孩子第一次玩板子,求大佬们帮忙看看这是什么情况啊QWQ
如下图第一行显示 PS D:Espressifdatumesp-rainmaker-masterexamplesled_light> idf.py set-target esp32c3 Adding "set-target"'s dependency "fullclean" to list of commands with default set of options. Executing action: fullclean Build directory 'd:espressifdatumesp-rainmaker-masterexamplesled_lightbuild' not found. Nothing to clean. Executing action: set-target Set Target to: esp32c3, new sdkconfig created. Existing sdkconfig renamed to sdkconfig.old. Running cmake in directory d:espressifdatumesp-rainmaker-masterexamplesled_lightbuild Executing "cmake -G Ninja -DPYTHON_DEPS_CHECKED=1 -DESP_PLATFORM=1 -DIDF_TARGET=esp32c3 -DCCACHE_ENABLE=1 d:espressifdatumesp-rainmaker-masterexamplesled_light"... -- Found Git: D:/Espressif/Espressif/Espressif/tools/idf-git/2.34.2/cmd/git.exe (found version "2.34.1.windows.1") -- Component directory D:/Espressif/datum/esp-rainmaker-master/components/esp-insights does not contain a CMakeLists.txt file. No component will be added -- Component directory D:/Espressif/datum/esp-rainmaker-master/components/rmaker_common does not contain a CMakeLists.txt file. No component will be added -- ccache will be used for faster recompilation -- The C compiler identification is GNU 8.4.0 -- The CXX compiler identification is GNU 8.4.0 -- The ASM compiler identification is GNU -- Found assembler: D:/Espressif/Espressif/Espressif/tools/riscv32-esp-elf/esp-2021r2-patch5-8.4.0/riscv32-esp-elf/bin/riscv32-esp-elf-gcc.exe -- Detecting C compiler ABI info -- Detecting C compiler ABI info - done -- Check for working C compiler: D:/Espressif/Espressif/Espressif/tools/riscv32-esp-elf/esp-2021r2-patch5-8.4.0/riscv32-esp-elf/bin/riscv32-esp-elf-gcc.exe - skipped -- Detecting C compile features -- Detecting C compile features - done -- Detecting CXX compiler ABI info -- Detecting CXX compiler ABI info - done -- Check for working CXX compiler: D:/Espressif/Espressif/Espressif/tools/riscv32-esp-elf/esp-2021r2-patch5-8.4.0/riscv32-esp-elf/bin/riscv32-esp-elf-g++.exe - skipped -- Detecting CXX compile features -- Detecting CXX compile features - done -- Building ESP-IDF components for target esp32c3 Skipping optional dependency: espressif/mdns Skipping optional dependency: espressif/mdns CMake Error at D:/Espressif/Espressif/Espressif/frameworks/esp-idf-v4.4.3/tools/cmake/build.cmake:201 (message): Failed to resolve component 'rmaker_common'. Call Stack (most recent call first): D:/Espressif/Espressif/Espressif/frameworks/esp-idf-v4.4.3/tools/cmake/build.cmake:227 (__build_resolve_and_add_req) D:/Espressif/Espressif/Espressif/frameworks/esp-idf-v4.4.3/tools/cmake/build.cmake:507 (__build_expand_requirements) D:/Espressif/Espressif/Espressif/frameworks/esp-idf-v4.4.3/tools/cmake/project.cmake:384 (idf_build_process) CMakeLists.txt:16 (project) -- Configuring incomplete, errors occurred! |
只有小组成员才能发言,加入小组>>
945 浏览 0 评论
1672 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1330 浏览 1 评论
1233 浏览 1 评论
5021 浏览 2 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1253浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
927浏览 3评论
2336浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2526浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1051浏览 2评论
/9
GMT+8, 2025-12-2 03:59 , Processed in 0.505414 second(s), Total 67, Slave 52 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
287
