RK3399单MIPI屏调试的步骤和RK3288的MIPI屏调试类似,只不过dts的书写方式有点不一样,首先需要根据电路原理图将enable和reset脚配置好,其次是根据屏的数据手册将屏的lane-rate以及屏的timings找到,具体的方法见我博客的Rockchip之RK3288解决MIPI屏花屏章节.
本文主要讲解与RK3288mipi屏配置dts的差异,首先看RK3399单mipi屏配置,如下: &dsi { status = "okay"; rockchip,lane-rate = <600>; panel@0 { compatible ="simple-panel-dsi"; reg = <0>; backlight = <&backlight>; enable-gpios = <&gpio1 13 GPIO_ACTIVE_HIGH>; enable-delay-ms = <100>; prepare-delay-ms = <100>; reset-gpios = <&gpio4 30 GPIO_ACTIVE_HIGH>; reset-delay-ms = <50>; init-delay-ms = <100>; dsi,flags = <(MIPI_DSI_MODE_VIDEO | MIPI_DSI_MODE_VIDEO_BURST | MIPI_DSI_MODE_LPM | MIPI_DSI_MODE_EOT_PACKET)>; dsi,format = dsi,lanes = <4>; status = "okay"; panel-init-sequence = [ 15 00 02 36 0A 39 00 03 B3 0A 7F 15 00 02 B4 00 39 00 06 B5 4C 14 14 00 20 39 00 08 B6 00 14 0F 16 13 9F 9F 39 00 04 C0 00 0A 10 15 0A 02 C2 6E 39 00 0D C3 01 66 13 23 00 66 85 33 20 38 38 00 39 00 06 C4 22 24 11 11 6D 39 00 0A D0 00 37 52 17 01 04 70 45 05 39 00 0A D1 00 37 52 17 01 04 70 45 05 39 00 0A D2 00 37 52 17 01 04 70 45 05 39 00 0A D3 00 37 52 17 01 04 70 45 05 39 00 0A D4 00 37 52 17 01 04 70 45 05 39 32 0A D5 00 37 52 17 01 04 70 45 05 05 96 01 11 05 00 01 29 ]; display-timings { native-mode = <&timing0>; timing0: timing0 { clock-frequency = <74250000>; hactive = <768>; vactive = <1024>; hback-porch = <10>; hfront-porch = <160>; vback-porch = <40>; vfront-porch = <16>; hsync-len = <160>; vsync-len = <10>; hsync-active = <1>; vsync-active = <1>; de-active = <0>; pixelclk-active = <1>; }; }; }; } 首先不一样的是节点配置方式,其次是命令的配置方式不一样,rk3399的命令配置需要把初始化命令写在 panel-init-sequence = [ 15 00 02 36 0A 39 00 03 B3 0A 7F 15 00 02 B4 00 39 00 06 B5 4C 14 14 00 20 39 00 08 B6 00 14 0F 16 13 9F 9F 39 00 04 C0 00 0A 10 15 0A 02 C2 6E 39 00 0D C3 01 66 13 23 00 66 85 33 20 38 38 00 39 00 06 C4 22 24 11 11 6D 39 00 0A D0 00 37 52 17 01 04 70 45 05 39 00 0A D1 00 37 52 17 01 04 70 45 05 39 00 0A D2 00 37 52 17 01 04 70 45 05 39 00 0A D3 00 37 52 17 01 04 70 45 05 39 00 0A D4 00 37 52 17 01 04 70 45 05 39 32 0A D5 00 37 52 17 01 04 70 45 05 05 96 01 11 05 00 01 29 ]; 把退出命令写在 panel-exit-sequence = [ ]; 命令的前面三个字节分别表示命令类型、延时和命令净荷长度。从第四个字节开始表示命令的有效 payload。这个字节数需要与第三个字节一致。 命令的类型有三种 : 0x05/0x15/0x39. 其中0x05命令类型是带1个参数,如: 05 96 01 11 0x15命令类型是带2个参数,如: 15 00 02 36 0A 0x39命令类型是带多个参数,即大于两个参数,如: 39 00 0A D4 00 37 52 17 01 04 70 45 05 其中,这些命令就需要根据屏的数据手册去寻找,比如我的屏的数据手册中的命令如图: 与我这几个命令相符 15 00 02 36 0A 39 00 03 B3 0A 7F 15 00 02 B4 00 39 00 06 B5 4C 14 14 00 20 这些参数配置完了之后编译烧录屏就能显示了。 遇到问题: 1.背光不能亮 检查硬件电路,或者enable脚是否配置正确. 2.可以显示,但是屏幕花屏 调节rockchip,lane-rate以及timings参数。 原作者:Monster_Ps |
2个回答
您是做什么产品
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
1331 浏览 1 评论
synopsys 的design ware:DW_fpv_div,浮点数除法器,默认32位下,想提升覆盖率(TMAX),如果用功能case去提升覆盖率呢?
1352 浏览 1 评论
RK3588 GStreamer调试四路鱼眼摄像头四宫格显示报错
2868 浏览 1 评论
【飞凌嵌入式OK3576-C开发板体验】RKNN神经网络-YOLO图像识别
254 浏览 0 评论
【飞凌嵌入式OK3576-C开发板体验】SSH远程登录网络配置及CAN通讯
1336 浏览 0 评论
GMT+8, 2024-11-2 15:16 , Processed in 0.615514 second(s), Total 75, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
