NUCLEO-F103RB 与 STM32F103RB
我想在突发模式下使用 DMA 将数据从 RAM 中的缓冲区写入 tiM1_CCR1,2,3,4?处于 PWM 模式。在 TIM1 更新 (UEV) 上请求 DMA 突发事务。突发模式下的事务数设置为 4 个事务。根据有关每个 DMA 突发请求的参考手册,RAM 缓冲区中的 4 个值必须同时传输到 CCR1、2、3、4。我实际看到的是,在每个 TIM1 更新事件中,只有一个 TIM1_CCRx 寄存器正在使用缓冲区中的新值进行更新。 这就是工作的方式吗?如果不是,哪里会出问题? IDE:arm Keil microVision5 驱动程序:STMicroelectronics SPL 源代码 #define TIM1_DMAR_ADDRESS ((uint32_t)0x40012C4C) GPIO_InitTypeDef GPIO_InitStructure; DMA_InitTypeDef DMA_InitStructure; TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure; TIM_OCInitTypeDef TIM_OCInitStructure; uint16_t SRC_Buffer[] = {0xFFFF, 0x7FFF, 0x3FFF, 0x1FFF}; int 主要(无效) { RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_TIM1,启用); RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10 | GPIO_Pin_11; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOA, &GPIO_InitStructure); DMA_DeInit(DMA1_Channel5); DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)TIM1_DMAR_ADDRESS; DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)SRC_Buffer; DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralDST; DMA_InitStructure.DMA_BufferSize = 4; DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable; DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable; DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord; DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord; DMA_InitStructure.DMA_Mode = DMA_Mode_Normal; DMA_InitStructure.DMA_Priority = DMA_Priority_High; DMA_InitStructure.DMA_M2M = DMA_M2M_Disable; DMA_Init(DMA1_Channel5, &DMA_InitStructure); //TIM1(PWM 发生器) TIM_DeInit(TIM1); TIM_TimeBaseStructure.TIM_Period = 0xFFFF; TIM_TimeBaseStructure.TIM_Prescaler = (uint16_t) (SystemCoreClock / 24000000)-1; TIM_TimeBaseStructure.TIM_ClockDivision = 0x0; TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure); TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1; TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; TIM_OCInitStructure.TIM_Pulse = 0x0000; TIM_OC1Init(TIM1, &TIM_OCInitStructure); TIM_OC1PreloadConfig(TIM1, TIM_OCPreload_Enable); TIM_OC2Init(TIM1, &TIM_OCInitStructure); TIM_OC2PreloadConfig(TIM1, TIM_OCPreload_Enable); TIM_OC3Init(TIM1, &TIM_OCInitStructure); TIM_OC3PreloadConfig(TIM1, TIM_OCPreload_Enable); TIM_OC4Init(TIM1, &TIM_OCInitStructure); TIM_OC4PreloadConfig(TIM1, TIM_OCPreload_Enable); TIM_DMAConfig(TIM1, TIM_DMABase_CCR1, TIM_DMABurstLength_4Transfers); TIM_DMACmd(TIM1, TIM_DMA_Update, ENABLE); TIM_Cmd(TIM1,启用); TIM_CtrlPWMOutputs(TIM1,启用); DMA_Cmd(DMA1_Channel5, 启用); 同时(1){} } 这是我在 Keil 的逻辑分析器中得到的图片 我现在正在使用模拟器,很长一段时间内将无法在真正的 MCU 上测试程序。 |
1个回答
我终于可以访问我的电路板和一个真正的逻辑分析仪(感谢所有浪费时间的隔离嘿嘿),Tim DMA-burst 功能工作正常 irl,问题出在 Keil 的模拟器中。
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1453 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1502 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3649 浏览 1 评论
3842 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2461 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
727浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
661浏览 5评论
710浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
941浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
745浏览 5评论
/9
GMT+8, 2025-12-2 04:34 , Processed in 0.572706 second(s), Total 42, Slave 35 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1902
