SoC:RK3288
Platform:Android 5.1
问题:系统启动卡在Android动画
通过串口助手获取logcat日志:
--------- beginning of crash
06-05 09:17:26.406 E/AndroidRuntime( 4564): *** FATAL EXCEPTION IN SYSTEM PROCESS: main
06-05 09:17:26.406 E/AndroidRuntime( 4564): java.lang.RuntimeException: Failed to boot service com.android.server.devicepolicy.DevicePolicyManagerService$Lifecycle: onBootPhase threw an exception during phase 480
06-05 09:17:26.406 E/AndroidRuntime( 4564): at com.android.server.SystemServiceManager.startBootPhase(SystemServiceManager.java:137)
06-05 09:17:26.406 E/AndroidRuntime( 4564): at com.android.server.SystemServer.startOtherServices(SystemServer.java:1107)
06-05 09:17:26.406 E/AndroidRuntime( 4564): at com.android.server.SystemServer.run(SystemServer.java:279)
06-05 09:17:26.406 E/AndroidRuntime( 4564): at com.android.server.SystemServer.main(SystemServer.java:171)
06-05 09:17:26.406 E/AndroidRuntime( 4564): at java.lang.reflect.Method.invoke(Native Method)
06-05 09:17:26.406 E/AndroidRuntime( 4564): at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:772)
06-05 09:17:26.406 E/AndroidRuntime( 4564): at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:662)
06-05 09:17:26.406 E/AndroidRuntime( 4564): Caused by: android.database.sqlite.SQLiteDiskIOException: disk I/O error (code 4874)
06-05 09:17:26.406 E/AndroidRuntime( 4564): at android.database.sqlite.SQLiteConnection.nativeExecuteForLong(Native Method)
06-05 09:17:26.406 E/AndroidRuntime( 4564): at android.database.sqlite.SQLiteConnection.executeForLong(SQLiteConnection.java:596)
06-05 09:17:26.406 E/AndroidRuntime( 4564): at android.database.sqlite.SQLiteSession.executeForLong(SQLiteSession.java:652)
06-05 09:17:26.406 E/AndroidRuntime( 4564): at android.database.sqlite.SQLiteStatement.simpleQueryForLong(SQLiteStatement.java:107)
06-05 09:17:26.406 E/AndroidRuntime( 4564): at android.database.DatabaseUtils.longForQuery(DatabaseUtils.java:845)
06-05 09:17:26.406 E/AndroidRuntime( 4564): at android.database.DatabaseUtils.longForQuery(DatabaseUtils.java:833)
06-05 09:17:26.406 E/AndroidRuntime( 4564): at android.database.sqlite.SQLiteDatabase.getVersion(SQLiteDatabase.java:864)
06-05 09:17:26.406 E/AndroidRuntime( 4564): at android.database.sqlite.SQLiteOpenHelper.getDatabaseLocked(SQLiteOpenHelper.java:241)
06-05 09:17:26.406 E/AndroidRuntime( 4564): at android.database.sqlite.SQLiteOpenHelper.getReadableDatabase(SQLiteOpenHelper.java:187)
06-05 09:17:26.406 E/AndroidRuntime( 4564): at com.android.server.LockSettingsStorage.readKeyValue(LockSettingsStorage.java:138)
06-05 09:17:26.406 E/AndroidRuntime( 4564): at com.android.server.LockSettingsService.getStringUnchecked(LockSettingsService.java:353)
06-05 09:17:26.406 E/AndroidRuntime( 4564): at com.android.server.LockSettingsService.getLong(LockSettingsService.java:332)
06-05 09:17:26.406 E/AndroidRuntime( 4564): at com.android.internal.widget.LockPatternUtils.getLong(LockPatternUtils.java:1112)
06-05 09:17:26.406 E/AndroidRuntime( 4564): at com.android.internal.widget.LockPatternUtils.getKeyguardStoredPasswordQuality(LockPatternUtils.java:830)
06-05 09:17:26.406 E/AndroidRuntime( 4564): at com.android.internal.widget.LockPatternUtils.getActivePasswordQuality(LockPatternUtils.java:427)
06-05 09:17:26.406 E/AndroidRuntime( 4564): at com.android.server.devicepolicy.DevicePolicyManagerService.loadSettingsLocked(DevicePolicyManagerService.java:1673)
06-05 09:17:26.406 E/AndroidRuntime( 4564): at com.android.server.devicepolicy.DevicePolicyManagerService.getUserData(DevicePolicyManagerService.java:1091)
06-05 09:17:26.406 E/AndroidRuntime( 4564): at com.android.server.devicepolicy.DevicePolicyManagerService.systemReady(DevicePolicyManagerService.java:1785)
06-05 09:17:26.406 E/AndroidRuntime( 4564): at com.android.server.devicepolicy.DevicePolicyManagerService$Lifecycle.onBootPhase(DevicePolicyManagerService.java:308)
06-05 09:17:26.406 E/AndroidRuntime( 4564): at com.android.server.SystemServiceManager.startBootPhase(SystemServiceManager.java:135)
06-05 09:17:26.406 E/AndroidRuntime( 4564): ... 6 more
一直反复报这样的错误,从log看是操作data分区时出现I/O error,此时怀疑data分区出现了问题,df命令查看data分区,发现data分区已经被填满。
解决:清除data分区垃圾文件,去掉系统后台的logcat日志脚本,该脚本在系统运行过程中一直保存logcat日志到data分区。
原作者:HelloBirthday
