stm32片上flash数据结构 const struct fal_flash_dev stm32f2_onchip_flash ={ 这儿的blksize到底填2048还是填128 × 1024如此大的数,有些blog说是这儿是最小擦除单位,填2048或者4096. |
3个回答
rtt驱动是这样分块定义的
#if defined(RT_USING_FAL) static int fal_flash_read_16k(long offset, rt_uint8_t *buf, size_t size); static int fal_flash_read_64k(long offset, rt_uint8_t *buf, size_t size); static int fal_flash_read_128k(long offset, rt_uint8_t *buf, size_t size); static int fal_flash_write_16k(long offset, const rt_uint8_t *buf, size_t size); static int fal_flash_write_64k(long offset, const rt_uint8_t *buf, size_t size); static int fal_flash_write_128k(long offset, const rt_uint8_t *buf, size_t size); static int fal_flash_erase_16k(long offset, size_t size); static int fal_flash_erase_64k(long offset, size_t size); static int fal_flash_erase_128k(long offset, size_t size); const struct fal_flash_dev stm32_onchip_flash_16k = { "onchip_flash_16k", STM32_FLASH_START_ADRESS_16K, FLASH_SIZE_GRANULARITY_16K, (16 * 1024), {NULL, fal_flash_read_16k, fal_flash_write_16k, fal_flash_erase_16k} }; const struct fal_flash_dev stm32_onchip_flash_64k = { "onchip_flash_64k", STM32_FLASH_START_ADRESS_64K, FLASH_SIZE_GRANULARITY_64K, (64 * 1024), {NULL, fal_flash_read_64k, fal_flash_write_64k, fal_flash_erase_64k} }; const struct fal_flash_dev stm32_onchip_flash_128k = { "onchip_flash_128k", STM32_FLASH_START_ADRESS_128K, FLASH_SIZE_GRANULARITY_128K, (128 * 1024), {NULL, fal_flash_read_128k, fal_flash_write_128k, fal_flash_erase_128k} }; static int fal_flash_read_16k(long offset, rt_uint8_t *buf, size_t size) { return stm32_flash_read(stm32_onchip_flash_16k.addr + offset, buf, size); } static int fal_flash_read_64k(long offset, rt_uint8_t *buf, size_t size) { return stm32_flash_read(stm32_onchip_flash_64k.addr + offset, buf, size); } static int fal_flash_read_128k(long offset, rt_uint8_t *buf, size_t size) { return stm32_flash_read(stm32_onchip_flash_128k.addr + offset, buf, size); } static int fal_flash_write_16k(long offset, const rt_uint8_t *buf, size_t size) { return stm32_flash_write(stm32_onchip_flash_16k.addr + offset, buf, size); } static int fal_flash_write_64k(long offset, const rt_uint8_t *buf, size_t size) { return stm32_flash_write(stm32_onchip_flash_64k.addr + offset, buf, size); } static int fal_flash_write_128k(long offset, const rt_uint8_t *buf, size_t size) { return stm32_flash_write(stm32_onchip_flash_128k.addr + offset, buf, size); } static int fal_flash_erase_16k(long offset, size_t size) { return stm32_flash_erase(stm32_onchip_flash_16k.addr + offset, size); } static int fal_flash_erase_64k(long offset, size_t size) { return stm32_flash_erase(stm32_onchip_flash_64k.addr + offset, size); } static int fal_flash_erase_128k(long offset, size_t size) { return stm32_flash_erase(stm32_onchip_flash_128k.addr + offset, size); } #endif #endif /* BSP_USING_ON_CHIP_FLASH */ |
看你具体擦除的地方块大小是多少,就是起始地址那里到size结束,block是多少就是多少。
意思是说整片片上flash的大小吗,但是这个名字是blocksize,是每个块的大小啊,按理说每块大小应该是2048或者4096字节才合理,一般spiflash才有block的参数,片上flash按芯片参考手册上都是按page和bank来划分区域,没有block这个参数。
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
999 浏览 0 评论
2781 浏览 0 评论
图腾柱PFC无法上升至400V,且电感电流为正弦波形,但是幅值极小
9368 浏览 0 评论
飞凌嵌入式ElfBoard-Vim编辑器之静态链接和动态链接
2895 浏览 0 评论
使用 LinkBoy 将程序导出为 C 语言代码并烧录至 Arduino ESP32 开发板
2300 浏览 1 评论
/9
GMT+8, 2025-12-1 20:39 , Processed in 0.788021 second(s), Total 76, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1036
