program有概率导致卡死,复位后无法验证sha256
开发板为esp-c3-13-kit 内置4m 由于真写efuse比较费芯片,我找到了一个能复现问题的方法,不用费芯片 注释掉ets_efuse_program就不会触发 程序: Code: [Select all] [Expand/Collapse]
GeSHi © Codebox Plus Extension 执行一会之后就能看到日志: ESP-ROM:esp32c3-api1-20210207 Build:Feb 7 2021 rst:0xc (RTC_SW_CPU_RST),boot:0xc (SPI_FAST_FLASH_BOOT) Saved PC:0x40380648 0x40380648: esp_restart_noos at D:/Program_Files/esp-idf/components/esp_system/port/soc/esp32c3/system_internal.c:146 (discriminator 1) SPIWP:0xee mode:DIO, clock div:2 load:0x3fcd6100,len:0x1dbc load:0x403ce000,len:0x9f0 load:0x403d0000,len:0x31f8 entry 0x403ce000 I (36) boot: ESP-IDF v4.4-dev-3042-g220590d599-dirty 2nd stage bootloader I (37) boot: compile time 12:33:04 D (37) bootloader_flash: XMC chip detected by RDID (00204016), skip. D (43) bootloader_flash: mmu set block paddr=0x00000000 (was 0xffffffff) I (50) boot: chip revision: 3 D (54) boot.esp32c3: magic e9 D (57) boot.esp32c3: segments 03 D (60) boot.esp32c3: spi_mode 02 D (63) boot.esp32c3: spi_speed 00 D (67) boot.esp32c3: spi_size 02 I (70) boot.esp32c3: SPI Speed : 40MHz I (75) boot.esp32c3: SPI Mode : DIO I (79) boot.esp32c3: SPI Flash Size : 4MB D (84) boot: Enabling RTCWDT(9000 ms) I (88) boot: Enabling RNG early entropy source... D (93) bootloader_flash: mmu set paddr=00010000 count=1 size=c00 src_addr=10000 src_addr_aligned=10000 D (103) boot: mapped partition table 0x10000 at 0x3c000000 D (108) flash_parts: partition table verified, 4 entries I (114) boot: Partition Table: I (117) boot: ## Label Usage Type ST Offset Length D (125) boot: load partition table entry 0x3c000000 D (130) boot: type=1 subtype=2 I (133) boot: 0 nvs WiFi data 01 02 00011000 00006000 D (140) boot: load partition table entry 0x3c000020 D (145) boot: type=1 subtype=1 I (148) boot: 1 phy_init RF data 01 01 00017000 00001000 D (156) boot: load partition table entry 0x3c000040 D (161) boot: type=0 subtype=0 I (164) boot: 2 factory factory app 00 00 00020000 00100000 I (172) boot: End of partition table D (176) boot: Trying partition index -1 offs 0x20000 size 0x100000 D (182) esp_image: reading image header @ 0x20000 D (187) bootloader_flash: mmu set block paddr=0x00020000 (was 0xffffffff) D (194) esp_image: image header: 0xe9 0x06 0x02 0x02 403802d2 I (199) esp_image: segment 0: paddr=00020020 vaddr=3c020020 size=06b20h ( 27424) map D (208) esp_image: free data page_count 0x0000003f D (213) bootloader_flash: mmu set paddr=00020000 count=1 size=6b20 src_addr=20020 src_addr_aligned=20000 D (228) bootloader_flash: mmu set block paddr=0x00020000 (was 0xffffffff) I (229) esp_image: segment 1: paddr=00026b48 vaddr=3fc89e00 size=01524h ( 5412) load D (238) esp_image: free data page_count 0x0000003f D (243) bootloader_flash: mmu set paddr=00020000 count=1 size=1524 src_addr=26b48 src_addr_aligned=20000 D (253) bootloader_flash: mmu set block paddr=0x00020000 (was 0xffffffff) I (259) esp_image: segment 2: paddr=00028074 vaddr=40380000 size=07fa4h ( 32676) load D (267) esp_image: free data page_count 0x0000003f D (272) bootloader_flash: mmu set paddr=00020000 count=2 size=7fa4 src_addr=28074 src_addr_aligned=20000 D (290) bootloader_flash: mmu set block paddr=0x00030000 (was 0xffffffff) I (290) esp_image: segment 3: paddr=00030020 vaddr=42000020 size=165e8h ( 91624) map D (297) esp_image: free data page_count 0x0000003f D (302) bootloader_flash: mmu set paddr=00030000 count=2 size=165e8 src_addr=30020 src_addr_aligned=30000 D (332) bootloader_flash: mmu set block paddr=0x00040000 (was 0xffffffff) I (332) esp_image: segment 4: paddr=00046610 vaddr=40387fa4 size=01ce0h ( 7392) load D (336) esp_image: free data page_count 0x0000003f D (341) bootloader_flash: mmu set paddr=00040000 count=1 size=1ce0 src_addr=46610 src_addr_aligned=40000 D (352) bootloader_flash: mmu set block paddr=0x00040000 (was 0xffffffff) I (357) esp_image: segment 5: paddr=000482f8 vaddr=50000000 size=00010h ( 16) load D (366) esp_image: free data page_count 0x0000003f D (370) bootloader_flash: mmu set paddr=00040000 count=1 size=10 src_addr=482f8 src_addr_aligned=40000 D (380) bootloader_flash: mmu set block paddr=0x00040000 (was 0xffffffff) D (387) boot: Calculated hash: c173afc7246778dcdd1fd5df44e7f5d8988b390d2a77578524a924cd78ff58c0 I (398) boot: Loaded app from partition at offset 0x20000 I (401) boot: Disabling RNG early entropy source... D (407) boot: Mapping segment 0 as DROM D (411) boot: Mapping segment 3 as IROM D (415) boot: calling set_cache_and_start_app D (419) boot: configure drom and irom and start D (424) boot: start: 0x403802d2 0x403802d2: call_start_cpu0 at D:/Program_Files/esp-idf/components/esp_system/port/cpu_start.c:270 I (438) cpu_start: Pro cpu up. I (447) cpu_start: Pro cpu start user code I (447) cpu_start: cpu freq: 160000000 I (447) cpu_start: Application information: I (449) cpu_start: Project name: hello-world I (455) cpu_start: App version: 1 I (459) cpu_start: Compile time: Dec 12 2021 12:32:56 I (465) cpu_start: ELF file SHA256: 4b7334e6cff00b34... I (471) cpu_start: ESP-IDF: v4.4-dev-3042-g220590d599-dirty I (478) heap_init: Initializing. RAM available for dynamic allocation: I (486) heap_init: At 3FC8C2F0 len 00033D10 (207 KiB): DRAM I (492) heap_init: At 3FCC0000 len 0001F060 (124 KiB): STACK/DRAM I (499) heap_init: At 50000010 len 00001FF0 (7 KiB): RTCRAM I (505) spi_flash: detected chip: generic I (510) spi_flash: flash io: dio I (514) sleep: Configure to isolate all GPIO pins in sleep state I (520) sleep: Enable automatic switching of GPIO sleep configuration I (528) cpu_start: Starting scheduler. ESP-ROM:esp32c3-api1-20210207 Build:Feb 7 2021 rst:0x8 (TG1WDT_SYS_RST),boot:0xc (SPI_FAST_FLASH_BOOT) Saved PC:0x4004c4c6 SPIWP:0xee mode:DIO, clock div:2 load:0x3fcd6100,len:0x1dbc load:0x403ce000,len:0x9f0 load:0x403d0000,len:0x31f8 entry 0x403ce000 I (36) boot: ESP-IDF v4.4-dev-3042-g220590d599-dirty 2nd stage bootloader I (37) boot: compile time 12:33:04 D (37) bootloader_flash: XMC chip detected by RDID (00204016), skip. D (43) bootloader_flash: mmu set block paddr=0x00000000 (was 0xffffffff) I (50) boot: chip revision: 3 D (54) boot.esp32c3: magic e9 D (57) boot.esp32c3: segments 03 D (60) boot.esp32c3: spi_mode 02 D (63) boot.esp32c3: spi_speed 00 D (67) boot.esp32c3: spi_size 02 I (70) boot.esp32c3: SPI Speed : 40MHz I (75) boot.esp32c3: SPI Mode : DIO I (79) boot.esp32c3: SPI Flash Size : 4MB W (84) boot.esp32c3: PRO CPU has been reset by WDT. D (90) boot: Enabling RTCWDT(9000 ms) I (93) boot: Enabling RNG early entropy source... D (99) bootloader_flash: mmu set paddr=00010000 count=1 size=c00 src_addr=10000 src_addr_aligned=10000 D (108) boot: mapped partition table 0x10000 at 0x3c000000 D (114) flash_parts: partition table verified, 4 entries I (119) boot: Partition Table: I (123) boot: ## Label Usage Type ST Offset Length D (130) boot: load partition table entry 0x3c000000 D (135) boot: type=1 subtype=2 I (138) boot: 0 nvs WiFi data 01 02 00011000 00006000 D (146) boot: load partition table entry 0x3c000020 D (151) boot: type=1 subtype=1 I (154) boot: 1 phy_init RF data 01 01 00017000 00001000 D (161) boot: load partition table entry 0x3c000040 D (166) boot: type=0 subtype=0 I (170) boot: 2 factory factory app 00 00 00020000 00100000 I (177) boot: End of partition table D (181) boot: Trying partition index -1 offs 0x20000 size 0x100000 D (188) esp_image: reading image header @ 0x20000 D (192) bootloader_flash: mmu set block paddr=0x00020000 (was 0xffffffff) D (199) esp_image: image header: 0xe9 0x06 0x02 0x02 403802d2 I (205) esp_image: segment 0: paddr=00020020 vaddr=3c020020 size=06b20h ( 27424) map D (213) esp_image: free data page_count 0x0000003f D (218) bootloader_flash: mmu set paddr=00020000 count=1 size=6b20 src_addr=20020 src_addr_aligned=20000 D (234) bootloader_flash: mmu set block paddr=0x00020000 (was 0xffffffff) I (235) esp_image: segment 1: paddr=00026b48 vaddr=3fc89e00 size=01524h ( 5412) load D (243) esp_image: free data page_count 0x0000003f D (248) bootloader_flash: mmu set paddr=00020000 count=1 size=1524 src_addr=26b48 src_addr_aligned=20000 D (259) bootloader_flash: mmu set block paddr=0x00020000 (was 0xffffffff) I (264) esp_image: segment 2: paddr=00028074 vaddr=40380000 size=07fa4h ( 32676) load D (273) esp_image: free data page_count 0x0000003f D (278) bootloader_flash: mmu set paddr=00020000 count=2 size=7fa4 src_addr=28074 src_addr_aligned=20000 D (296) bootloader_flash: mmu set block paddr=0x00030000 (was 0xffffffff) I (296) esp_image: segment 3: paddr=00030020 vaddr=42000020 size=165e8h ( 91624) map D (303) esp_image: free data page_count 0x0000003f D (308) bootloader_flash: mmu set paddr=00030000 count=2 size=165e8 src_addr=30020 src_addr_aligned=30000 D (338) bootloader_flash: mmu set block paddr=0x00040000 (was 0xffffffff) I (338) esp_image: segment 4: paddr=00046610 vaddr=40387fa4 size=01ce0h ( 7392) load D (342) esp_image: free data page_count 0x0000003f D (347) bootloader_flash: mmu set paddr=00040000 count=1 size=1ce0 src_addr=46610 src_addr_aligned=40000 D (358) bootloader_flash: mmu set block paddr=0x00040000 (was 0xffffffff) I (363) esp_image: segment 5: paddr=000482f8 vaddr=50000000 size=00010h ( 16) load D (372) esp_image: free data page_count 0x0000003f D (377) bootloader_flash: mmu set paddr=00040000 count=1 size=10 src_addr=482f8 src_addr_aligned=40000 D (386) bootloader_flash: mmu set block paddr=0x00040000 (was 0xffffffff) D (393) boot: Calculated hash: 0000000000000000000000000000000000000000000000000000000000000000 E (402) esp_image: Image hash failed - image is corrupt D (407) boot: Expected hash: c173afc7246778dcdd1fd5df44e7f5d8988b390d2a77578524a924cd78ff58c0 E (416) boot: Factory app partition is not bootable D (422) boot: Can't boot from zero-length partition E (427) boot: No bootable app partitions in the partition table 必须重新上电才行,要不就会一直复位,一直验证hash失败 |
只有小组成员才能发言,加入小组>>
944 浏览 0 评论
1671 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1330 浏览 1 评论
1233 浏览 1 评论
5015 浏览 2 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1252浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
927浏览 3评论
2334浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2526浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1051浏览 2评论
/9
GMT+8, 2025-12-2 01:17 , Processed in 0.796715 second(s), Total 71, Slave 54 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
377
