RK3588电池和充电部分可以参考平板的dts
arch/arm64/boot/dts/rockchip/rk3588s-tablet.dtsi 对应的硬件配置: 双节电池,最大充电电压8.75v 快充IC:BQ25703 电量计:cw2015 DTS配置解析 配置关机充电 charge-animation { compatible = "rockchip,uboot-charge"; rockchip,uboot-charge-on = <1>; //启用uboot的关机充电模式:1:开启,0:关闭 rockchip,android-charge-on = <0>;//启用android的关机充电模式:1:开启,0:关闭,这里默认是关闭,使用的是uboot的关机充电 rockchip,uboot-low-power-voltage = <6800>; //uboot低电预充的开机电压 rockchip,screen-on-voltage = <6900>;// uboot低电预充的亮屏电压 rockchip,uboot-exit-charge-level = <2>; // 退出uboot充电的电量百分比 rockchip,uboot-exit-charge-auto = <0>; //是否开启自动退出uboot充电,与uboot-exit-charge-level 配合使用 rockchip,system-suspend = <1>; //配置uboot关机充电时支持深度休眠 //uboot关机充电时支持深度休眠时如下电源不关闭 regulator-on-in-mem = <&vdd_log_s0>, <&vcc_2v0_pldo_s3>, <&vdd2_ddr_s3>, <&vcc_1v1_nldo_s3>, <&vdd1_1v8_ddr_s3>, <&vcc_1v8_s3>, <&master_pldo6_s3>, <&vdd_0v75_s3>, <&vdd2l_0v9_ddr_s3>, <&vdd_1v8_pll_s0>, <&pldo6_s3>; //uboot关机充电时支持深度休眠时如下电源关闭 regulator-off-in-mem = <&vdd_gpu_s0>, <&vdd_npu_s0>, <&vdd_vdenc_s0>, <&vdd_gpu_mem_s0>, <&vdd_npu_mem_s0>, <&vdd_vdenc_mem_s0>, <&avcc_1v8_s0>, <&vcc_3v3_s0>, <&vccio_sd_s0>, <&master_nldo3>, <&avdd_0v75_s0>, <&vdd_0v85_s0>, <&vdd_cpu_big1_s0>, <&vdd_cpu_big0_s0>, <&vdd_cpu_lit_s0>, <&vdd_cpu_big1_mem_s0>, <&vdd_cpu_big0_mem_s0>, <&vcc_1v8_s0>, <&vdd_cpu_lit_mem_s0>, <&vddq_ddr_s0>, <&vdd_ddr_s0>, <&vcc_1v8_cam_s0>, <&avdd1v8_ddr_pll_s0>, <&vcc_3v3_sd_s0>, <&vcc_2v8_cam_s0>, <&vdd_0v75_pll_s0>, <&vdd_ddr_pll_s0>, <&slave_nldo3>, <&avdd_1v2_cam_s0>, <&avdd_1v2_s0>, <&vcc_3v3_s3>; status = "okay"; }; 配置电量计cw2015和快充bq25703 &i2c2 { status = "okay"; cw2015@62 { status = "okay"; compatible = "cellwise,cw2015"; reg = <0x62>; cellwise,battery-profile = /bits/ 8 <0x17 0x67 0x6C 0x66 0x65 0x64 0x61 0x5B 0x5F 0x75 0x49 0x52 0x50 0x51 0x48 0x3D 0x34 0x2C 0x29 0x21 0x23 0x2D 0x40 0x49 0x25 0x5C 0x0B 0x85 0x10 0x1F 0x31 0x49 0x58 0x5E 0x63 0x6C 0x3E 0x1D 0x9A 0x35 0x0A 0x33 0x15 0x3B 0x70 0x99 0xAB 0x17 0x40 0x75 0x99 0xC4 0x80 0xB5 0xDE 0xCB 0x2F 0x00 0x64 0xA5 0xB5 0x00 0xF8 0x39>; cellwise,dual-cell = <1>; cellwise,monitor-interval-ms = <5000>; power-supplies = <&bq25703>; }; bq25703: bq25703@6b { status = "okay"; compatible = "ti,bq25703"; reg = <0x6b>; ti,u***-charger-detection = <&u***c0>; interrupt-parent = <&gpio0>; interrupts = otg-mode-en-gpios = <&gpio4 RK_PA6 GPIO_ACTIVE_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&charger_ok>; extcon = <&u2phy0>; ti,charge-current = <2500000>; ti,max-input-voltage = <20000000>; ti,max-input-current = <6000000>; ti,max-charge-voltage = <8750000>; ti,input-current = <500000>; ti,input-current-sdp = <500000>; ti,input-current-dcp = <2000000>; ti,input-current-cdp = <2000000>; ti,minimum-sys-voltage = <7400000>; ti,otg-voltage = <5000000>; ti,otg-current = <1500000>; pd-charge-only = <0>; regulators { vbus5v0_typec: vbus5v0-typec { regulator-compatible = "otg-vbus"; regulator-name = "vbus5v0_typec"; }; }; }; }; 不带电池的产品配置 不带电池的产品不需要配置上面的信息,但是需要在dts中加入test-power节点 test-power { status = "okay"; }; 否则会出现开机异常,Android出现找不到电池从而导致crash无法开机。 原作者:loitawu |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
2026 浏览 3 评论
rk1126实现BT601输入,输入不带IIC接口的驱动程序
3773 浏览 0 评论
2332 浏览 1 评论
3563 浏览 3 评论
RK3568 Android11让系统ntp校准时间生效,需要设置些什么
3818 浏览 1 评论
浏览过的版块 |
GMT+8, 2024-9-29 04:56 , Processed in 0.511314 second(s), Total 40, Slave 33 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
