问题描述及复现步骤:
python2 .repo/repo/repo sync -l
python2 .repo/repo/repo sync -c --no-clone-bundle --no-tags
python2 .repo/repo/repo start firefly --all
[ljn@ljn-manjaro build_repo2022]$ ./build.sh roc-rk3308b-cc-plus-buildroot.mk
processing option: roc-rk3308b-cc-plus-buildroot.mk
switching to board: /data/ljn/Sources/Linux_SDK_R3308Y/build_repo2022/device/rockchip/rk3308/roc-rk3308b-cc-plus-buildroot.mk
[ljn@ljn-manjaro build_repo2022]$ ./build.sh uboot
processing option: uboot
============Start building uboot============
TARGET_UBOOT_CONFIG=firefly-rk3308-debug-uart4
make for firefly-rk3308-debug-uart4_defconfig by -j8
HOSTCC scripts/basic/fixdep
HOSTCC scripts/kconfig/conf.o
SHIPPED scripts/kconfig/zconf.tab.c
SHIPPED scripts/kconfig/zconf.lex.c
SHIPPED scripts/kconfig/zconf.hash.c
HOSTCC scripts/kconfig/zconf.tab.o
HOSTLD scripts/kconfig/conf
configuration written to .config
scripts/kconfig/conf --silentoldconfig Kconfig
CHK include/config.h
UPD include/config.h
CFG u-boot.cfg
GEN include/autoconf.mk.dep
CFG spl/u-boot.cfg
CFG tpl/u-boot.cfg
GEN spl/include/autoconf.mk
GEN tpl/include/autoconf.mk
CHK include/config/uboot.release
CHK include/generated/timestamp_autogenerated.h
UPD include/generated/timestamp_autogenerated.h
HOSTCC scripts/dtc/dtc.o
HOSTCC scripts/dtc/flattree.o
HOSTCC scripts/dtc/fstree.o
HOSTCC scripts/dtc/data.o
HOSTCC scripts/dtc/livetree.o
HOSTCC scripts/dtc/treesource.o
HOSTCC scripts/dtc/srcpos.o
HOSTCC scripts/dtc/checks.o
HOSTCC scripts/dtc/util.o
SHIPPED scripts/dtc/dtc-lexer.lex.c
SHIPPED scripts/dtc/dtc-parser.tab.h
SHIPPED scripts/dtc/dtc-parser.tab.c
HOSTCC scripts/dtc/dtc-lexer.lex.o
HOSTCC scripts/dtc/dtc-parser.tab.o
CFG u-boot.cfg
UPD include/config/uboot.release
CHK include/generated/version_autogenerated.h
UPD include/generated/version_autogenerated.h
CC lib/asm-offsets.s
CC arch/arm/lib/asm-offsets.s
CHK include/generated/asm-offsets.h
UPD include/generated/asm-offsets.h
HOSTLD scripts/dtc/dtc
CHK include/generated/generic-asm-offsets.h
/usr/bin/ld: scripts/dtc/dtc-parser.tab.o:(.bss+0x10): multiple definition of `yylloc'; scripts/dtc/dtc-lexer.lex.o:(.bss+0x0): first defined here
UPD include/generated/generic-asm-offsets.h
collect2: error: ld returned 1 exit status
LDS u-boot.lds
make[2]: *** [scripts/Makefile.host:108: scripts/dtc/dtc] Error 1
make[1]: *** [scripts/Makefile.build:425: scripts/dtc] Error 2
make: *** [Makefile:491: scripts] Error 2
make: *** Waiting for unfinished jobs....
ERROR: Running build_uboot failed!
ERROR: exit code 2 from line 523:
./make.sh RK_UBOOT_DEFCONFIG UBOOT_COMPILE_COMMANDS
把dtc-parser.tab.c_shipped文件里面的yylloc注释掉,能编译通过。但uboot编译到后面又报错,提示dtc文件语法错误:
DTC arch/arm/dts/rk3126-evb.dtb
DTC arch/arm/dts/rk3188-radxarock.dtb
DTC arch/arm/dts/rk3128-evb.dtb
DTC arch/arm/dts/rk3288-evb.dtb
Error: arch/arm/dts/.rk3036-sdk.dtb.pre.tmp:77.1-10 syntax error
FATAL ERROR: Unable to parse input tree
make[2]: *** [scripts/Makefile.lib:319: arch/arm/dts/rk3036-sdk.dtb] Error 1
make[2]: *** Waiting for unfinished jobs....
Error: arch/arm/dts/.rk3188-radxarock.dtb.pre.tmp:383.1-10 syntax error
make[2]: *** [scripts/Makefile.lib:319: arch/arm/dts/rk3188-radxarock.dtb] Error 1
make[1]: *** [dts/Makefile:72: arch-dtbs] Error 2
make: *** [Makefile:880: dts/dt.dtb] Error 2
./make.sh $RK_UBOOT_DEFCONFIG $UBOOT_COMPILE_COMMANDS
这些dtc文件,使用系统自带的dtc命令,也会报错。
