我使用模板工程,创建工程之后,添加ETH组件,选择使用industry-io,配置好网口需要的驱动,编译,然后finsh控制台报错: [W/drv.emac] eth transmit frame faild: 4 [I/sal.skt] Socket Abstraction Layer initialize success. [W/drv.emac] eth transmit frame faild: 20 msh />[W/drv.emac] eth transmit frame faild: 20 [W/drv.emac] eth transmit frame faild: 20 [W/drv.emac] eth transmit frame faild: 20 [I/drv.emac] link down 我加入udpserver例程,也无法正常运行。是我的配置有问题吗?,下面是生成的rtconfig.h配置: #ifndef RT_CONFIG_H__ #define RT_CONFIG_H__ /* Generated by Kconfiglib (https://github.com/ulfalizer/Kconfiglib) */ /* RT-Thread Kernel */ #define RT_NAME_MAX 8 #define RT_ALIGN_SIZE 4 #define RT_THREAD_PRIORITY_32 #define RT_THREAD_PRIORITY_MAX 32 #define RT_TICK_PER_SECOND 1000 #define RT_USING_OVERFLOW_CHECK #define RT_USING_HOOK #define RT_HOOK_USING_FUNC_PTR #define RT_USING_IDLE_HOOK #define RT_IDLE_HOOK_LIST_SIZE 4 #define IDLE_THREAD_STACK_SIZE 512 #define RT_USING_TIMER_SOFT #define RT_TIMER_THREAD_PRIO 4 #define RT_TIMER_THREAD_STACK_SIZE 512 /* kservice optimization */ #define RT_KSERVICE_USING_STDLIB /* end of kservice optimization */ #define RT_DEBUG #define RT_DEBUG_COLOR /* Inter-Thread communication */ #define RT_USING_SEMAPHORE #define RT_USING_MUTEX #define RT_USING_EVENT #define RT_USING_MAILBOX #define RT_USING_MESSAGEQUEUE /* end of Inter-Thread communication */ /* Memory Management */ #define RT_USING_MEMHEAP #define RT_MEMHEAP_FAST_MODE #define RT_USING_MEMHEAP_AS_HEAP #define RT_USING_MEMHEAP_AUTO_BINDING #define RT_USING_HEAP /* end of Memory Management */ /* Kernel Device Object */ #define RT_USING_DEVICE #define RT_USING_CONSOLE #define RT_CONSOLEBUF_SIZE 1024 #define RT_CONSOLE_DEVICE_NAME "uart4" /* end of Kernel Device Object */ #define RT_VER_NUM 0x40100 /* end of RT-Thread Kernel */ #define ARCH_ARM #define RT_USING_CPU_FFS #define ARCH_ARM_CORTEX_M #define ARCH_ARM_CORTEX_M7 /* RT-Thread Components */ #define RT_USING_COMPONENTS_INIT #define RT_USING_USER_MAIN #define RT_MAIN_THREAD_STACK_SIZE 4096 #define RT_MAIN_THREAD_PRIORITY 10 #define RT_USING_LEGACY #define RT_USING_MSH #define RT_USING_FINSH #define FINSH_USING_MSH #define FINSH_THREAD_NAME "tshell" #define FINSH_THREAD_PRIORITY 20 #define FINSH_THREAD_STACK_SIZE 4096 #define FINSH_USING_HISTORY #define FINSH_HISTORY_LINES 5 #define FINSH_USING_SYMTAB #define FINSH_CMD_SIZE 80 #define MSH_USING_BUILT_IN_COMMANDS #define FINSH_USING_DESCRIPTION #define FINSH_ARG_MAX 10 #define RT_USING_DFS #define DFS_USING_POSIX #define DFS_USING_WORKDIR #define DFS_FILESYSTEMS_MAX 5 #define DFS_FILESYSTEM_TYPES_MAX 4 #define DFS_FD_MAX 50 #define RT_USING_DFS_ELMFAT /* elm-chan's FatFs, Generic FAT Filesystem Module */ #define RT_DFS_ELM_CODE_PAGE 437 #define RT_DFS_ELM_WORD_ACCESS #define RT_DFS_ELM_USE_LFN_3 #define RT_DFS_ELM_USE_LFN 3 #define RT_DFS_ELM_LFN_UNICODE_0 #define RT_DFS_ELM_LFN_UNICODE 0 #define RT_DFS_ELM_MAX_LFN 255 #define RT_DFS_ELM_DRIVES 2 #define RT_DFS_ELM_MAX_SECTOR_SIZE 512 #define RT_DFS_ELM_REENTRANT #define RT_DFS_ELM_MUTEX_TIMEOUT 3000 /* end of elm-chan's FatFs, Generic FAT Filesystem Module */ #define RT_USING_DFS_DEVFS #define RT_USING_DFS_ROMFS #define RT_USING_FAL #define FAL_DEBUG_CONFIG #define FAL_DEBUG 1 #define FAL_PART_HAS_TABLE_CFG #define FAL_USING_SFUD_PORT #define FAL_USING_NOR_FLASH_DEV_NAME "norflash0" /* Device Drivers */ #define RT_USING_DEVICE_IPC #define RT_USING_SYSTEM_WORKQUEUE #define RT_SYSTEM_WORKQUEUE_STACKSIZE 2048 #define RT_SYSTEM_WORKQUEUE_PRIORITY 23 #define RT_USING_SERIAL #define RT_USING_SERIAL_V1 #define RT_SERIAL_USING_DMA #define RT_SERIAL_RB_BUFSZ 64 #define RT_USING_PIN #define RT_USING_MTD_NOR #define RT_USING_RTC #define RT_USING_SOFT_RTC #define RT_USING_SDIO #define RT_SDIO_STACK_SIZE 512 #define RT_SDIO_THREAD_PRIORITY 15 #define RT_MMCSD_STACK_SIZE 1024 #define RT_MMCSD_THREAD_PREORITY 22 #define RT_MMCSD_MAX_PARTITION 16 #define RT_USING_SPI #define RT_USING_SFUD #define RT_SFUD_USING_SFDP #define RT_SFUD_USING_FLASH_INFO_TABLE #define RT_SFUD_SPI_MAX_HZ 50000000 /* Using USB */ /* end of Using USB */ /* end of Device Drivers */ /* C/C++ and POSIX layer */ #define RT_LIBC_DEFAULT_TIMEZONE 8 /* POSIX (Portable Operating System Interface) layer */ #define RT_USING_POSIX_FS #define RT_USING_POSIX_DEVIO #define RT_USING_POSIX_STDIO #define RT_USING_POSIX_POLL #define RT_USING_POSIX_SELECT #define RT_USING_POSIX_SOCKET #define RT_USING_POSIX_TERMIOS #define RT_USING_MODULE /* Interprocess Communication (IPC) */ /* Socket is in the 'Network' category */ /* end of Interprocess Communication (IPC) */ /* end of POSIX (Portable Operating System Interface) layer */ /* end of C/C++ and POSIX layer */ /* Network */ #define RT_USING_SAL #define SAL_INTERNET_CHECK /* protocol stack implement */ #define SAL_USING_LWIP /* end of protocol stack implement */ #define SAL_USING_POSIX #define RT_USING_NETDEV #define NETDEV_USING_IFCONFIG #define NETDEV_USING_PING #define NETDEV_USING_NETSTAT #define NETDEV_USING_AUTO_DEFAULT #define NETDEV_IPV4 1 #define NETDEV_IPV6 0 #define RT_USING_LWIP #define RT_USING_LWIP203 #define RT_USING_LWIP_VER_NUM 0x20003 #define RT_LWIP_MEM_ALIGNMENT 4 #define RT_LWIP_IGMP #define RT_LWIP_ICMP #define RT_LWIP_DNS #define RT_LWIP_DHCP #define IP_SOF_BROADCAST 1 #define IP_SOF_BROADCAST_RECV 1 /* Static IPv4 Address */ #define RT_LWIP_IPADDR "192.168.1.30" #define RT_LWIP_GWADDR "192.168.1.1" #define RT_LWIP_MSKADDR "255.255.255.0" /* end of Static IPv4 Address */ #define RT_LWIP_UDP #define RT_LWIP_TCP #define RT_LWIP_RAW #define RT_MEMP_NUM_NETCONN 34 #define RT_LWIP_PBUF_NUM 38 #define RT_LWIP_RAW_PCB_NUM 4 #define RT_LWIP_UDP_PCB_NUM 4 #define RT_LWIP_TCP_PCB_NUM 30 #define RT_LWIP_TCP_SEG_NUM 40 #define RT_LWIP_TCP_SND_BUF 8196 #define RT_LWIP_TCP_WND 8196 #define RT_LWIP_TCPTHREAD_PRIORITY 10 #define RT_LWIP_TCPTHREAD_MBOX_SIZE 8 #define RT_LWIP_TCPTHREAD_STACKSIZE 4096 #define RT_LWIP_ETHTHREAD_PRIORITY 12 #define RT_LWIP_ETHTHREAD_STACKSIZE 1024 #define RT_LWIP_ETHTHREAD_MBOX_SIZE 8 #define LWIP_NETIF_STATUS_CALLBACK 1 #define LWIP_NETIF_LINK_CALLBACK 1 #define SO_REUSE 1 #define LWIP_SO_RCVTIMEO 1 #define LWIP_SO_SNDTIMEO 1 #define LWIP_SO_RCVBUF 1 #define LWIP_SO_LINGER 0 #define LWIP_NETIF_LOOPBACK 0 #define RT_LWIP_USING_PING /* end of Network */ /* Utilities */ /* end of Utilities */ /* end of RT-Thread Components */ /* RT-Thread online packages */ /* IoT - internet of things */ /* Wi-Fi */ /* Marvell WiFi */ /* end of Marvell WiFi */ /* Wiced WiFi */ /* end of Wiced WiFi */ /* end of Wi-Fi */ /* IoT Cloud */ /* end of IoT Cloud */ /* end of IoT - internet of things */ /* security packages */ /* end of security packages */ /* language packages */ /* JSON: JavaScript Object Notation, a lightweight data-interchange format */ /* end of JSON: JavaScript Object Notation, a lightweight data-interchange format */ /* XML: Extensible Markup Language */ /* end of XML: Extensible Markup Language */ /* end of language packages */ /* multimedia packages */ /* LVGL: powerful and easy-to-use embedded GUI library */ /* end of LVGL: powerful and easy-to-use embedded GUI library */ /* u8g2: a monochrome graphic library */ /* end of u8g2: a monochrome graphic library */ /* PainterEngine: A cross-platform graphics application framework written in C language */ /* end of PainterEngine: A cross-platform graphics application framework written in C language */ /* end of multimedia packages */ /* tools packages */ /* end of tools packages */ /* system packages */ /* enhanced kernel services */ /* end of enhanced kernel services */ /* acceleration: Assembly language or algorithmic acceleration packages */ /* end of acceleration: Assembly language or algorithmic acceleration packages */ /* CMSIS: ARM Cortex-M Microcontroller Software Interface Standard */ /* end of CMSIS: ARM Cortex-M Microcontroller Software Interface Standard */ /* Micrium: Micrium software products porting for RT-Thread */ /* end of Micrium: Micrium software products porting for RT-Thread */ /* end of system packages */ /* peripheral libraries and drivers */ /* Kendryte SDK */ /* end of Kendryte SDK */ /* end of peripheral libraries and drivers */ /* AI packages */ /* end of AI packages */ /* miscellaneous packages */ /* project laboratory */ /* end of project laboratory */ /* samples: kernel and components samples */ /* end of samples: kernel and components samples */ /* entertainment: terminal games and other interesting software packages */ /* end of entertainment: terminal games and other interesting software packages */ /* end of miscellaneous packages */ /* end of RT-Thread online packages */ /* Hardware Drivers Config */ #define SOC_STM32H750XB #define SOC_SERIES_STM32H7 /* Board extended module */ #define ART_PI_USING_INDUSTRY_IO #define INDUSTRY_IO_USING_ETH /* end of Board extended module */ /* Onboard Peripheral */ #define BSP_USING_USB_TO_USART /* end of Onboard Peripheral */ /* On-chip Peripheral */ #define BSP_USING_GPIO #define BSP_USING_UART #define BSP_USING_UART4 #define BSP_USING_UART6 #define BSP_USING_SPI #define BSP_USING_SPI1 #define BSP_USING_SDIO #define BSP_USING_SDIO1 #define BSP_USING_ETH #define ETH_RESET_PIN "PA.3" #define PHY_USING_LAN8720A /* end of On-chip Peripheral */ /* end of Hardware Drivers Config */ /* External Libraries */ /* end of External Libraries */ #define FIRMWARE_EXEC_USING_QSPI_FLASH #define RT_STUDIO_BUILT_IN #endif |
2个回答
网线连接正常吗,你的网线是连接到哪了,直接连的电脑、还是路由器
网络链接正常,我用industry_io_gateway例程,是可以正常通讯的,但基于模板工程,然后增加网络组件,会出现上面的问题。
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
1092 浏览 0 评论
3044 浏览 0 评论
图腾柱PFC无法上升至400V,且电感电流为正弦波形,但是幅值极小
9411 浏览 0 评论
飞凌嵌入式ElfBoard-Vim编辑器之静态链接和动态链接
2900 浏览 0 评论
使用 LinkBoy 将程序导出为 C 语言代码并烧录至 Arduino ESP32 开发板
2305 浏览 1 评论
/9
GMT+8, 2025-12-3 13:17 , Processed in 0.694711 second(s), Total 78, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2381
