目前用my_mqtt软件包做的单主题订阅已经调通,但是当把主题数量增加时就会报错,想到之前看到个帖子说paho_mqtt V1.1.0只支持1个主题订阅,请教各位是这样的吗?是否有人使用过多主题订阅?
如果不支持的话,是否可以曲线救国,通过更改主题来实现多个主题的订阅? |
2个回答
Paho MQTT 和 myMQTT 都是支持订阅多个主题的,myMQTT 订阅多个主题需要在配置中对最大订阅主题的个数进行修改,方法如下所示。
比如说你定义的最大订阅个数是3,直接像下面这样写就行了 /* set subscribe table and event callback */ client.message_handlers[0].topicFilter = rt_strdup(MQTT_SUBTOPIC0); client.message_handlers[0].callback = mqtt_sub_callback; client.message_handlers[0].qos = QOS1; /* set subscribe table and event callback */ client.message_handlers[1].topicFilter = rt_strdup(MQTT_SUBTOPIC1); client.message_handlers[1].callback = mqtt_sub_callback; client.message_handlers[1].qos = QOS1; /* set subscribe table and event callback */ client.message_handlers[2].topicFilter = rt_strdup(MQTT_SUBTOPIC2); client.message_handlers[2].callback = mqtt_sub_callback; client.message_handlers[2].qos = QOS1; |
我没有用过umqtt,但是看了一下源码,umqtt是支持多主题订阅的。
umqtt_subscribe的过程可以简化为: 1.通过语句取得client的sub_rec_list,若链表不为空,则判断topic是否已存在; _cnt = rt_list_isempty(&client->sub_recv_list); rt_list_for_each(node, &client->sub_recv_list) .... 2.发送sub数据,若收到suback,则将新节点插入到client的sub_rec_list链表中 rt_list_insert_after(&client->sub_recv_list, &p_subtop->next_list); 完整的umqtt_subscrbie的代码如下: int umqtt_subscribe(struct umqtt_client *client, const char *topic, enum umqtt_qos qos, umqtt_subscribe_cb callback) { int _ret = 0; int _length = 0; int _cnt = 0; struct subtop_recv_handler *p_subtop = RT_NULL; rt_list_t *node = RT_NULL; struct umqtt_msg encode_msg = { 0 }; struct umqtt_msg_ack msg_ack = { 0 }; RT_ASSERT(client); RT_ASSERT(topic); _cnt = rt_list_isempty(&client->sub_recv_list); if (_cnt == 0) { _cnt = 0; rt_list_for_each(node, &client->sub_recv_list) { p_subtop = rt_list_entry(node, struct subtop_recv_handler, next_list); if (p_subtop->topicfilter && (rt_strcmp(p_subtop->topicfilter, topic) == 0)) { LOG_D(" subscribe topic(%s) is already subscribed.", topic); goto exit; } } _length = rt_list_len(&client->sub_recv_list); } if (_length > client->sub_recv_list_len) { _ret = UMQTT_MEM_FULL; LOG_E(" subscribe size(%d) is not enough! now length(%d)!", client->sub_recv_list_len, _length); goto exit; } else { rt_memset(&encode_msg, 0, sizeof(encode_msg)); encode_msg.header.bits.qos = UMQTT_QOS1; encode_msg.msg.subscribe.packet_id = get_next_packetID(client); encode_msg.msg.subscribe.topic_filter[0].topic_filter = topic; encode_msg.msg.subscribe.topic_filter[0].filter_len = strlen(topic); encode_msg.msg.subscribe.topic_filter[0].req_qos.request_qos = qos; encode_msg.msg.subscribe.topic_count = 1; rt_memset(client->send_buf, 0, sizeof(rt_uint8_t) * client->mqtt_info.send_size); _length = umqtt_encode(UMQTT_TYPE_SUBSCRIBE, client->send_buf, client->mqtt_info.send_size, &encode_msg); if (_length <= 0) { _ret = UMQTT_ENCODE_ERROR; LOG_E(" subscribe encode failed! topic: %s", topic); goto exit; } client->send_len = _length; _ret = umqtt_trans_send(client->sock, client->send_buf, client->send_len, client->mqtt_info.send_timeout); if (_ret < 0) { _ret = UMQTT_SEND_FAILED; LOG_E(" subscribe trans send failed!"); goto exit; } set_uplink_recon_tick(client, UPLINK_LAST_TICK); rt_memset(&msg_ack, 0, sizeof(msg_ack)); if (RT_EOK == rt_mq_recv(client->msg_queue, &msg_ack, sizeof(struct umqtt_msg_ack), rt_tick_from_millisecond(client->mqtt_info.send_timeout * 1000))) { if (msg_ack.msg_type == UMQTT_TYPE_SUBACK) { p_subtop = RT_NULL; p_subtop = (struct subtop_recv_handler *)rt_calloc(1, sizeof(struct subtop_recv_handler)); RT_ASSERT(p_subtop); LOG_D(" start assign datas !"); p_subtop->topicfilter = rt_strdup(topic); p_subtop->qos = qos; if (callback) { p_subtop->callback = callback; } rt_list_insert_after(&client->sub_recv_list, &p_subtop->next_list); set_uplink_recon_tick(client, UPLINK_NEXT_TICK); _ret = UMQTT_OK; LOG_I("subscribe ack ok! "); goto exit; } else { _ret = UMQTT_READ_ERROR; LOG_E("subscribe ack error!"); goto exit; } } else { _ret = UMQTT_READ_FAILED; LOG_E(" subscribe recv message timeout! topic: %s", topic); goto exit; } } exit: return _ret; } 此外,内部的umqtt_deliver_message函数中,也是遍历链表,然后执行回调的。 因此,umqtt支持同一client的多主题订阅。 |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
1033 浏览 0 评论
2877 浏览 0 评论
图腾柱PFC无法上升至400V,且电感电流为正弦波形,但是幅值极小
9386 浏览 0 评论
飞凌嵌入式ElfBoard-Vim编辑器之静态链接和动态链接
2898 浏览 0 评论
使用 LinkBoy 将程序导出为 C 语言代码并烧录至 Arduino ESP32 开发板
2302 浏览 1 评论
/9
GMT+8, 2025-12-2 05:45 , Processed in 2.099123 second(s), Total 76, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1327
