你好,这个是roc-rk3308b-cc的,不是roc-rk3308b-cc-plus,不过我也试过,使用该dts时,内核启动有问题,串口打印一直卡在starting kernel......
这个dts同样适用于ROC-RK3308B-CC-PLUS,因为ROC-RK3308B-CC使用的调试串口是UART2,ROC-RK3308B-CC-PLUS使用的是UART4。你可以将我发给你的dts,改下chosen和fiq_debugger
chosen { bootargs = "earlycon=uart8250,mmio32,0xff0e0000 swiotlb=1 console=ttyFIQ0 root=PARTLABEL=rootfs rootfstype=ext4 rootwait snd_aloop.index=7 snd_aloop.use_raw_jiffies=1 overlayroot=device:dev=PARTLABEL=userdata,fstype=ext4,mkfs=1 coherent_pool=1m systemd.gpt_auto=0 cgroup_enable=memory swapaccount=1"; }; &fiq_debugger { status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&uart4_xfer>; rockchip,serial-id = <4>; }; &uart4 { status = "disabled"; }; |
你好,我使用改后的dts,内核可以正常起来,但是使用arecord录音时,好像时钟有点问题
# arecord -l **** List of CAPTURE Hardware Devices **** card 0: rockchiprk3308v [rockchip,rk3308-vad], device 0: dailink-multicodecs multicodec-0 [] Subdevices: 1/1 Subdevice #0: subdevice #0 card 1: UAC1Gadget [UAC1_Gadget], device 0: UAC1_PCM [UAC1_PCM] Subdevices: 1/1 Subdevice #0: subdevice #0 card 7: Loopback [Loopback], device 0: Loopback PCM [Loopback PCM] Subdevices: 8/8 Subdevice #0: subdevice #0 Subdevice #1: subdevice #1 Subdevice #2: subdevice #2 Subdevice #3: subdevice #3 Subdevice #4: subdevice #4 Subdevice #5: subdevice #5 Subdevice #6: subdevice #6 Subdevice #7: subdevice #7 card 7: Loopback [Loopback], device 1: Loopback PCM [Loopback PCM] Subdevices: 7/8 Subdevice #0: subdevice #0 Subdevice #1: subdevice #1 Subdevice #2: subdevice #2 Subdevice #3: subdevice #3 Subdevice #4: subdevice #4 Subdevice #5: subdevice #5 Subdevice #6: subdevice #6 Subdevice #7: subdevice #7 # 录音 # arecord -f dat -t wav -r 48000 -c 8 -D hw:0,0 test.wav Recording WAVE 'test.wav' : Signed 16 bit Little Endian, Rate 48000 Hz, Channels 8 [ 142.674604] clk_pdm_frac parent_rate(589823999) is low than rate(61440000)*20, fractional div is not allowed [ 142.676548] dma-pl330 ff2d0000.dma-controller: pl330_submit_req:1680 Try increasing mcbufsz (372/256) [ 142.676603] dma-pl330 ff2d0000.dma-controller: fill_queue:2211 Bad Desc(3) [ 142.676627] dma-pl330 ff2d0000.dma-controller: pl330_submit_req:1680 Try increasing mcbufsz (372/256) [ 142.676642] dma-pl330 ff2d0000.dma-controller: fill_queue:2211 Bad Desc(3) |
windows装个软件Audacity,分析下音频文件中,8个通道是否有通道录到音了,一般有波形就说明通道有录取到音了
没有波形
检查下硬件了,可以录音的时候,用示波器测量下时钟线和数据线是否有波形出来
录音命令: arecord -D 6mic_loopback -r 16000 -f S16_LE /tmp/record.wav -c 8 或者arecord -D hw:0,0 -r 16000 -f S16_LE -c 8 /tmp/record.wav |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
1133 浏览 0 评论
谁有3566+电池+POE充电的方案,有个项目需要用该功能的主板
1367 浏览 0 评论
RK3588的GMAC0与PHY的参考时钟电平匹配问题??????
7082 浏览 1 评论
请问各位大佬,如何解决,瑞芯微 RV1126B 使用 mpp 自带工具 调试时,内核直接报错崩溃!
2170 浏览 0 评论
使用rk3568开发板,核0\\1\\3运行linux,核2运行hal,在核0中怎么关闭核2
2715 浏览 0 评论
/9
GMT+8, 2025-12-14 15:08 , Processed in 0.821088 second(s), Total 55, Slave 48 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2421
