#include "gd32f4xx.h" #include "adc.h" #include #include "systick.h" __IO uint32_t g_dmacomplete_flag; uint32_t FAN_BAD1; uint32_t FAN_BAD2; uint32_t BUS700V; uint32_t ADC_MQ; uint32_t ADC_Water1; uint32_t ADC_Water2; uint16_t adc_value[8]; /*************************************************************************** * @Brief 配置ADC工作模式 用DMA读取 * @param 无 * @retval 无 **************************************************************************/ void ADC_config(void) { dma_single_data_parameter_struct dma_single_data_parameter; //ADC相关时钟配置 rcu_periph_clock_enable(RCU_GPIOA); rcu_periph_clock_enable(RCU_DMA1); rcu_periph_clock_enable(RCU_ADC0); adc_clock_config(ADC_ADCCK_PCLK2_DIV6); //PA1 PA2 PA3 PA5 PA6 PA7 gpio_mode_set(GPIOA,GPIO_MODE_ANALOG,GPIO_PUPD_NONE,GPIO_PIN_1 //配置引脚为模拟输入状态 |GPIO_PIN_2|GPIO_PIN_3|GPIO_PIN_5|GPIO_PIN_6|GPIO_PIN_7); /* DMA相关配置 DMA1 CH0*/ dma_deinit(DMA1, DMA_CH0); dma_single_data_parameter.periph_addr = (uint32_t)(&ADC_RDATA(ADC0)); dma_single_data_parameter.periph_inc = DMA_PERIPH_INCREASE_DISABLE; dma_single_data_parameter.memory0_addr = (uint32_t)(&adc_value); dma_single_data_parameter.memory_inc = DMA_MEMORY_INCREASE_ENABLE; // 存储器地址是否为增量模式 dma_single_data_parameter.periph_memory_width = DMA_PERIPH_WIDTH_16BIT; dma_single_data_parameter.circular_mode = DMA_CIRCULAR_MODE_ENABLE; // 循环模式 dma_single_data_parameter.direction = DMA_PERIPH_TO_MEMORY; // 外设到存储器 dma_single_data_parameter.number = 6; // DMA缓存大小 dma_single_data_parameter.priority = DMA_PRIORITY_HIGH; dma_single_data_mode_init(DMA1,DMA_CH0,&dma_single_data_parameter); dma_channel_enable(DMA1, DMA_CH0); dma_circulation_enable(DMA1, DMA_CH0); //ADC相关配置 adc_deinit(); // 复位ADC adc_sync_mode_config(ADC_SYNC_MODE_INDEPENDENT); //独立模式 adc_special_function_config(ADC0, ADC_SCAN_MODE, ENABLE); // 扫描模式 adc_special_function_config(ADC0, ADC_CONTINUOUS_MODE, ENABLE); // 连续模式 adc_data_alignment_config(ADC0, ADC_DATAALIGN_RIGHT); // 右对齐 adc_channel_length_config(ADC0, ADC_REGULAR_CHANNEL, 6); //读取6通信 /* ADC regular channel config */ adc_regular_channel_config(ADC0, 0, ADC_CHANNEL_1, ADC_SAMPLETIME_56); adc_regular_channel_config(ADC0, 1, ADC_CHANNEL_2, ADC_SAMPLETIME_56); adc_regular_channel_config(ADC0, 2, ADC_CHANNEL_3, ADC_SAMPLETIME_56); adc_regular_channel_config(ADC0, 3, ADC_CHANNEL_5, ADC_SAMPLETIME_56); adc_regular_channel_config(ADC0, 4, ADC_CHANNEL_6, ADC_SAMPLETIME_56); adc_regular_channel_config(ADC0, 5, ADC_CHANNEL_7, ADC_SAMPLETIME_56); adc_external_trigger_config(ADC0,ADC_REGULAR_CHANNEL,EXTERNAL_TRIGGER_DISABLE); adc_dma_request_after_last_enable(ADC0); adc_dma_mode_enable(ADC0); adc_enable(ADC0); adc_calibration_enable(ADC0); adc_software_trigger_enable(ADC0, ADC_REGULAR_CHANNEL); } |
1147 浏览 0 评论
3228 浏览 0 评论
图腾柱PFC无法上升至400V,且电感电流为正弦波形,但是幅值极小
9443 浏览 0 评论
飞凌嵌入式ElfBoard-Vim编辑器之静态链接和动态链接
2907 浏览 0 评论
使用 LinkBoy 将程序导出为 C 语言代码并烧录至 Arduino ESP32 开发板
2314 浏览 1 评论
/9
GMT+8, 2025-12-4 10:17 , Processed in 0.950192 second(s), Total 68, Slave 48 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
