主屏使用的是HDMI,副屏使用的lvds
主屏是HMDI转lvds 由于转接模块不支持1280x800 所以设置了hdmi输入源为1280x720 为了保证主屏正常显示 修改了framebuffer为1280x800 就是由于修改了framebuffer导致副屏显示旋转异常,一定不要设置persist.sys.framebuffer.main这个参数 persist.sys.framebuffer.main=1280x800 查找rk资料了解到,双屏同显时,副屏显示是在主屏显示的基础上进行的缩放,双屏异显时,副屏显示是按照副屏实际物理分辨率重新进行了UI绘制 下面的patch能解决副屏旋转后显示异常及同显时不满屏的问题 修改patch如下 --- device/rockchip/rk3288/system.prop | 13 ++++++----- .../server/display/LocalDisplayAdapter.java | 20 ++++++++++++++++- .../com/android/server/display/LogicalDisplay.java | 26 +++++++++++++++++++++- .../services/surfaceflinger/DisplayDevice.cpp | 3 ++- 4 files changed, 53 insertions(+), 9 deletions(-) diff --git a/device/rockchip/rk3288/system.prop b/device/rockchip/rk3288/system.prop index 358f0fd..f34c991 100755 --- a/device/rockchip/rk3288/system.prop +++ b/device/rockchip/rk3288/system.prop @@ -48,9 +48,10 @@ ro.rk.displayd.enable=false sys.hwc.device.primary=HDMI-A sys.hwc.device.extend=LVDS -persist.sys.framebuffer.main=1280x800 -persist.sys.resolution.main=1920x1080 -persist.sys.resolution.aux=480x1280 -ro.same.orientation=false -#ro.orientation.einit=0 -ro.rotation.external=false +#persist.sys.framebuffer.main=1280x800 +#persist.sys.resolution.main=1280x720 +#persist.sys.resolution.aux=480x1280 +#ro.same.orientation=false +#ro.rotation.external=false +ro.orientation.einit=270 +persist.sys.rotation.efull=true diff --git a/frameworks/base/services/core/java/com/android/server/display/LocalDisplayAdapter.java b/frameworks/base/services/core/java/com/android/server/display/LocalDisplayAdapter.java index 68be9ce..be69c7e 100755 --- a/frameworks/base/services/core/java/com/android/server/display/LocalDisplayAdapter.java +++ b/frameworks/base/services/core/java/com/android/server/display/LocalDisplayAdapter.java @@ -422,8 +422,26 @@ final class LocalDisplayAdapter extends DisplayAdapter { // For demonstration purposes, allow rotation of the external display. // In the future we might allow the user to configure this directly. - if ("portrait".equals(SystemProperties.get("persist.demo.hdmirotation"))) { + /*if ("portrait".equals(SystemProperties.get("persist.demo.hdmirotation"))) { mInfo.rotation = Surface.ROTATION_270; + }*/ + String rotation = SystemProperties.get("ro.orientation.einit","0"); + switch(Integer.valueOf(rotation)) { + case 0: + mInfo.rotation = Surface.ROTATION_0; + break; + case 90: + mInfo.rotation = Surface.ROTATION_90; + break; + case 180: + mInfo.rotation = Surface.ROTATION_180; + break; + case 270: + mInfo.rotation = Surface.ROTATION_270; + break; + default: + mInfo.rotation = Surface.ROTATION_0; + break; } // For demonstration purposes, allow rotation of the external display diff --git a/frameworks/base/services/core/java/com/android/server/display/LogicalDisplay.java b/frameworks/base/services/core/java/com/android/server/display/LogicalDisplay.java index 287a25a..acc4c9f 100755 --- a/frameworks/base/services/core/java/com/android/server/display/LogicalDisplay.java +++ b/frameworks/base/services/core/java/com/android/server/display/LogicalDisplay.java @@ -26,7 +26,7 @@ import java.util.Arrays; import java.util.List; import libcore.util.Objects; - +import android.os.SystemProperties; @@ -137,6 +137,22 @@ final class LogicalDisplay { mInfo.physicalXDpi = mOverrideDisplayInfo.physicalXDpi; mInfo.physicalYDpi = mOverrideDisplayInfo.physicalYDpi; } + if(mDisplayId!=Display.DEFAULT_DISPLAY){ + String rotation = SystemProperties.get("ro.orientation.einit","0"); + int rot = Integer.valueOf(rotation)/90; + if(rot%2!=0) { + mInfo.appWidth = mPrimaryDisplayDeviceInfo.height; + mInfo.appHeight = mPrimaryDisplayDeviceInfo.width; + mInfo.logicalWidth = mPrimaryDisplayDeviceInfo.height; + mInfo.logicalHeight=mPrimaryDisplayDeviceInfo.width; + }else{ + mInfo.appWidth = mPrimaryDisplayDeviceInfo.width; + mInfo.appHeight = mPrimaryDisplayDeviceInfo.height; + mInfo.logicalWidth = mPrimaryDisplayDeviceInfo.width; + mInfo.logicalHeight=mPrimaryDisplayDeviceInfo.height; + } + } + } return mInfo; } @@ -349,6 +365,14 @@ final class LogicalDisplay { mTempDisplayRect.right += mDisplayOffsetX; mTempDisplayRect.top += mDisplayOffsetY; mTempDisplayRect.bottom += mDisplayOffsetY; + if(SystemProperties.getBoolean("persist.sys.rotation.efull", false)) { + if(device.getDisplayDeviceInfoLocked().type!=Display.TYPE_BUILT_IN){ + mTempDisplayRect.left=0; + mTempDisplayRect.right=physWidth; + mTempDisplayRect.top=0; + mTempDisplayRect.bottom=physHeight; + } + } device.setProjectionInTransactionLocked(orientation, mTempLayerStackRect, mTempDisplayRect); } diff --git a/frameworks/native/services/surfaceflinger/DisplayDevice.cpp b/frameworks/native/services/surfaceflinger/DisplayDevice.cpp index 0c63381..68f93ce 100755 --- a/frameworks/native/services/surfaceflinger/DisplayDevice.cpp +++ b/frameworks/native/services/surfaceflinger/DisplayDevice.cpp @@ -538,6 +538,7 @@ void DisplayDevice::setProjection(int orientation, #endif #if !RK_VR & RK_HW_ROTATION +#if 0 bool isHdmiScreen = mType == DisplayDevice::DISPLAY_EXTERNAL; if (isHdmiScreen) { int eInitOrientation = 0; @@ -599,7 +600,7 @@ void DisplayDevice::setProjection(int orientation, } ALOGV("update frame [%d,%d]",frame.getWidth(),frame.getHeight()); } - +#endif if (mType == DisplayDevice::DISPLAY_PRIMARY) { mClientOrientation = orientation; orientation = (mHardwareOrientation + orientation) % 4; -- 2.7.4 原作者:红尘六欲 |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
1133 浏览 0 评论
谁有3566+电池+POE充电的方案,有个项目需要用该功能的主板
1367 浏览 0 评论
RK3588的GMAC0与PHY的参考时钟电平匹配问题??????
7082 浏览 1 评论
请问各位大佬,如何解决,瑞芯微 RV1126B 使用 mpp 自带工具 调试时,内核直接报错崩溃!
2170 浏览 0 评论
使用rk3568开发板,核0\\1\\3运行linux,核2运行hal,在核0中怎么关闭核2
2715 浏览 0 评论
/9
GMT+8, 2025-12-14 15:03 , Processed in 0.480249 second(s), Total 41, Slave 34 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1718
